Hubitat Elevation Platform update 2.2.3 is now available:
*** C-7 Users: See below for "Important Please Read" ***
Please note, the process takes about a minute to download (depending on your Internet connection) and extract the hub update, and 1-2 minutes to perform the update after you click 'Update Hub'. We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 2.2.2:
Drivers and Devices
- New drivers:
- Fibaro Smart Implant
- HomeSeer Fan Controller FC200+
- Inovelli Fan/Light Switch LZW-36
- Inovelli 4-in-1 Sensor
- Ring Alarm Hardwired Retrofit Kit (C-7 Required)
- Generic Component Drivers
- Generic Component Fan Control
- Generic Component Humidity Sensor
- Generic Component Voltage Sensor
- New compatible devices
- EVA LOGIK Outdoor Plug (ZW96) using EVA LOGIK Smart Plug
- Samotech MS104Z using Generic Zigbee Switch
- Heiman Z-Wave smoke detector using Generic Z-Wave smoke detector.
- New driver features
- Inovelli Multi-White Bulb (LZW-41): Performance updates when using firmware version 2.27+.
- Added firmware version report to Alfred Lock driver
New App Features
- Amazon Echo Skill App
- Added support for garage door controllers.
- Added support for fan controllers.
- Added support for shade controllers..
- Rule-4.0: Allows selection of format for %time% and %now% (one option per rule).
Bug Fixes
- Fixed a bug in the Aeotec water sensor 6 driver that was preventing saving of configurations when the device was on battery.
- Fixed multiple drivers incorrect formatting of firmware version numbers.
- Button Controller 3.1: Fixed bug with Adjust Dimmer.
- Generic Z-Wave Smoke/CO Detector: Change event value from test to tested.
- Zooz Double Switch: Removed extra logging.
- Rule-4.0: Fixed multiple device trigger bug.
- August Pro Lock: Added C7/S2 support.
- Fixed multiple driver compatibility issues with S2/S0.
- Leviton VRSC4 Z-Wave Controller: Fixed Null error with child dimmers on startup.
- Fixed groovy.lang.MissingMethodException for SupervisionGet on Zooz drivers.
- C-7: Fixed Z-Wave repair behavior with sleepy devices.
- C-7: Fixed Z-Wave inclusion issues.
- C-7: Fixed occasional repair lock-up.
Platform Changes
- Performance and stability enhancements.
- C-7: Added update mechanism for Z-Wave radio firmware.
- C-7: Updated Z-Wave settings page to include node routes / speed and highest security grant.
- Added universal Z-Wave security encapsulation commands, automatically detects correct security encapsulation requirements of none, S0, S2_UNAUTHENTICATED, S2_AUTHENTICATED or S2_ACCESS_CONTROL. (example)
- Signatures:
- String zwaveSecureEncap(String cmd)
- String zwaveSecureEncap(hubitat.zwave.Command cmd)
- Change Zigbee EZSP_CONFIG_PAN_ID_CONFLICT_REPORT_THRESHOLD from 1 to 10
*** Important Please Read ***
C-7 hubs are receiving major Z-Wave updates with this release and require some user intervention to complete the process.
Part 1 of the update will happen automatically during startup. There may be an automatic reboot during first startup on 2.2.3.
Part 2 requires user intervention. Under settings and z-wave details you will see a new button "Firmware Update". This will start the radio firmware update.
Please note that the firmware update takes roughly 10 minutes to complete, please let this process complete fully before attempting to do anything. If you run into trouble please reach out on the community, we will be watching for people posting problems.
Once this is complete it is recommended to go through and remove any failed nodes from previous inclusion issues.
Hot Fix Release 2.2.3.119 Available -- All C-7 Users Should Update
This release fixes an issue pertaining to Soft Reset where after performing such a reset, the hub would not boot correctly.
All C-7 users should update to 2.2.3.119. This release is very minimal, and addresses just this single issue. There are no other changes from 2.2.3.118. Please also see this post: WARNING: Do not reset C-7 Hub until after updating to version 2.2.3.119
Please note: We strongly recommend the following: DO NOT USE FULL RESET. If you have a problem that makes you think you need to do a Full Reset, please contact support before doing it. This is rarely the correct thing to do. We intend to remove this option from the Diagnostic Tool in the near future.
Release 2.2.3.132 Available
This hot fix Includes:
Bug Fixes
- August Pro Lock: Add unknown event when lock is jammed.
- Update keyWay Z-Wave Lock for improved reliability on C-7 hubs.
- Totally re-engineered C-7 Z-Wave hub to device communication.
- Totally re-engineered C-7 Z-Wave repair.
- Fixed several C-7 potential network management lock ups.
- Fixed several C-7 Zooz driver fingerprints when using S2.
- More under the hood performance enhancements.
- Fixed an issue with sunrise.
- Fixed a bug in Rule-4.0 with sensor changed triggers.
- Dashboard bug fix for a rare issue.
- Database cleanup now removes all device states older than one week.
- Added ability to check versions of underlying Z-Wave components.
- Fix for hubs that didn't update one of the z-wave components.
- Corrected verbiage on backup runtime.
- Fix for hub getting stuck at 75%, 80%, or 85% during boot time.
- Fix for a rare scenario when database schema version is not detected.
- A diagnostic URL to see current database schema version.
New Features:
- Added C-7 single node Z-Wave repair.
- Added new calculated times for apps.
- todaysSunrise
- todaysSunset
- tomorrowsSunrise
- tomorrowsSunset
- Rule-4.0:
- Provides cut/paste method for editing actions.
Release 2.2.3.135 Available
This hot fix includes:
New Drivers
Bug Fixes
- Fixed multiple C-7 Z-Wave inclusion and exclusion issues.
- Fixed some issues dealing with C-7 ghost nodes.
- Fixed aeotec gen 5 recessed sensor driver bug.
- Fixed Zooz Double Switch refresh issue with using "smart bulb mode"
- Fixed some potential sources of "name not found" db errors.
- Fixed fan off on Inovelli Fan/Light Switch.
- Fixed Zooz Multi-Relay supervision on multi-channel encapsulation.
- Mode Manager: Fixed null mode display and mode as object bug.
- NTP time validation after hub boot.
- Device state performance improvements.
Release 2.2.3.142 Available
Bug Fixes
- Flush DNS cache to fix NTP and cloud connections.
- Fix for sunrise/sunset calculation.
- Remove database cleanup from startup process.
- C-7: Fixed rare boot loop during component update.
- C-7: Prevent IDLE return on FAILED result for z-wave firmware update.
- C-7: Prevent bogus nodes from being created.
- C-7: Fixed invalid status reports on Z-Wave nodes.
- C-7: Fixed invalid route report. (The mysterious A5 route)
- C-7: Added node pinging before repair to check for reachability.
- C-7: Fixed rare discovery issue with some devices.
- C-7: Fixed an issue with some command classes not reaching drivers.
Release 2.2.3.144 Available
Bug Fixes
- C-7: Fixed lockup issues on inclusion timeouts.
Release 2.2.3.145 Available
Bug Fixes
- C-7: Re-engineered Z-Wave repair (again)
- C-7: Added management keepalive to fix some existing and many yet undiscovered bugs.
Release 2.2.3.148 Available
Bug Fixes
- Runs Z-Wave cleanup overnight only, once a day instead of hourly with database cleanup.
- Adds new /hub/cleanupRadio URI for on-demand Z-Wave cleanup.
- Includes fix for one page apps not picking up mode restriction option.
