aaron
September 22, 2018, 9:58pm
1
Hello all,
I have this recessed door sensor from Monoprice .
The issue I am running into is that I am not getting any battery report back from the device using the Z-Wave Generic Contact Sensor or even a custom DH from this thread . See my dashboard below as I am not seeing anything for these two devices. Help??
patrick
September 22, 2018, 10:14pm
2
Does the device status page in the admin UI show anything for battery?
patrick
September 22, 2018, 10:43pm
4
How long has it been in place? If it doesn't show up in Current States, its not going to show up in Dashboard.
What driver is it set to? The screen shot just cut that off.
patrick
September 22, 2018, 11:24pm
6
And how long have you had it paired to Hubitat?
aaron
September 22, 2018, 11:25pm
7
For about 5 hours now. The issue is the Monoprice Door/Window Sensor (non-recessed) shows battery indication immediately. Same driver being used too.
patrick
September 22, 2018, 11:51pm
8
Well, it might not have checked in, I assume you have clicked configure? Try that and give it about 24 hours to check in its battery level.
aaron
September 23, 2018, 12:38am
9
I will report back tomorrow.
mag
September 23, 2018, 2:03am
10
Remove/reinstall the cover a couple of times.
Apparently, when woken up by the z-wave/intrusion button, the sensor stays up longer.
Do not forget to press the Configure button (immediately after removing the cover)
dwery
September 23, 2018, 2:06am
11
I have the same device, same driver, and I remember it reported quickly:
deviceType: 8226
zwaveSecurePairingComplete: true
inClusters: 0x5E,0x86,0x72,0x5A,0x85,0x59,0x73,0x80,0x71,0x84,0x7A,0x98
deviceId: 8705
MSR: 0109-2022-2201
manufacturer: 265
aaron
September 23, 2018, 12:45pm
12
Waiting seemed to do the trick. I did t have to remove cover but rather just hit configure and wait. Thank you for all the help everyone!
aaron
November 3, 2018, 5:45pm
13
That worked btw. Just forgot to respond.
