Note!
You're better off using @dandanache's newer IKEA drivers in preference to these, unless you require only the Zigbee2MQTT element.
Introduction
Following my take on a driver for the Tradfri Shortcut Button I've cobbled more together to support the Symfonisk Sound Remote and the Tradfri Signal Repeater.
These are combination drivers, so can be used with directly paired IKEA devices or those connected via my Zigbee2MQTT Routing Driver. I recommend Zigbee2MQTT as it solves all of the battery related issues seen with these devices.
Installation
Search for the keyword "IKEA" on Hubitat Package Manager and you should see "IKEA Drivers from BirdsLikeWires". Requires HPM v1.8.7 or later. Or install manually from the link below.
- IKEA Symfonisk Sound Remote E1744 - Import URL: RAW
- IKEA Tradfri Shortcut Button E1812 - Import URL: RAW
- IKEA Tradfri Signal Repeater E1746 - Import URL: RAW
There are other excellent drivers around for these devices, but as I rely on device health status detection I always try to roll my own when I find the time.
This driver reports the remote as a 3 button device; press, clockwise and anticlockwise. Single, double and triple tap is supported on the button using official methods for the first two, plus push (single), hold (double) and release (triple) to catch all three modes in a manner that can be used for automation.
Rotation start, progress and stop are reported as button 2 (clockwise) and button 3 (anticlockwise), again with push, hold and release reporting. Level change and cumulative / subtractive level in percentage is also supported.
I've also just added on/off switch support so the device can be used with the Mirror app.
Supports push, hold, release and battery monitoring, with the device reporting in hourly. If you've updated the device to firmware 2.3.080 then it should also support double-press.
Probably the best and most reliable Tradfri product on Hubitat!
More of a monitor than a driver as it just checks in every 10 minutes for device health. I rely on these as I find them to be the best simple repeaters at an affordable price in a useful package.
