Release 2.3.4 Available
Release 2.3.4.116 Available
Changes from 2.3.3.140
New Drivers
  • Eva Logik ZW31S Dimmer
  • Ring Glass Break Sensor
  • Sinope Multi-controller (MC3100ZB)
  • Sinope TH1123ZB-G2 Thermostat
  • frient Smart Siren
  • Sunricher MW Motion Sensor (SR-ZG9030A-MW, SR-ZG9031A-MW and SR-ZG9032A-MW)
New Compatible Devices
  • Jasco Flood/Freeze Multi-Sensor 54325 using Jasco Flood/Freeze Sensor driver
  • Enbrighten Smart Switch Toggle 58436 using Generic Z-Wave Plush Scene Switch driver
  • Enbrighten Smart Dimmer Toggle 59341 using Generic Z-Wave Plus Scene Dimmer driver
  • Enbrighten Smart Switch Toggle 59338 using Generic Z-Wave Plus Scene Switch driver
  • Enbrighten Paddle Switch 59337 using Generic Z-Wave Plush Scene Switch driver
  • Enbrighten Smart Switch 58443 using Generic Z-Wave Plus Scene Switch driver
  • Enbrighten Smart Receptacle 58449 using Generic Z-Wave Plus Outlet driver
  • Develco window sensor using frient Contact Sensor Pro
  • Develco Motion sensor 2 using frient Motion Sensor Pro
  • TP-Link Smart Home Sensor using Generic Zigbee Motion Sensor (no temp)
New Apps
  • HomeKit integration: Use your hub with Apple Home. Click [here] for more details.
  • Basic Button Controller: Similar to Button Controller but uses Basic Rule for each button-action.
New App Features
  • Rule 5.1:
    • Action to set the temperature sensors used by Thermostat Controller 2.0.
    • Variable offsets for Sunrise/Sunset Certain Time.
    • Allows direct Activation of Room Lights apps with forced or conditional Activation.
    • Added Track Event Switch for setting switches.
  • Notifier: Added %variable-name% as option for notifications.
  • Room Lights:
    • Added Hub Variables for color settings.
    • Added ability to set all color bulbs the same, both while doing settings and for random colors.
    • Added WiZ Scenes.
Bug Fixes
  • Rule 5.1:
    • Fixed Event Subscriptions when Mode is used both in Required Expression and Trigger, preventing double triggering.
    • Fixed deleting a Disabled Action to clear the disabled actions indication.
    • Fixed Triggers with annual dates throwing an error when initialized.
    • Fixed an error when DateTime variable deleted that is in use in a Condition.
    • Fixed error on sunrise/sunset offsets, for line 9635.
    • Fixed variable Fade in Set ColorTemperature actions.
    • Fixed error thrown for Required Expression with Between Two Times with sunrise/sunset.
    • Fixed erroneous display of buttons for ELSE and END-IF in certain action creation sequences.
    • Fixed running actions if Required Expression removed with option 'Cancel pending actions when Required Expression becomes false' still selected.
    • Fixed error for a bad date, e.g. 4/31.
    • Fixed error for variable in repeat for line 8851.
  • Hub Variables: Added Done button for Rename Variable name input, to prevent commitment of input name if Cancel button hit.
  • Room Lights:
    • Fixed Transition upon Activation to use the correct starting level for the transition; if the light is off, starting level will be 0.
    • Fixed cancelling Turn Off timers from motion stays inactive upon re-Activation.
    • Fixed broken selector for device type in table.
    • Fixed problem with removing a button selection.
  • Notifier: Fixed limitation of only one notification for a number of minutes.
  • Fixed possible Groups/Scenes freeze after clicking Done button.
  • Basic Rule: Fixed Set Thermostat Mode or Set Thermostat Fan Mode correctly.
  • Added a cooldown period between failed Zigbee restart and another attempt to avoid radio spamming.
  • "No updates" message on software update screen stays.
  • Added time limit on Z-Wave details page waiting for controller response.
  • Fixed issue with newer Sinope thermostats leaving network after initial join.
Platform Updates
  • Optional Z-Wave firmware 7.18.1 available.
Release 2.3.4.115 Available
Changes from 2.3.4.114
New App Features
  • Thermostat Controller 2.0:
    • Added variables for weight setting.
    • Added select temperature sensors per mode.
Bug Fixes
  • Room Lights: Fixed error if Activator Device created before selecting Devices to Automate.
  • Thermostat Scheduler 2.0: Fixed problems with Use Eco-Mode for Away.
  • Rule 5.1 / Button Rule 5.1:
    • Fixed error on Activate Room Lights app with no modes/periods selected.
    • Fixed error in the UI for some Custom Action actions.
  • Simple Automation Rule: Fixed error when paused/resumed by Rule Machine.
  • Virtual Thermostat: Fixed error when setTemperature() called with long decimal value.
  • Sonoff button controller: Fixed command error when command executed from device page.
  • Dashboards: Fixed time offset on variable time tile.
Platform Changes
  • HomeKit integration back end tweaks.
  • Added required capabilities to HomeKit app (turn on Show accessory classes and characteristics in Advanced section at the bottom to view).
Changes from 2.3.4.115
Bug Fixes
  • Room Lights: Fixed running transition.
  • frient Motion Sensor driver: Fixed typo in motion event name (moton).
    • Fixed setting temperatures correctly after returning from Away with Use EcoMode for Away.
    • Fixed clone of app to establish schedules.
  • Thermostat Controller 2.0: Fixed error on startup for some thermostats.
  • Basic Rule / Basic Button Rule: Fixed error for Set Volume of Music Player.
  • Dashboards: Fixed renaming a hub variable making tile to disappear.
  • Generic Zigbee Motion Sensor (no temp) driver: Fixed battery reporting for TP-Link motion sensor.
Platform Changes
  • HomeKit buttons are now only available as stateless button controllers. Multi-switch simulated button controller is no longer a part of HomeKit beta.
  • Additional device capabilities (traits) now include carbon dioxide, carbon monoxide, illuminance, temperature, and motion sensors.
Release 2.3.4.117 Available
Changes from 2.3.4.116
Bug Fixes
  • Fixed delayed device data save (under some circumstances).
  • Rule 5.1:
    • Fixed setting multiple Thermostat Schedulers in a single rule.
    • Fixed running long fade over time transitions.
  • Virtual Thermostat driver: Fixed temperature units in dashboard.
Platform Changes
  • New relaxed home hub pairing security option (HomeKit app - scroll to the bottom - Advanced) to use with 16.2 beta when accessories are not responding.
  • Added endpoints to force delete all scheduled jobs for app or device (/hub/advanced/deleteDeviceJobs/:deviceId and /hub/advanced/deleteAppJobs/:appId).
Release 2.3.4.118 Available
This version is pulled.
Release 2.3.4.119 Available
Changes from 2.3.4.117
Bug Fixes
  • Thermostat Scheduler 2.0: Fixed setting setpoints from variables when using time periods.
  • Thermostat Controller Device: Fixed temperature display units.
  • Zen thermostat: Fixed operating state value for multi stage systems.
  • Rule 5.1:
    • Fixed showing broken triggers, wait events or conditions when device removed.
    • Fixed error scheduling time and date trigger.
    • Fixed showing correct action labels after clone with device substitutions.
  • frient mini plug: Fixed wattage report.
  • Sinope TH1123ZB-G2 Thermostat: Fixed display backlight preferences.
Platform Changes
  • Added mode switch group option to HomeKit integration.
  • Added virtual presence driver with switch capability.
  • Various HomeKit tweaks.
Release 2.3.4.120 Available
Changes from 2.3.4.119
Bug Fixes
  • HomeKit battery characteristic and z-wave window shutter fix.
  • Mode Manager:
    • Fixed crash when modes in use by it are deleted in Settings / Modes.
    • Fixed crash when hitting - box to remove modes when none are selected.
  • Rule 5.1: Fixed action UI break with error for condition on Last Event Device.
  • Monoprice 6 Zone Audio Controller: Fix port preference setting not being applied.
Platform Changes
  • HomeKit "relaxed home hub pairing security" setting is enabled by default.
  • Updated networking app with better WiFi settings detection.
Release 2.3.4.122 Available
Changes from 2.3.4.120
Bug Fixes
Updated Drivers
  • Kasa drivers updated to the latest version.
Bug Fixes
  • Removed some HomeKit restrictions when relaxed security setting is on.
  • Rule 5.1: Fixed errors when Erase Expression hit while editing an IF-THEN action or IF-THEN action deleted.
Platform Changes
  • Tweaks to Settings - Network Setup page.
Release 2.3.4.123 Available
Changes from 2.3.4.122
Bug Fixes
  • Fixed Settings - Network Setup - WiFi name getting overridden.
  • Fixed having to click Register tile twice while registering a new hub.
  • Fixed HomeKit button not firing on "held" event.
  • Rule 5.1:
    • Fixed erroneously labeling Wait for Elapsed Time as Broken Wait Event.
    • Fixed mistakenly offering Mode Lighting apps for Pause/Resume rule.
Release 2.3.4.127 Available
Changes from 2.3.4.123
New Apps
  • webCoRE
Bug Fixes
  • HSM Custom Rule: Fixed creating event subscription for battery alerts.
  • Basic Rule / Basic Button Rule: Fixed problem with square brackets in rule name.
  • Fixed static IP assignment not sticking around.
  • HomeKit integration button fix.
  • Fixed Third Reality driver parsing error.
Platform Changes
  • Completely revamped Network setup page (C5+ hubs only).
Release 2.3.4.128 Available
Changes from 2.3.4.127
Updated Apps
  • webCoRE.
Bug Fixes
  • Faster loading for HomeKit app.
  • Mode Manager: Fixed errors on initial install and for variable times, and setting wrong mode on reboot or Update from app.
  • Thermostat Scheduler 2.0: Fixed error caused by logging.
Release 2.3.4.129 Available
Changes from 2.3.4.128
Updated Apps
  • webCoRE.
Bug Fixes
  • Mode Manager: Fixed erroneous setting of mode at midnight or restart to incorrect mode; added option about setting mode per time table on hub restart. Even if selected, will not set mode if current mode is a skipped mode (e.g. Away).
Platform Changes
  • Added separate options to restore from local or cloud backup when hub is new or has undergone a soft reset.
Release 2.3.4.130 Available
Changes from 2.3.4.129
Bug Fixes
  • Fixed HomeKit outlets handling of non-numeric power readings.
  • Mode Manager: Fixed error for variable times.
Platform Changes
  • Updated HTTP client dependency/version.
Release 2.3.4.132 Available
Changes from 2.3.4.130
App Update
  • WebCoRE updated to the latest available version.
Bug Fixes
  • Fixed IP address reporting when both Ethernet and wireless USB adapter are connected.
  • Ecobee Integration: Fixed Ecobee modes supported attributes to JSON.
  • Rule 5.1:
    • Fixed Wait for Event for Last Event Device to create the correct event subscription.
    • Fixed fatal error when attempting to schedule the condition Between Two Dates with variables where one of the dates is in the past for a Required Expression.
  • Hubitat Safety Monitor: Fixed closing water or gas valve after deselecting option to do so.
  • Room Lights: Fixed an error for line 2038 when renaming a time period.
  • Mode Manager: Fixed an error for time variables.
  • Simple Automation Rule: Fixed restriction for timed activation when Restrict Only Trigger selected.
Platform Changes
  • HomeKit integration restarts every hour.
  • Added functions to manipulate File Manager file from app/driver code:
    • void uploadHubFile(String fileName, byte[] bytes)
    • byte[] downloadHubFile(String fileName)
    • void deleteHubFile(String fileName)
Release 2.3.4.133 Available
Changes from 2.3.4.132
App Update
  • Button Rule 5.1: Added Local Variables.
Bug Fixes
  • Fixed ChromeCast integration TimeoutException.
  • Fixed Zigbee reset issue.
  • Rule 5.1 / Button Rule 5.1: Fixed display of imported Actions clipboard.
  • Room Lights:
    • Fixed stopping activation transition when turned off.
    • Fixed canceling pending off if mode adjust happens.
Release 2.3.4.134 Available
Changes from 2.3.4.133
Bug Fixes
  • Possibly fixed elevated/severe hub load experienced on previous 2.3.4 builds.
  • Fixed Rotel AVR driver attributes not updating.
  • Fixed unnecessary pings while on static IP address setting.
  • Fixed bug in Z-Wave migration from C7 to C7.
Release 2.3.4.138 Available
Changes from 2.3.4.134
This release includes a hub mesh update that makes it incompatible with earlier releases. Please update all hubs using hub mesh feature to keep it functional.
App Update
Bug Fixes
  • Added logging for hubs with high CPU usage.
  • Fixed "extra chatty" Wiz integration under some circumstances.
  • Fixed supportedFanModes JSON format in Ecobee Thermostat.
  • Generic Zigbee Moisture Sensor (no temp): Fix battery reporting/parsing error with linkind devices.
  • Button Controller 5.1:
    • Fixed copying local variables when button copied.
    • Fixed broken action Wait for Elapsed Time upon copy button.
  • Rule 5.1:
    • Fixed While Expression not testing expression for final iteration.
    • Fixed error for setting variable to minutes between a date with no time.
  • Thermostat Scheduler 2.0: Fixed failure to maintain Away settings when next time period changes.
Platform Changes
  • Changed backup/restore routines for better resiliency.
  • Made hourly HomeKit restart optional in the app's Advanced section (default = no restart).
  • Added file manager backup and restore for cloud backups (with 100Mb limit for now).
  • Added support for Wiz dim only light bulbs.
  • Removed UDP hub mesh option (it's TCP only now) and moved TCP hub mesh option to use port 8083 instead of 8082.
Release 2.3.4.139 Available
Changes from 2.3.4.138
New devices
  • frient Smart Button
  • frient Panic Button
  • Develco Panic Button using frient Panic Button
New compatible devices
  • Third Reality Smart Plug (3RSP02028BZ) using Generic Zigbee Outlet
  • Eria Zigbee RGBW Bulb (AD-RGBW3001) using Advanced Zigbee RGBW Bulb
  • Onesti Products AS Touch Prolock using Generic ZigBee Lock
New App Features
  • Motion and Mode Lighting Apps made available again.
Bug Fixes
  • Fixed high CPU usage/memory leak under certain conditions.
  • Zen Thermostat: refactor eventing for more reliable operation.
  • Lutron Shade, Lutron Shade (no level): fixed open and setPosition issues with Caséta systems.
  • zigbee.setHue command: added missing internal direction parameter.
  • Thermostat Sceduler 2.0: Fixed possible issue with not setting thermostat mode reliably.
Platform Changes
  • Added a way to enter SSID manually for WiFi connections.
Release 2.3.4.148 Available
Changes from 2.3.4.139
App Update
Driver Update
  • Kasa updated to the latest available version.
Platform Changes
  • Revised Backup and restore page.
Bug Fixes
  • Fixed devices grid view to avoid text overlap.
  • Thermostat Scheduler: Fixed setting fan mode in table when only two fan modes and using Modes for schedule.
  • Room Lights: Fixed error if a room in use has its name changed.
Download the Hubitat app
