I'm having an odd problem with one of these. On wakening the logs (see below) show repeat activity -any thoughts why? Both are paired as Generic Z-wave sensors. Seems to function ok otherwise. Any thoughts on how to solve this?
dev:4982018-11-07 03:22:23.715 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.613 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.512 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.469 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.408 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.378 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.360 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.349 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.303 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.263 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.242 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.238 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.160 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.153 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.042 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:23.030 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.934 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.728 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.719 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.707 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.626 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.559 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.514 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.452 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.391 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.339 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.327 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.317 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.256 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.245 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.160 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:22.126 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.844 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.744 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.733 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.643 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.633 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.622 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.567 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.546 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.481 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.403 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.358 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:21.171 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.942 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.872 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.713 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.655 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.631 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.577 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.514 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.506 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.493 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.437 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.355 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.343 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.278 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.265 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.255 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.158 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:20.076 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:19.746 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:19.336 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:19.329 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:19.225 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:19.166 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:19.068 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.935 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.857 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.805 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.794 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.682 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.580 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.558 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.485 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.442 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.363 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.345 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.307 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.295 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.285 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.265 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.251 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.231 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.185 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.140 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.130 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:18.039 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.916 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.785 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.644 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.579 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.564 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.549 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.502 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.497 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.381 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.348 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.322 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.282 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.226 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.192 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.189 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:17.082 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.997 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.984 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.948 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.926 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.901 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.829 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.690 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.640 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.518 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.409 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.285 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.210 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.103 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.030 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.018 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:16.016 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.999 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.990 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.970 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.850 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.825 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.815 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.805 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.698 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.676 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.666 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.621 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.507 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.368 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.334 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.224 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.197 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.185 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.016 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:15.006 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.968 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.832 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.819 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.815 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.804 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.680 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.406 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.357 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.336 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.306 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.225 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.132 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.121 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:14.028 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.997 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.976 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.869 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.848 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.795 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.785 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.774 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.728 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.680 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.667 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.632 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.600 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.521 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.507 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.430 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.421 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.408 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.375 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.304 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.293 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.237 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.224 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.213 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.182 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.090 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.016 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:13.005 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.922 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.872 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.804 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.794 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.783 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.744 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.741 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.684 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.653 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.618 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.597 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.579 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.564 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.502 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.493 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.438 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.437 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.362 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.346 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.316 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.295 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.169 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.078 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:12.011 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.942 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.826 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.816 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.805 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.753 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.714 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.686 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.572 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.541 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.478 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.476 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.390 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.378 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.343 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.335 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.314 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.226 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.145 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:11.083 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:10.814 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:10.783 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:10.703 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:10.496 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:10.376 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:10.200 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:09.823 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:09.684 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:09.623 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:09.475 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:09.415 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:09.383 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:09.260 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:08.793 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:08.753 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:08.700 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:08.666 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:08.645 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:08.609 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:08.501 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:08.500 info Garage Inside Door Sensor battery is 100%
dev:4982018-11-07 03:22:07.755 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.653 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.575 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.498 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.433 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.431 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.365 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.356 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.286 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.262 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.214 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.179 debug Garage Inside Door Sensor woke up
dev:4982018-11-07 03:22:07.076 debug Garage Inside Door Sensor woke up
