Release 2.2.4 Available
Hubitat Elevation Platform update 2.2.4 is now available:
Please note, the process takes about a minute to download (depending on your Internet connection) and extract the hub update, and 1-2 minutes to perform the update after you click 'Update Hub'. We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 2.2.3:
Drivers and Devices
  • New drivers:
    • Jasco Z-Wave double plug (dimmer and switch models)
    • Leaksmart Zigbee Moisture Sensor
    • Generic Zigbee Motion Sensor (no temp)
    • Inovelli Z-Wave 2-Channel Plug (NZW37)
    • Zipato Z-Wave Bulb 2
    • Zlink water leak and temperature sensor
    • HAB Home Intel Z-Wave iBlinds V3
    • Aeotec Nano Shutter
    • Shelly DUO using Shelly WiFi CT Bulb
    • Shelly Bulb using Shelly WiFi RGBW Bulb
    • Sonoff Zigbee Temperature/Humidity Sensor (SNZB-02)
    • Sonoff Zigbee Contact Sensor (SNZB-04)
    • Sonoff Zigbee Button Controller (SNZB-01)
    • Aeotec Smart Switch 7 US (ZWA023-A)
    • Generic Z-Wave Plus Smoke/CO Detector
    • Re-engineered Aeotec Siren 6 with full doorbell 6 compatibility
    • Zooz Remote Switch (Zen34)
    • Leviton Zigbee Dimmer supports DG6HD and DG3HL Plugin Dimmer
  • New compatible devices
    • Ecolink Zigbee contact using Generic Zigbee Contact Sensor
    • GoControl GD00Z-8 using Generic Z-Wave Garage Door Opener
    • Linkind Zigbee motion sensor using Generic Zigbee Motion Sensor (no temp)
    • Monoprice Z-Wave Contact Sensor using Generic Z-Wave Contact Sensor
    • Minoston Z-Wave 2-Channel Plug (MP20Z) using Inovelli 2-Channel Plug
    • GoControl WA00Z-1 Wireless Remote Switch using Generic Z-Wave Button Controller
    • GoControl LBR30Z-1 Dimmable LED Indoor Flood Light using Generic Z-Wave Smart Dimmer
    • Shelly Plug S using Shelly WiFi Switch
    • Shelly 1 using Shelly WiFi Switch
    • Shelly 1PM using Shelly WiFi Switch
    • Shelly 2.5 using Shelly WiFi Switch
    • Shelly Plug using Shelly WiFi Switch
    • Trane XR524 Thermostat using Generic ZWave Thermostat
    • AGSHome Motion using Generic Zigbee Motion Sensor (no temp)
    • Sonoff SNZB-03 motion using Generic Zigbee Motion Sensor (no temp)
    • GE Smart Outlet using Generic Zigbee Outlet
    • GE Smart Switch (plug in model) using Generic Zigbee Outlet
    • Leviton ZW15R using Generic Z-Wave Outlet
    • Color8 support added to Yeelight Integration
    • Sinope TH1500ZB thermostat using Sinope TH1400ZB Thermostat
    • First Alert ZCOMBO Gen2 using Generic Z-Wave Plus Smoke/CO Detector
    • First Alert ZCOMBO Gen3 using Generic Z-Wave Plus Smoke/CO Detector
    • Sonoff Zigbee Smart Plug using Generic Zigbee Outlet
    • Leviton DG15S Zigbee Switch using Generic Zigbee Switch
    • SmartThings bulb (GP-LBU019BBAWU) using Generic Zigbee Bulb
    • Leviton DG15A Plugin Zigbee Switch using Generic Zigbee Switch
    • Sinope water valve model VA4220ZB using Sinope water valve
    • Sinope Smart Plug SP2600ZB using Generic Zigbee Outlet
    • Sinope In-Wall Outlet SP2610ZB using Generic Zigbee Outlet
  • New driver features
    • August Pro Z-Wave Lock, add keypad events
    • Generic Zigbee Outlet, enable power reporting for Salus SP600 plug
    • Device, add custom commands for the following:
      • Delete scheduled jobs
      • Delete child devices
      • Delete all states
    • Hue Motion Sensor, update attribute reporting options (see this post)
    • Add temperature reporting options to the following drivers:
      • Bosch Motion Detector
      • Generic Zigbee Contact Sensor
      • Generic Zigbee Moisture Sensor
      • Generic Zigbee Motion/Humidity Sensor
      • Hue Motion Sensor
      • NYCE Motion Sensor Series
      • Sinope Moisture Sensor
      • SmartThings Humidity Sensor
    • Add humidity reporting options to the following drivers:
    • All drivers: battery events now force a state change (isStateChange:true)
    • Sinope thermostat drivers (all), add Clock display format option.
    • Sonos Player, add options for volume up/down and trackData events disable
    • GE Zigbee Dimmer, add options for level staging, level change rate and minimum level
    • Generic Zigbee Outlet, enable power reporting for Salus SP600 plug, add flash command.
    • GE Enbrighten Z-Wave Smart Dimmer, add options for level staging, level change rate maximum level and default transition time.
New Apps
  • Thermostat Controller (see this post)
  • Device Firmware Update (see this post)
  • Hub Mesh - seamlessly use devices connected to one hub on a second (or third, or fourth) hub residing on the same local network. (see this post)
New App Features
  • Rule-4.0:
    • Added Sound Sensor capability.
    • Added explicit Cron string for Periodic trigger.
    • New UI for Local Variables.
    • Wait for Elapsed Time. (see this post )
  • Rule Machine:
    • New UI for Global Variables.
    • Rule Backup/Restore now allows multiple rules to be downloaded or imported at one time with a single file. Clone Rule has been improved to allow device replacement selections.
  • Simple Automation Rule
    • Added check for on/off before sending on/off command.
    • Reworked UI for consistency and flexibility (see this post).
    • Added more sensor types for triggering: sound, temperature and humidity.
    • Added ability to control color temperature.
    • Added ability to trigger on specific mode transitions, e.g., Away to Evening.
    • Added simple delay for action.
  • Zone Motion Manager:
    • Added more zone timeout options.
  • Scene 1.2
    • Changed adjust page to start with captured values.
  • Dashboard:
    • Specific tokens per menu and dashboards, addressing a security concern.
    • Devices are not added by default, need to be granted per dashboard, also a security issue.
    • Per user Dashboard, allows to grant individual tokens per user. Allows QR code capture of user specific Dashboard.
  • MakerAPI: Allow options for modes/hsm.
  • Mode Lighting: Now supports a switch to disable setting the lights, for example on a mode change.
  • Motion Lighting: Added export/import/clone rules.
  • Button Controllers now supports rule export/import/clone.
Bug Fixes
  • Fixed bug with CCI4 (Input 2) for Lutron VCRX driver.
  • Jasco Z-Wave Motion Switch, corrected fingerprint.
  • Zooz 4 in 1, cast Humidity to Integer value.
  • RGBgenie Button Controller, fixed released event bug.
  • C7: Zooz Zen20 Powerstrip: Fixed redundant reporting, and multi-channel incompatibilities.
  • C7: Zooz Zen27 Double Plug: Fixed multi-channel incompatibilities.
  • C7: Zooz Zen30 Double Switch: Fixed multi-channel incompatibilities. (note: device must be included without security due to reporting quirk in the device)
  • C7: Fixed Yale Conexis L1 Z-Wave Lock event reporting.
  • C7: Fixed Ring Alarm Contact Sensor Gen 2 wakeup functions.
  • C7: Fixed Z-Wave hub node ID sometimes shows as zero.
  • C7: Fixed thermostatModeSet command rejection when sent to unsolicited destination.
  • C5/C4/C3: Fixed a Z-Wave issue that could have caused some drivers to incorrectly send non-security encapsulated packets when included with security.
  • Increased Z-Wave send pool size.
  • Fixed ST V4 presence beep.
  • Fixed default value bug in ST V4 Presence .
  • Fixed August Pro keypad event reversal.
  • Fixed VirtualDimmer missing log conditional.
  • Inovelli Bulb Drivers: Fixed bug preventing configuration variable from being saved to device.
  • Fix Z-Wave v3 and v4 multiChannelEndpointReports.
  • Alexa Skill: Added preference for fan control devices to select between FanControl and SwitchLevel, preventing double reporting that is causing alexa to incorrectly report the device is not responding.
  • Orvbio Motion sensor now uses Generic Zigbee Motion Sensor (no temp) driver.
  • Rule-4.0:
    • Fixed error thrown with Bad Number in actions.
    • Fixed bug causing ‘ringing’ with string variable connectors.
    • Fixed bugs with Boolean local variable connectors.
    • Fixed multiple repeats and stop repeat.
  • Button Controller 3.1:
    • Fixed bug with Position Shade.
    • Fixed bug with Fade dimmer.
  • Yale Zigbee Lock driver: fix battery report for YRD226L TSDB.
  • ERIA Motion Sensor: fix battery reports.
  • Fixed incorrect bitmask on Z-Wave ThermostatSetpointReport setpointType.
  • Thermostat Scheduler: Fixed EcoMode thermostat settings.
  • Virtual Dimmer: Send switch off event when setLevel 0 is called.
  • Lock Code Manager: Fix bug where adding a new user code failed if an existing user code was disabled.
  • Dashboard: Fixed swapped cloud/local allow access toggle buttons.
  • Dashboard: Changed Per User Dashboard UI.
  • Dashboard: Fix on color bulb tile On/Off not working for some devices.
  • Alexa Skill: Fixed thermostat delta setpoint directive error.
  • Schlage BE468/BE469 Lock: Fix code name not being displayed correctly when unlocked using pin code with older device firmwares.
  • Generic Z-Wave Lock: Bug fix for Kwikset locks not always reporting user code after set.
Platform Changes
  • C7: Z-Wave UI improvements:
    • Removed hub node from Z-Wave details page.
    • New node health statistics and topology map (see this post).
    • Fixed an issue that caused node statistics and routes to be lost on node refresh and repair.
  • C7 Z-Wave improvements in packet handling: (see this post)
    • Improved secure inbound packet handling, recycling of secure sessions for faster response time and less potential re-transmits or drops.
    • Re-worked ack / nack / nack+waiting / ack timeout handling.
      • Improved reliability of FLiRS/LSS device communication (ex: Locks).
      • Improved reliability of packet delivery under heavy load.
    • Improved reliability of failed node removal.
    • Fixed occasional SDK crash during network management operations, often requiring a reboot to fix.
    • Updated multi-channel encapsulation processing for new SDK standards.
    • Inbound packet de-duplication.
  • C7: Z-Wave Repair (see this post):
    • Improved reliability.
    • New GUI interface.
    • Now repairs nodes in order based on network topology.
    • Adds additional routes for legacy nodes (pre-plus) to the hub’s virtual nodes.
  • Added new Z-Wave Entry Control V1 Classes.
  • Added new Z-Wave Sound Switch V1/V2 Classes.
  • User logging added for invalid outbound Zigbee messages.
  • Refactor Zigbee class dynamic variables to static types.
  • Broken socket connections now generate device level errors.
  • Chromecast NPEs don't spam logs any more,
  • Revamped timeToday function.
Release 2.2.4.141 Available
This hot fix Includes:
Bug Fixes
  • Aeotec Siren 6: Fixed button press events.
  • Qubino dual relay: Fixed child events.
  • Aeotec Recessed Door Sensor: Fixed for incorrect default configuration.
  • Dashboard: Restored legacy Dashboard Links tile.
  • Simple Automation Rule: Fixed secondary action logic.
  • Sonoff Zigbee Contact Sensor: Corrected capability.
  • Hub Mesh: Propagates hub name changes.
  • Scene Transition: Fixed possible error at activation with switch in Scene.
  • Fixed time input UI for iPad.
  • Child devices' getDataValue() NPE fix.
  • Fixed 500 error on Z-Wave Details page when loading on a large mesh.
A post was split to a new topic: What was 2.2.4.142 release announcement
This release 2.2.4.142 has been pulled. If you updated to it, you should roll back to your previous release.
Release 2.2.4.143 Available
New Supported Devices
  • Linkind Tunable White Bulb using Generic Zigbee CT Bulb
  • Sylvania Edge-LIt Under Cabinet Tunable White using Generic Zigbee CT Bulb
  • Sylvania Flushmount Tunable White using Generic Zigbee CT Bulb
Bug Fixes
  • Aeotec Siren 6 fixes.
  • Aeotec Recessed Door Sensor fixed error introduced in last build.
  • Qubino Dual Relay fixed child devices.
  • Rule-4.0: Fixed bug related to Wait for mode.
  • Scene Transition: Fixed bug with 'off' command to activation device.
  • Fixed 500 error on Z-Wave Details page.
  • Fixed battery reporting bug when battery is replaced on:
    • Bosch Zigbee Motion
    • Generic Zigbee Contact No Temp
    • Generic Zigbee Motion Humidity Sensor
    • Generic Zigbee Motion No Temp
    • Philips Hue Motion
    • Smart Sense Humidity
Release 2.2.3.143 is essentially the same release as yesterday's 2.2.4.142, minus the bug that caused it to be pulled -- ah, with that bug no longer part of it.
Release 2.2.4.145 Available
This hot fix includes:
App Name Change
Motion Lighting Apps has been changed to Motion and Mode Lighting Apps. This has no effect on your installed apps.
New App Features
  • Hub Mesh: Added support added for TCP based connectivity (for mesh routers).
Bug Fixes
  • C7: Multiple issues were fixed for Z-Wave Repair.
  • C7: Enhancements were made to outbound Z-Wave queues to better handle groups and slow devices.
  • Dashboards: Changed Dashboards to make "Dashboard Link Tile" work as before when opening from WebMenu or MobileApp.
Release 2.2.4.147 Available
New Driver
  • Lutron VCRX Output. This replaces the previous component elements of the VCRX driver. Each VCRX output has its own Integration ID in the Lutron system. The output can be pulsed on for a settable amount of time, either by pushing a button, or by turning it on. The driver will show the state of the output based on timing the pulse, as Lutron does not report the pulse off event. See page 139 of the Lutron Integration Protocol.
Bug Fixes
  • Fixed Z-Wave Firmware MD Report CC null on v3+ when only 1 firmware target exists.
  • C7: Device Firmware Updater:
    • Fixed invalid fragment size error.
    • Clear inputs on complete or failed result.
  • HomeSeer WD200+: Fixed set led indicator command.
  • Zooz Double Switch: Fixed child events for S2 included device with new firmware.
  • Jasco Dual Switch/Dimmer: Fixed error when componentOn is sent on dimmer models.
  • Hub core: updateDataValue/getDataValue now work properly.
  • Hub core: revised memory settings for C4 hubs.
  • Hub mesh: no state change event spamming on full refresh.
  • ChromeCast: added automatic reconnect attempts.
  • AppUI: Time input width fix for 24 hours format.
  • Motion and Mode Lighting Apps: fixed bug when saving a ML rule.
  • Simple Automation Rule: fixed restrictions, sunrise/sunset offsets, days of week bugs.
  • Sonoff Zigbee Button Controller: Add doubletapable and missing battery capability and function.
  • Leviton VRSC4 Z-Wave Controller: Add multicast frame option, fix some devices not reporting.
  • GE Enbrighten Z-Wave Smart Dimmer: fix error when included with S2 security enabled
Release 2.2.4.148 Available
  • Hub core: fix for a bug that prevented database self-repair.
  • Inovelli 4-in-1 sensor: fix for missed initial device data under some conditions.
  • Virtual shade: fix for transition time options.
  • Rule Machine: fix for days of the week.
