Release 2.3.2.123 Available
Changes from 2.3.1.142
New Drivers
- Philips wall switch module [RDM001]
- Third Reality Smart Button (3RSB22BZ)
- Third Reality Switch (3RSS009Z)
- Sinope DM2550ZB Dimmer
- Lutron SeeTouch Keypad
- Lutron Component Switch (used by Keypad above)
- Philio PST02 driver
- Bond Bridge
- Generic Component Fan Light Control
- Generic Component Window Shade
New Compatible Devices
- EVVR smart relay using Generic Zigbee switch
- Third Reality door sensor (3RDS17BZ) Generic Zigbee Contact Sensor (no temp)
- Third Reality Smart Plug (3RSP019BZ) using Generic Zigbee Outlet
- Third Reality motion sensor (3RMS16BZ) using Generic Zigbee Motion Sensor (no temp)
- Third Reality Temp Humidity Sensor using Generic Zigbee Temperature/Humidity Sensor
- Third Reality Smart Blind (3RSB015BZ) using Generic Zigbee Shade
- Philips Hue indoor motion gen2 using Hue Motion Sensor
New Apps
- Room Lighting -- Comprehensive Lighting app. See this post .
- Bond Integration -- Includes Bond's push api for instant state updates with no polling.
Bug Fixes
- Rule 5.1:
- Fixed Custom RGB with Variable.
- Fixed validity check for Custom RGB value.
- Fixed UI break for
**Any Value** with Custom Attribute trigger.
- Fixed Paste Action for Simple Conditional actions and Wait for Events.
- Fixed variable change when used in Cron string getting rescheduled.
- Fixed All choice for presence triggers.
- Fixed choices for Power Source.
- Fixed Set Variable to sensor value with decimal values.
- Fixed variable comparison values disappearing when the selected variable is changed.
- Fix Boolean variable comparisons.
- Fixed Change ColorTemperature over time.
- Fixed UI bug where Required Expression conditions were offered for Simple Conditional pre-defined conditions.
- Fixed UI bug where “cond” showed as available condition for IF-THEN action.
- Fixed bug with Presence triggers where with multiple devices, it would trigger on the wrong value.
- Fixed bug with HSM Status in Required Expression not detecting a change of status.
- Fixed bug with Delay Per Mode that caused rule to stop running.
- Fixed Wait for Events with
all devices selected.
- Fixed import of Basic Rule with action of Control HSM.
- Fixed Wait for Events with Stays and Certain Time.
- Fixed Choose Button Per Mode.
- Hub Variables: Now allows dates with years from 1900 instead of rejecting 1943.
- All apps that offer time options: Fixed issues with sunrise/sunset settings for north of Arctic Circle.
- Mode Manager:
- Fixed problems with days of week settings.
- Fixed bug with earlier/later of two times.
- Button Rule- 5.0: Fixed refresh loop with Pause Rule action.
- Sonos Player: Fixed speak error when passed null as volume argument.
- Fixed Zooz ZSE32 digital button controls
- Fixed Zooz ZSE34 digital button controls
- Fixed aeon motor controller invalid use of swithcBinary
- Fixed missing position event in qubino shutter module
- Simple Automation Rule: Fixed bug with On/Off Optimization option.
Platform Changes
- Updated hub mesh (Settings - Hub mesh) and file manager (Settings - File manager) pages.
- Hub variables can now be shared and synchronized over hub mesh.
- Add device, version update, and file manager pages updated.
- Improvements to Zigbee and Z-Wave outbound serial command processing when multiple commands are sent to a large number of devices in one Rule or Automation (requires Z-Wave firmware update to 7.17.1) . Metering should no longer be required in properly functioning networks.
- Added Z-Wave Exclusion back to Z-Wave Details page.
- Added functions convertTemperatureToGenericColorName(int temp) and convertHueToGenericColorName(int hue, int sat) to get generic color names.
- Added an option to stop and restart firmware update.
- Added a "source hub" column for hub variables, visible only when there are hub mesh linked variables.
- Added multiple DNS servers (by default) for the static IP option in Network settings.
- Added atomicState.updateMapValue(Object stateKey, Object key, Object value) for apps. This method is a shortcut for getting a Map from atomicState, updating a value inside that map, and setting it back.
- Added a direct link to device's past logs to device detail page.
- Updated Network test page.
- Added offerAll option (true/false) for application inputs with type = enum.
Release 2.3.2.124 Available
Changes from 2.3.2.123
Bug Fixes
- Rule-5.0: Possibly fixed problem with Repeating showing in Rule name when no longer repeating.
- Room Lights:
- Fixed issues with Activation from Activation Device.
- Fixed problem with Activation Device being added to Google Home.
- Fixed problem with Motion Lighting import with disable switch, contact or variable.
- Fix for Bond shade control commands.
Platform
- Added hub name to the menu bottom in mobile view.
- Hub name in the right top corner (desktop view) and at the menu bottom (mobile view) are linked to hub details page.
Release 2.3.2.125 Available
Changes from 2.3.2.124
New App Features
- Room Lights:
- Added Grace Period for turning off.
- Added groupState attribute to Activation Devices.
Bug Fixes
- Room Lights:
- Fixed initialization NPE error thrown.
- Fixed error on import of Group that didn’t create Activation Device.
- Fixed error with buttons as Means to Turn Off, and automatic creation of button Means to Turn Off from button as Means to Activate.
- Changed default device type for hybrid switch/button from Button to Switch.
- Fixed 6-speed fan control in Bond Integration.
Release 2.3.2.126 Available
Changes from 2.3.2.125
New App Features
- Room Lights:
- Added options for variable level and color temperature in Devices to Automate Table.
- Added options for variable illuminance for Means and Conditions.
- Added options for variable time for Means, Disable and Re-Enable.
- Added use of fractional minutes for Stays Inactive/Closed times, e.g., 0.5 minutes.
Bug Fixes
- Rule 5.1:
- Fixed pasting IF-THEN conditions.
- Fixed string value input for Custom Attribute comparison (leading space bug).
- Room Lights:
- Fixed bug with mode as Means to Turn Off.
- Fixed bugs with Stay Minutes Per Mode.
- Fixed bug with Conditions to Limit Activation when Preset Off selected.
- Fixed Days of Week and Between Two Times as Conditions to Limit Turning Off.
- Mode Manager
- Fixed "before sunrise handler not firing" issue.
Platform Changes
- Version update notes are now a link to the community instead of embedded text.
Release 2.3.2.127 Available
Changes from 2.3.2.126
New Driver Features
- Lutron Thermostat: Added
schedule and sensor attributes.
- Added presetColor and presetColorTemperature to Inovelli and LIFX bulb drivers.
New App Features
- Room Lights: Added complete set of Disable/Enable Events available in Motion Lighting.
Bug Fixes
- Room Lights:
- Fixed bugs with import of Motion Lighting with disable/enable settings.
- Fixed errors when illuminance reported as decimal value.
- Fixed red X from remaining for devices in table that report their settings.
- Fixed bond fan speeds > 6.
- Fixed an issue with Z-Wave NVM cloud backups.
- Rule 5.1: Fixed bug preventing setting thermostat setpoint to zero.
** IMPORTANT: If you use cloud backups, update and create a new manual backup.
Release 2.3.2.128 Available
Changes from 2.3.2.127
Bug Fixes
- Mode Manager: Fixed bug with variable time.
- Room Lights:
- Fixed ‘mod’ error bug.
- Fixed bug with Custom Attribute.
- Lutron Telnet: Allow actions for schedule and sensors.
- Fixed Shelly WiFi dimmer setLevel(0) error.
Platform Changes
- Added java.time.temporal.TemporalAdjusters to allowed classes.
Release 2.3.2.130 Available
Changes from 2.3.2.128
Bug Fixes
- Room Lights:
- Fixed race condition with Transitions being stopped.
- Fixed bug with Grace Period re-Activation.
- Fixed bug with Activator Device commanded Off with Conditions to Limit Off or Off Disabled.
- Fixed bug with Conditions for Variable is False.
- Fixed so that mode adjustment uses transition-to-on when selected.
- Fixed Turn On If Partially Activated option.
- Rule 5.1:
- Fixed error thrown with Paste Conditional action.
- Allow decimal values for variable offsets.
- Hub Variables: Fixed UI bug with paused apps for In Use By.
- Hubitat Safety Monitor: Fixed bug when Arming Alerts page clicked on.
- Fix Sengled contact sensor battery reporting when using Generic Zigbee Contact Sensor (no temp) driver.
Platform Changes
- Improved scrolling implementation on apps and devices pages.
- Added app string setting hubitatQueryString with parsed query string.
Release 2.3.2.131 Available
Changes from 2.3.2.130
New App Features
- Maker API: Added room to device data.
Bug Fixes
- Room Lights:
- Fixed mode adjustment.
- Fixed Conditions to Limit Turning Off for Between Two Times and Days of Week.
- Fixed Preset Off issues.
- Rule 5.1: Fixed setting thermostat setpoints to zero degrees.
Platform Changes
Release 2.3.2.132 Available
Changes from 2.3.2.131
New App Features
- Room Lights: Added Switches Turn On for Means to Turn Off.
- Rule 5.1: Added range test as additional comparison.
Bug Fixes
- Room Lights:
- Changed Off Transitions to start with current device values instead of Activation settings.
- Fixed failure to follow Conditions to Limit Turning Off for Preset Off.
- Fixed bug with Zigbee Group Messaging where non-grouped devices would not Turn Off.
- Mode Manager: Fixed earlier/later of two times (again).
Platform Changes
Release 2.3.2.133 Available
Changes from 2.3.2.132
Bug Fixes
- Fixed app scrolling to bottom when app is opened.
- Fixed Third Reality battery reporting on contact and motion (no temp) drivers.
- Room Lights:
- Fixed display of on/off for stop Transition switch.
- Fixed bug on Mode name changed, or mode deleted.
- Fixed Disable Off at specific time.
- Rule 5.1: Fixed display of triggers and conditions.
Release 2.3.2.134 Available
Changes from 2.3.2.133
Bug Fixes
- Room Lights:
- Fixed bug with 'Do Turn Off Even If' option interaction with Conditions to Limit Turning Off.
- Fixed device cleanup for removed Means to Turn Off, and bug with same for Contact Closes.
- Fixed removal of Zigbee Group information upon app removal, or turning off Zigbee Group Messaging.
- Rule 5.1: Fixed missing range value input for Custom Attribute.
Release 2.3.2.135 Available
Changes from 2.3.2.134
New Driver Feature
- Lutron Dimmer: Added Preference option for GE QS device monitoring reports.
New App Features
- Room Lights: Added ‘Lock unlocks’ as Means to Activate.
- Rule 5.1: Added setting %device% to variable name of variable trigger.
Bug Fixes
- Room Lights:
- Fixed bug with Switch Turns Off being reset to initial setting.
- Fixed Devices to Automate table rendering on Safari.
- Fixed initialization error when there are no Means to Turn Off.
- Rule 5.1: Fixed issues with Change Color Temperature over time.
- Several apps: Fixed display of Between Two Times for 24 hour clock display.
- Maker API: Fixed missing room name for allDevices.
- Fix configuration error in Sinope DM2550 dimmer driver.
- Add white as a color in Yeelight and virtual RGB and RGBW drivers.
Release 2.3.2.136 Available
Changes from 2.3.2.135
Bug Fixes
- Fix for enum dropdowns appearing to be populated with nulls.
- Room Lights:
- Fixed Restore to prior state before Activation when Turned Off.
- Fixed table rendering for iOS devices.
- Fixed import from Motion Lighting for Adjust on Mode Change.
- Rule 5.1:
- Fixed Custom Color hue or saturation values of zero.
- Fixed HSM Custom Rule cancel alert trigger/wait.
- Fixed bug with presence sensor in Required Expression.
- Fixed rendering problems with Local Variables.
Release 2.3.2.138 Available
Changes from 2.3.2.136
Bug Fixes
- Hubitat Safety Monitor: Fixed extra Disarm Event from UI buttons.
- Room Lights: Fixed Activate Only Activating Switch.
- Rule 5.1:
- Fixed Presence Stays trigger.
- Fixed DateTime variable changed trigger.
- Fixed Custom Attribute triggers. Note: Rules with Custom Attribute triggers for changed, increased or decreased may not trigger or may mistakenly trigger for the first event of that attribute after this update. Such triggers will work properly after the first such event.
Release 2.3.2.139 Available
Changes from 2.3.2.138
Bug Fixes
- Room Lights:
- Fixed Activate Only Activating Switch to only work for switches on, allowing other means to still Activate all devices.
- Fixed bug for error on line 2203 when turning device on/off from table.
- Fixed possible deadlock with delayed Activation/Turn Off.
- Rule 5.1:
- Fixed comparisons of Custom Attribute states.
- Fixed triggers/Required Expression for HSM Status.
- Fixed timeout in %device%.
- Hubitat Safety Monitor: Fixed problem with Text Notifications stuck on wrong alert type.
Release 2.3.2.140 Available
Changes from 2.3.2.139
Bug Fixes
- Room Lights: Fixed Line 2033 errors associated with Indicator usage.
- Rule 5.1:
- Fixed error thrown on scheduling in the past.
- Fixed Stays trigger preventing other triggers during stays period.
- Fixed triggers/waits for thermostat setpoints.
Release 2.3.2.141 Available
Changes from 2.3.2.140
Bug Fixes
- Rule 5.1: Fixed bug with “mode” Custom Attribute changed.
- Increased max upload file size to 10Mb.
