Works fine.
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Z-Wave Door/Window Sensor
* Author: SmartThings
* Date: 2013-11-3
metadata {
definition (name: "Aeon Recessed Door Sensor", namespace: "Hubitat", author: "keltymd", ocfDeviceType: "x.com.st.d.sensor.contact") {
capability "Contact Sensor"
capability "Sensor"
capability "Battery"
capability "Configuration"
capability "Health Check"
fingerprint deviceId: "0x2001", inClusters: "0x30,0x80,0x84,0x85,0x86,0x72"
fingerprint deviceId: "0x07", inClusters: "0x30"
fingerprint deviceId: "0x0701", inClusters: "0x5E,0x98"
fingerprint deviceId: "0x0701", inClusters: "0x5E,0x86,0x72,0x98", outClusters: "0x5A,0x82"
fingerprint deviceId: "0x0701", inClusters: "0x5E,0x80,0x71,0x85,0x70,0x72,0x86,0x30,0x31,0x84,0x59,0x73,0x5A,0x8F,0x98,0x7A", outClusters:"0x20" // Philio multi+
fingerprint mfr:"0086", prod:"0002", model:"001D", deviceJoinName: "Aeotec Door/Window Sensor (Gen 5)"
fingerprint mfr:"0086", prod:"0102", model:"0070", deviceJoinName: "Aeotec Door/Window Sensor 6"
fingerprint mfr:"0086", prod:"0102", model:"0059", deviceJoinName: "Aeotec Recessed Door Sensor"
fingerprint mfr:"014A", prod:"0001", model:"0002", deviceJoinName: "Ecolink Door/Window Sensor"
fingerprint mfr:"014A", prod:"0001", model:"0003", deviceJoinName: "Ecolink Tilt Sensor"
fingerprint mfr:"011A", prod:"0601", model:"0903", deviceJoinName: "Enerwave Magnetic Door/Window Sensor"
fingerprint mfr:"014F", prod:"2001", model:"0102", deviceJoinName: "Nortek GoControl Door/Window Sensor"
fingerprint mfr:"0063", prod:"4953", model:"3031", deviceJoinName: "Jasco Hinge Pin Door Sensor"
fingerprint mfr:"019A", prod:"0003", model:"0003", deviceJoinName: "Sensative Strips"
// simulator metadata
simulator {
// status messages
status "open": "command: 2001, payload: FF"
status "closed": "command: 2001, payload: 00"
status "wake up": "command: 8407, payload: "
// UI tile definitions
tiles(scale: 2) {
multiAttributeTile(name:"contact", type: "generic", width: 6, height: 4){
tileAttribute ("device.contact", key: "PRIMARY_CONTROL") {
attributeState("open", label: '${name}', icon: "st.contact.contact.open", backgroundColor: "#e86d13")
attributeState("closed", label: '${name}', icon: "st.contact.contact.closed", backgroundColor: "#00A0DC")
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat",width: 2, height: 2) {
state "battery", label:'${currentValue}% battery', unit:""
main "contact"
details(["contact", "battery"])
private getCommandClassVersions() {
[0x20: 1, 0x25: 1, 0x30: 1, 0x31: 5, 0x80: 1, 0x84: 1, 0x71: 3, 0x9C: 1]
def result = null
if (description.startsWith("Err 106")) {
if (state.sec) {
log.debug description
} else {
result = createEvent(
descriptionText: "This sensor failed to complete the network security key exchange. If you are unable to control it via SmartThings, you must remove it from your network and add it again.",
eventType: "ALERT",
value: "failed",
isStateChange: true,
} else if (description != "updated") {
def cmd = zwave.parse(description, commandClassVersions)
if (cmd) {
result = zwaveEvent(cmd)
log.debug "parsed '$description' to $result"
return result
def installed() {
// Device-Watch simply pings if no device events received for 482min(checkInterval)
sendEvent(name: "checkInterval", value: 2 * 4 * 60 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
def updated() {
def cmds = []
if (!state.MSR) {
cmds = [
command(zwave.manufacturerSpecificV2.manufacturerSpecificGet()),
"delay 1200",
zwave.wakeUpV1.wakeUpNoMoreInformation().format()
} else if (!state.lastbat) {
cmds = []
} else {
cmds = [zwave.wakeUpV1.wakeUpNoMoreInformation().format()]
response(cmds)
def configure() {
commands([
zwave.sensorBinaryV2.sensorBinaryGet(sensorType: zwave.sensorBinaryV2.SENSOR_TYPE_DOOR_WINDOW),
], 1000)
def sensorValueEvent(value) {
if (value) {
createEvent(name: "contact", value: "open", descriptionText: "$device.displayName is open")
} else {
createEvent(name: "contact", value: "closed", descriptionText: "$device.displayName is closed")
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd)
sensorValueEvent(cmd.value)
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd)
def zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd)
def zwaveEvent(hubitat.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd)
sensorValueEvent(cmd.sensorValue)
def zwaveEvent(hubitat.zwave.commands.sensoralarmv1.SensorAlarmReport cmd)
sensorValueEvent(cmd.sensorState)
def zwaveEvent(hubitat.zwave.commands.notificationv3.NotificationReport cmd)
def result = []
if (cmd.notificationType == 0x06 && cmd.event == 0x16) {
result << sensorValueEvent(1)
} else if (cmd.notificationType == 0x06 && cmd.event == 0x17) {
result << sensorValueEvent(0)
} else if (cmd.notificationType == 0x07) {
if (cmd.v1AlarmType == 0x07) { // special case for nonstandard messages from Monoprice door/window sensors
result << sensorValueEvent(cmd.v1AlarmLevel)
} else if (cmd.event == 0x01 || cmd.event == 0x02) {
} else if (cmd.event == 0x03) {
result << createEvent(descriptionText: "$device.displayName covering was removed", isStateChange: true)
if(!state.MSR) result << response(command(zwave.manufacturerSpecificV2.manufacturerSpecificGet()))
} else if (cmd.event == 0x05 || cmd.event == 0x06) {
result << createEvent(descriptionText: "$device.displayName detected glass breakage", isStateChange: true)
} else if (cmd.event == 0x07) {
result << createEvent(name: "motion", value: "active", descriptionText:"$device.displayName detected motion")
} else if (cmd.notificationType) {
def text = "Notification $cmd.notificationType: event ${([cmd.event] + cmd.eventParameter).join(", ")}"
result << createEvent(name: "notification$cmd.notificationType", value: "$cmd.event", descriptionText: text, displayed: false)
} else {
def value = cmd.v1AlarmLevel == 255 ? "active" : cmd.v1AlarmLevel ?: "inactive"
result << createEvent(name: "alarm $cmd.v1AlarmType", value: value, displayed: false)
result
def zwaveEvent(hubitat.zwave.commands.wakeupv1.WakeUpNotification cmd)
def event = createEvent(descriptionText: "${device.displayName} woke up", isStateChange: false)
def cmds = []
if (!state.MSR) {
cmds << command(zwave.manufacturerSpecificV2.manufacturerSpecificGet())
cmds << "delay 1200"
if (device.currentValue("contact") == null) { // Incase our initial request didn't make it
cmds << command(zwave.sensorBinaryV2.sensorBinaryGet(sensorType: zwave.sensorBinaryV2.SENSOR_TYPE_DOOR_WINDOW))
if (!state.lastbat || now() - state.lastbat > 53*60*60*1000) {
cmds << command(zwave.batteryV1.batteryGet())
} else { // If we check the battery state we will send NoMoreInfo in the handler for BatteryReport so that we definitely get the report
cmds << zwave.wakeUpV1.wakeUpNoMoreInformation().format()
[event, response(cmds)]
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [ name: "battery", unit: "%" ]
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = "${device.displayName} has a low battery"
map.isStateChange = true
} else {
map.value = cmd.batteryLevel
state.lastbat = now()
[createEvent(map), response(zwave.wakeUpV1.wakeUpNoMoreInformation())]
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
def result = []
def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
log.debug "msr: $msr"
updateDataValue("MSR", msr)
retypeBasedOnMSR()
result << createEvent(descriptionText: "$device.displayName MSR: $msr", isStateChange: false)
if (msr == "011A-0601-0901") { // Enerwave motion doesn't always get the associationSet that the hub sends on join
result << response(zwave.associationV1.associationSet(groupingIdentifier:1, nodeId:zwaveHubNodeId))
} else if (!device.currentState("battery")) {
if (msr == "0086-0102-0059") {
result << response(zwave.securityV1.securityMessageEncapsulation().encapsulate(zwave.batteryV1.batteryGet()).format())
} else {
result << response(command(zwave.batteryV1.batteryGet()))
result
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand(commandClassVersions)
// log.debug "encapsulated: $encapsulatedCommand"
if (encapsulatedCommand) {
state.sec = 1
zwaveEvent(encapsulatedCommand)
def zwaveEvent(hubitat.zwave.commands.crc16encapv1.Crc16Encap cmd)
// def encapsulatedCommand = cmd.encapsulatedCommand(versions)
def version = commandClassVersions[cmd.commandClass as Integer]
def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
return zwaveEvent(encapsulatedCommand)
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
def result = null
log.debug "Command from endpoint ${cmd.sourceEndPoint}: ${encapsulatedCommand}"
result = zwaveEvent(encapsulatedCommand)
result
def zwaveEvent(hubitat.zwave.commands.multicmdv1.MultiCmdEncap cmd) {
log.debug "MultiCmd with $numberOfCommands inner commands"
cmd.encapsulatedCommands(commandClassVersions).collect { encapsulatedCommand ->
}.flatten()
def zwaveEvent(hubitat.zwave.Command cmd) {
createEvent(descriptionText: "$device.displayName: $cmd", displayed: false)
private command(hubitat.zwave.Command cmd) {
if (state.sec == 1) {
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
} else {
cmd.format()
private commands(commands, delay=200) {
delayBetween(commands.collect{ command(it) }, delay)
def retypeBasedOnMSR() {
switch (state.MSR) {
case "0086-0002-002D":
log.debug "Changing device type to Z-Wave Water Sensor"
setDeviceType("Z-Wave Water Sensor")
break
case "011F-0001-0001": // Schlage motion
case "014A-0001-0001": // Ecolink motion
case "014A-0004-0001": // Ecolink motion +
case "0060-0001-0002": // Everspring SP814
case "0060-0001-0003": // Everspring HSP02
case "011A-0601-0901": // Enerwave ZWN-BPC
log.debug "Changing device type to Z-Wave Motion Sensor"
setDeviceType("Z-Wave Motion Sensor")
break
case "013C-0002-000D": // Philio multi +
log.debug "Changing device type to 3-in-1 Multisensor Plus (SG)"
setDeviceType("3-in-1 Multisensor Plus (SG)")
break
case "0109-2001-0106": // Vision door/window
log.debug "Changing device type to Z-Wave Plus Door/Window Sensor"
setDeviceType("Z-Wave Plus Door/Window Sensor")
break
case "0109-2002-0205": // Vision Motion
log.debug "Changing device type to Z-Wave Plus Motion/Temp Sensor"
setDeviceType("Z-Wave Plus Motion/Temp Sensor")
break
