Our engineers have identified an issue with the last update, and version 2.3.0.123 has been temporarily removed.
If you are running this version, please connect to hub and select "Settings" on the left menu then "Check for Updates." You should see a prompt to install the current public version: 2.3.0.121.
If you don't see a notification that an update is available, then please visit the Diagnostic Tool, and click "Restore Previous Version." Select version 2.3.0.121, as shown in picture below:
If you continue to have any problems, don't hesitate to reach out to support@hubitat.com.
