Release 2.3.0 Available
Hubitat Elevation Platform update 2.3.0 is now available:
Please note, the process takes about a minute to download (depending on your Internet connection) and extract the hub update, and 1-2 minutes to perform the update after you click 'Update Hub'. We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 2.2.9
New Drivers
  • LIFX Color
  • LIFX White
  • LIFX CT
  • LIFX Switch
  • LIFX Strip
  • Minoston Mini Power Meter Plug (MP21ZP)
  • Ministon Mini Smart Plug Dimmer (MP21ZD)
  • Aeotec Illumino Dimmer Switch (ZWA037-A)
  • Aeotec Illumino Wall Switch (ZWA038-A)
  • Homeseer WX300 Dimmer
  • Homeseer WX300 Switch
  • Zooz ZSE44 Temperature Humidity XS Sensor
  • Zooz ZSE43 Tilt Shock XS Sensor
  • Virtual Lock (no codes)
New Compatible Devices
  • LIFX A19 using LIFX Color
  • LIFX BR30 using LIFX Color
  • LIFX Mini White using LIFX White
  • LIFX Mini Day Dusk using LIFX CT
  • LIFX Mini Color using LIFX Color
  • LIFX Candle White to Warm using LIFX CT
  • Vesternet Zigbee 8 Button Wall Controller VES-ZB-WAL-012 using RGBgenie Button Controller
  • INNR SP 234 smart plug using Generic Zigbee Outlet
  • Centralite Nightlight/Repeater 3420 using Generic Zigbee Bulb
  • New One Mini Smart Plug (N4001) using Generic Z-Wave Plus Outlet
  • New One Mini Smart Plug Dimmer (N4002) using Generic Z-Wave Plus Dimmer
  • Minoston Z-Wave Outdoor Dimmer Plug (MP22ZD) using Generic Z-Wave Plus Dimmer
  • eWeLink 10A Outlet (SA-003-Zigbee) using Generic Zigbee Outlet
  • Kwikset 916 Touchscreen Deadbolt using Generic Zigbee Lock
  • ZLINK Plug-in-Dimmer ZL-PD-100 using Generic Z-Wave Plus Dimmer driver
  • Ultraloq U-Bolt Pro Z-Wave using Generic Z-Wave Lock driver
  • Alarm . com ADC-3000 using Generic Z-Wave Plus Thermostat driver
  • GoControl LB60Z-1 using Generic Z-Wave Dimmer driver
  • Yeelight model colorb added to Yeelight integration using Yeelight RGBW Bulb
  • E-Wand Zigbee blind wand using Generic Zigbee Shade
  • Yoolax Zigbee roller blind using Generic Zigbee Shade
New Driver Features
  • Aeotec Smart Switch 7 added CurrentMeter capability.
  • Added temperature and humidity reporting options to Sonoff Zigbee Temperature/Humidity Sensor.
  • Added firmware update command to Aurora Dimmer and switch drivers.
New Apps
  • LIFX Integration
  • New Lock Mirror child app added to Mirror app, includes command retry, status verification and command notification options.
New App Features
  • Rule 5.1 / Button Rule 5.1:
    • Added variable for chime number.
    • Added ‘On a Day’ condition.
    • Added Copy Actions (as in Cut, Copy, Paste).
    • Added optional offset for variable time trigger.
    • Added annual and one-time only variable time triggers.
    • Allow string variable token operations on %date%, %time%, etc.
    • Added import action clipboard from other Rule 5.1 / Button Rule 5.1.
    • Added fade time for Color Temperature actions.
    • Added fade level option for Fade Color Temperature.
    • Added allow variable values in rule name.
    • Added dates to DateTime variable comparisons.
    • Added passing last event device to called rule.
    • Changed Predicate rule to Required Expression.
    • Changed IF rule THEN, et al, to IF Expression THEN
    • Added %variable% use in Custom Attribute text value.
  • Basic Rule 1.0:
    • Added 'When turns off and stays off …'.
    • Added set thermostat setpoints.
  • Notify: Added logging.
  • Mode Manager: Added link to Settings / Mode page.
  • Group 2.1: Added group state indicator for activator devices.
  • Dashboards: Hub Variables can now be controlled directly from a tile, without connector.
  • Thermostat Scheduler: Added variables for setpoints.
Bug Fixes
  • Prevent duplicate global variable events.
  • Fixed motion sensitivity configuration parameter Neo Motion Sensor 700 driver.
  • Rule 5.1 / Button Rule 5.1 See Notice Below:
    • Fixed multiple scheduled jobs for times in Predicate rule.
    • Fixed broken list rule names pulldowns.
    • Fixed dateTime offset UI.
    • Fixed Between Two Dates as Predicate condition.
    • Fixed / in variable name for ‘sensor value’ and ‘device attribute’.
    • Fixed option to use date for variable time trigger.
    • Fixed UI for Between Two Dates with variable dates.
    • Fixed bug with Between Two Times in Wait.
    • Fixed UI display of some Certain Time triggers.
    • Fixed Days of Week Schedule trigger.
    • Fixed paste of Wait for Events
    • Fixed variable trigger bug.
  • Scene 1.2: Fixed initialization sequence with Push Button.
  • Dashboards: Fixed time tile for datetime variables.
  • Button Rule 5.1: Fixed pause rule selector error.
  • Group 2.1: Fixed setLevel(0) behavior.
  • Rule 5.0: Changed display of Paused to higher priority than Predicate False.
  • Motion Lighting: Fixed disable with Boolean variable.
  • Lutron Dimmer: Fixed use last level to avoid race condition.
  • Hub Variables: Fixed display of full DateTime variables for time zone difference.
  • DateTime Connector: Check input for valid time string.
  • Fixed and issue with ICMP ping where a timeout would cause all zeros in reply.
  • Fixed Z-Wave CC MeterPulseV1.
  • Correct indicator preferences for GE Enbrighten Z-Wave Plus Smart Fan Control when using GE Smart Fan Control driver.
  • Fixed links for alerts to point to the logs page now.
  • Fixed data handling in EventStream.
Platform Changes
  • Added mustCommitUi boolean app definition option to isolate UI changes from running app instances while UI changes are in progress. If true, mustCommitUi replaces app’s Done button with a pair of Apply/Cancel buttons. Behind the scenes, mustCommitUi creates temporary versions of app state and settings for the UI until changes are either committed or discarded.
  • Added an option to create user apps/drivers without exposing their source code.
  • Added currently running jobs tab on Logs page.
  • Added Aurora firmware images for Rotary Dimmer, Double Socket and several LED strips. * Added private bundles option for app/driver distribution while keeping source code hidden.
  • Added editable per-device "too many events" alert threshold.
  • Added better network disconnect handling when network watchdog is enabled or when using WiFi adapters.
  • Added boolean rawStream parameter to EventStream interface, which passes all incoming traffic to parse() method without changes.
  • Added boolean secureSocket (SSL implementation), boolean ignoreSSLIssues, boolean convertReceivedDataToString (passes UTF-8 string instead of hex encoded byte array to parse) and int bufferSize (1kb to 1Mb) parameters to RawSocket interface.
Notice about Rule Machine
There was a bug reported and fixed concerning triggers using Hub Variables. If you have any such rules, please open the Rule Machine parent app, and just hit Done. This will update those rules. If you don't do this, and had Variable triggers, they will disappear from your rules.
Release 2.3.0.112 Available
Changes from 2.3.0.111
New App Features
  • Notifier: Added local file option for notifications.
Bug Fixes
    • Fixed Periodic scheduling with Required Expression.
    • Fixed Play Chime action with variable sound number.
  • Fix for occasional 500 error on the logs page.
  • Dashboards:
    • Fixed Hub Variables not showing on legacy dashboard links.
    • Fixed Hub Variables not sorted.
Release 2.3.0.113 Available
Changes from 2.3.0.112
New App Features
  • Scene 1.2: Added ‘discrete on’ option to restore prior functionality as default.
Bug Fixes
  • Rule-4.1: Fixed setting time variable with sunrise or sunset.
  • Hub Variables: Fixed bug with DateTime variable set by Dashboard.
  • Rule 5.1 / Button Rule 5.1: Fixed Play Chime action with variable sound number (again).
  • Fixed LIFX Strips driver selection.
  • Dashboard: Fixed DateTime Variable not being saved correctly from variable tile.
Release 2.3.0.115 Available
Changes from 2.3.0.113
New Drivers
  • LIFX Strip Legacy (Z-TV)
New App Features
  • Notifier: Added Carbon Dioxide Sensor.
Bug Fixes
    • Fixed bug with subscriptions for custom attributes.
    • Fixed bug with variables in use at initialization.
    • Fixed bug with suppressed display of square brackets.
    • Fixed bug with overwrite of trigger with actions paste.
  • Fixed rounding of hue on Zooz RGBW Dimmer Driver.
  • Fixed initial logsOff scheduling in LIFX drivers.
  • Fixed multiple unhandled command messages in LIFX Drivers.
  • Advanced Zigbee CT and RGBW drivers, fix setColorTemperature command ignoring level param when device is off.
Release 2.3.0.116 Available
Changes from 2.3.0.115
Bug Fixes
  • Networking app identifies hub version correctly.
Release 2.3.0.118 Available
Changes from 2.3.0.116
New Drivers
  • LIFX Color Legacy
Bug Fixes
  • Fixed overnight backup scheduling.
  • Generic Zigbee Motion Sensor (no temp), fixed Linkind and other recently added devices not reporting motion.
  • Lutron dimmer: Fixed saving last level from physical switch level set.
  • Button Rule 5.1: Fixed Pause/Resume.
Release 2.3.0.119 Available
Changes from 2.3.0.118
NOTICE: We found an unfortunate break in a core hub module that can lead to database corruption. We strongly recommend all users to upgrade to 2.3.0.119.
Bug Fixes
  • Fix for database errors with prior 2.3.0 builds.
Release 2.3.0.120 Available
Changes from 2.3.0.119
Platform
  • Log4j security update (from 2.15.0 to 2.16.0).
Bug Fixes
  • Added text to speech delay option for ChromeCast video driver. Use it if Fuschia powered Nest hub cuts off the first words of a spoken phrase.
  • Fixed the "device event details not showing" issue.
  • Rule 5.1: Fixed bug with copy/paste of Variable condition.
  • Reduce event and log spam when using flash on LIFX devices
  • Fixed issues with older firmware Linkind motion sensors.
Release 2.3.0.121 Available
Changes from 2.3.0.120
Platform changes
  • Log4j update 2.16.0 -> 2.17.0.
Bug Fixes
  • Fix for a potential Zigbee freeze on startup.
    • Fixed bug with Rule Paused condition.
    • Fixed February 29 as date choice.
    • Fixed bug with Add Parameter for custom action.
Release 2.3.0.123 Available - bug discovered, version no longer available
Please see this post:
Release 2.3.0.124 Available
Changes from 2.3.0.121
Bug Fixes
  • Hubitat Safety Monitor:
    • Fixed light capture/restore.
    • Fixed lights flash UI break.
  • Button Controller 5.1: Fixed error on removing an instance of the app.
    • Fixed February 29 for ‘On a Day’ and ‘Between Two Dates’ conditions.
    • Fixed Change ColorTemperature over time bug.
  • Linkind Motion Sensor, please change to the new Linkind Zigbee Motion Sensor driver included in this release if you've been having issues with this device in platform version 2.3.0.xxx
