Release 2.3.9 Available
Release 2.3.9.135 Available
Changes from 2.3.8.140
Platform Changes
  • Z-Wave Long Range support for C-8 and C-8 PRO hubs. (To include using Long Range, you must use SmartStart)
  • Brand new Dashboards page that looks similar to Rooms, Devices, and Apps.
  • New local Dashboards 2.0 with updated look/feel and drag/drop design functionality.
  • Basic support for IntelliJ Idea based development using a simple hub code upload plugin.
  • Improved restore confirmation dialog.
New Apps
New Devices
  • Shelly Z-Wave Plug
  • Minoston MP31ZP Smart Plug
  • MCO Home Touch Panel Switch (510 Series)
  • MCO Home Dimmer Switch (MH-DT511)
  • Swidget Z-Wave Dimmer
  • Swidget Z-Wave Switch
  • Swidget Z-Wave Switch Multisensor
  • Swidget Z-Wave Dimmer Multisensor
  • MCO Home Occupancy Sensor
  • MCO Home Air Quality Sensor (A2-ZW)
  • MCO Home Micro Switch (MH-S220)
  • MCO Home IR Thermostat (IR2900-ZW)
New Compatible Devices
  • MCO Home TPS (MH-S511) using MCO Home Touch Panel Switch driver
  • MCO Home TPS (MH-S512) using MCO Home Touch Panel Switch driver
  • MCO Home TPS (MH-S513) using MCO Home Touch Panel Switch driver
  • MCO Home Occupancy Sensor (OS11) using MCO Home Occupancy Sensor Driver
  • MCO Home Occupancy Sensor (OS12) using MCO Home Occupancy Sensor Driver
  • MCO Home Dry Contact Micro Switch (MH-DS221) using MCO Home Micro Switch driver
  • Linkind Smart Dimmer Switch using Generic Matter Dimmer
  • ThirdReality Garage Door Tilt Sensor using Generic Zigbee Contact Sensor (no temp)
Bug Fixes
  • Fix configure() bug in Generic Z-wave Plus Thermostat Driver
  • Fix supportedThermostatModes invalid format in Heatit Z-TRM3 driver.
  • Improvements to supervision encapsulation for Z-Wave S2 devices, in built-in drivers, preventing false duplicate detection/drops on outgoing packets.
  • Fixed Advanced RGB(W) driver(s) refresh issues (hopefully all of them).
  • Rule 5.1:
    • Fixed %date% for Stays triggers.
    • Fixed Time Since Event for decimal event values.
  • Fixed sendMsg method in Onkyo AVR driver.
  • Fixed Z-Wave device fingerprint matching, specifically when using mfr, prod and deviceId style fingerprints.
Release 2.3.9.136 Available
Changes from 2.3.9.135
Platform Changes
  • Added support for clock and weather tiles (for built-in OpenWeather driver) to Easy dashboards. [check this post for more details ]
  • Added support for arbitrary fan/thermostat modes to Fan and Thermostat tiles on Easy dashboards.
Bug Fixes
  • Removed HTML from tooltips on Logs page and Easy dashboards.
  • Fixed the issue with HSM tile not updating status.
Release 2.3.9.141 Available
Changes from 2.3.9.136
Platform Changes
  • Added cloud support for Easy dashboards.
  • Added drag and drop support for local Hubitat dashboards.
Bug Fixes
  • Fixed runaway background z-wave exclusion when user clicks Cancel in remove device dialog.
  • Removed full device list in dashboard configuration dialog to free up screen space.
  • Basic Rule: Fixed Only Between Two Times Restriction.
Release 2.3.9.142 Available
Changes from 2.3.9.141
Bug Fixes
  • Fixed dashboard background and scrolling (bug introduced in .141).
  • Easy dashboard fan icon now grays out when the fan is off.
  • Easy dashboard home link now follows Navigation to - Dashboards page check in dashboard options.
  • Rule 5.1: Fixed cancel rule actions for delay.
Release 2.3.9.143 Available
Changes from 2.3.9.142
Bug Fixes
  • Fixed broken drag/drop on Hubitat dashboards with non-fixed cell width/height.
  • Easy dashboard thermostat icon/background now reflect on/off status for the device.
  • Fixed the cause of "Layout was Null" error message for Hubitat dashboards.
Release 2.3.9.147 Available
Changes from 2.3.9.143
Platform Changes
  • Added Easy dashboards to legacy dashboard menu page (used by mobile app, too).
  • Added drag and drop support to cloud Hubitat dashboards.
  • Added a Back button to Easy dashboards if there is any browse history available (e.g. in mobile app).
New Devices
  • Jasco PRO Water Leak Sensor
  • Jasco PRO Plugin Smart Switch
  • Third Reality Vibration Sensor
  • NodOn 1 relay module (SIN-4-1-20) using Generic Zigbee Switch
  • NodOn dual relay (SIN-4-2-20) using Generic Zigbee Multi-Endpoint Switch
  • NodOn metering relay (SIN-4-1-21) using Generic Zigbee Outlet
  • IKEA Ormanas LED Strip using Advanced Zigbee RGBW Bulb
  • IKEA TRADFRI bulb E27 WW globe 806lm using Advanced Zigbee bulb
  • IKEA TRADFRI bulb GU10 WW 345lm8 using Advanced Zigbee bulb
  • IKEA TRADFRI bulb E14 WS candle 470lm using Advanced Zigbee CT bulb
  • frient Zigbee Range Extender REXZB-111 using kea TRADFRI Signal Repeater
Bug Fixes
  • Rule 5.1: Fixed Time Since Event with variable value.
  • Basic Rule: Fixed issue with Restrictions.
  • Fixed optional tile toggle mix-up when creating Easy dashboard.
Release 2.3.9.150 Available
Changes from 2.3.9.147
Platform Changes
  • Improved drag/drop on Hubitat dashboards.
  • Added individual button naming to Easy dashboard button tiles.
  • Added separator and media player tiles to Easy dashboards.
  • Added an option to pre-populate Easy dashboard with all of the room's devices.
[check out this post for more details on the new Easy Dashboard features]
New Devices
  • TouchWand WallWand
  • TouchWand GP9000
Bug Fixes
  • Got rid of "empty" fan and thermostat modes on Easy dashboard.
  • Synchornized cloud Easy dashboard to match local Easy dashboard.
Release 2.3.9.153 Available
Changes from 2.3.9.150
Platform Changes
  • Added PIN security to Easy dashboard and Hubitat Safety monitor tile.
  • Added calendar tile to Easy dashboard.
  • Added background color and icon customization to Easy dashboard.
Check out this post for more details
Bug Fixes
  • Fixed some drag and drop issues with Hubitat dashboard.
  • Room Lights: Fixed Physical selection for Conditions and Disable/Enable.
Release 2.3.9.154 Available
Changes from 2.3.9.153
Bug Fixes
  • Fixed wrong buttons showing on the Add Device page.
  • Fixed an issue preventing some hubs from creating backups compatible with Z-Wave LR.
  • Basic Rule: Fixed error thrown with multiple thermostats selected.
New Driver Features
  • Added 3-Way configuration options to Zooz Zen32/Zen72/Zen71
Release 2.3.9.157 Available
Changes from 2.3.9.154
Platform Changes
  • Updated dashboard menu with new look/feel and a search feature.
  • Improved navigation between dashboards setup page, dashboards menu page, and dashboards themselves.
New Devices
  • Ryse Z-Wave SmartShade
Bug Fixes
  • Fixed wrong button number being pushed from Easy Dashboard.
Release 2.3.9.158 Available
Changes from 2.3.9.157
Platform Changes
  • Improved user apps compile time.
Bug Fixes
  • Fixed Hubitat dashboard red background showing through on older browsers.
  • Fixed easy dashboard sending commands to device while user moves slider.
  • Possibly fixed device current state not updating immediately after event is raised.
Release 2.3.9.160 Available
Changes from 2.3.9.158
Platform Changes
  • Hub's endpoints are now accessible using HTTP on port 8080 from 127.0.0.1 (hub itself), even if HTTPS only option is checked.
  • Added endpoints to limit access to the hub to a set of IP addresses. Pressing and holding Network reset button restores access.
    • /hub/advanced/limitAccess?addresses=1.2.3.4,1.2.3.5 - (use comma separated list of IPs to set value and limit access, starting with next reboot)
    • /hub/advanced/limitAccess?addresses= - (empty value restores access, starting with next reboot)
    • /hub/advanced/getLimitedAccessAddresses - (reads current list)
  • Added one click/tap open/close for window shades to Easy dashboards.
Bug Fixes
  • Fixed remote admin issue while using HTTPS only UI option.
