Hub Update 1.1.3
Hubitat Elevation platform update 1.1.3 is now available:
Please note, the update process takes about a minute to download (depending on your Internet connection) and extract the hub update, and 1-2 minutes to perform the update after you click 'Update Hub'. We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 1.1.2:
Additions / Changes
  • Long running Apps and Drivers are limited to 120 seconds.
  • New drivers:
    • Fibaro wall plug
    • Ecolink Siren
    • Fibaro Single Switch 2
    • Fibaro Flood Sensor
  • New App for linking multiple hubs:
  • New Integration:
New Features
  • Button Controller: Added repeat actions
  • Hubitat Safety Monitor:
    • Added %device% and %value% for messages
    • Throw hsmSetArm events for other apps
    • Support keypads for arming/disarming
  • Hubitat Simple Lighting: Update to sunrise/sunset event scheduling NOTE: you must open every Simple Lighting rule that uses sunrise or sunset, and hit Done for them to work properly after this update.
  • Mode Lighting: Added option to adjust levels on mode change
  • Rule Machine:
    • Added thermostat heat setpoint and thermostat cool setpoint as conditions or trigger events
    • Added back every n seconds or minutes to Periodic
Bug Fixes
  • Fixed Nanoleaf Aurora next and previous effects, general speed improvements.
  • Fixed Life360 refresh driver not working.
  • Fixed virtual motion driver not respecting initial auto inactive settings.
  • Fixed Hue motion refresh and config errors.
  • Fixed Safari on Mac OSX App List: unable to click child apps or status page links
  • Fixed error messages in Alexa Skill logging and occasional unable to control device.
  • Fixed Hubitat Dashboard double confirmation on mobile devices and double sending of commands
  • Shutdown telnet connection properly on device removal.
  • Motion Lighting: Fixed β€œDon’t turn off if already on” for switches and bulbs
  • Rule Machine:
    • Fixed bug for Periodic with Triggered Rules
    • Fixed private, update and stop for This Rule
  • Hubitat Safety Monitor: Fixed external armHome/armAway conflict
Small hot fix pushed. Now version 1.1.3.112.
This fixes a bug that prevented HSM from being installed, and another one that prevented multiple Time of Day conditions in Rule Machine.
Another small hot fix pushed: Now version 1.1.3.113.
Bug fixes:
  • Rule Machine
    • Thermostat Heat Setpoint and Thermostat Cool Setpoint fixed
    • Bug with trigger comparing value fixed
    • Tripping of sensor during delayed entry won't fire an alert prematurely
    • Setting arm state from other app then hitting Done in HSM will not result in "disarmed" or UI break
Enhancement:
    • Custom rule now supports %device% and %value% in alert texts
    • Entry delays now apply to both Armed-Away and Armed-Home
We have pushed out another hot fix: Version 1.1.3.114.
Improvements:
  • Resolves reported Z-Wave issues that were introduced in releases 1.1.2 and 1.1.3.
    • UI improvements, including display of alert condition
    • Logging of events
    • Bug fix for Disarm All re-arming last arm state
  • Rule Machine
    • Bug fix for heating setpoint / cooling setpoint in triggers
We have pushed out another hot fix: Version 1.1.3.116.
Improvements:
  • Revert the change that limited long running Apps and Drivers to 120 seconds.
    • If you use a custom app that runs for a very long time, it could lead to hub slow downs, even to the point of actually causing the hub to shutdown.
  • Fix to Sharptools for error message when authorizing a large number of devices.
