Release 2.3.9.180 Available
Changes from 2.3.9.177
Bug Fixes
- Dashboard menu detects cloud/local based on host (and not app reported origin).
- Modified Bonjour/mDNS library to ignore requests coming from the hub itself - may help with HomeKit not responding issue.
- Fixed a rare deadlock bug resulting in a locked up hub.
- Fixed an issue resulting in unnecessary, ongoing DNS servers update while on DHCP with custom DNS servers defined.
Platform Changes
- Added a reboot endpoint:
/management/reboot?token=TOKEN
where token is obtained from another endpoint, described here .
- Added a set static IP endpoint:
/management/setStaticIp?token=TOKEN&address=192.168.4.204&netmask=255.255.255.0&gateway=192.168.4.1&nameserver=8.8.8.8
where parameters are self explanatory and are identical to the values in the Network Setup static IP section. This endpoint does not perform a reboot on its own.
Release 2.3.9.181 Available
Changes from 2.3.9.180
Platform Changes
- Reverted increased DNS record TTL.
- Added some local endpoints for the mobile app to use when mobile device and hub are on the same network.
Release 2.3.9.184 Available
Changes from 2.3.9.181
Platform Changes
- Added seamless device replacement option to Add device workflow.
- Added hourly cloud force reconnects.
- Modified backup/restore page during onboarding to hide irrelevant elements like backup frequency.
- Added Bonjour option to Network setup to turn mDNS restarts off.
Bug Fixes
- Fixed Z-Wave repair cancel UI bug (main page kept showing progress).
- Fixed Easy dashboards' handling of heat only thermostat devices.
- Likely fixed a rare deadlock bug resulting in a locked up hub.
Release 2.3.9.192 Available
Changes from 2.3.9.184
New App Features
- Google Home Integration updated, support added for the following device types:
Fans, Locks, Garage door controllers, Blinds, Valves, Temperature, Contact and Humidity sensors.
- Rule 5.1:
- Added 'Run Action' option for Actions table UI
- Added URL Decode for String variables.
- Added composite temp/humidity and contact/temperature and log debugging preference to Google Home Integration.
- HSM Rule: Added repeat notifications until cancel.
New Compatible Devices
- Sonof Motion (SNZB-06P) using Sunricher MW Motion Sensor driver
- Third Reality Smart Blind (3RSB015BZ) using Generic Zigbee Shade driver
- Third Reality Temp Humidity Sensor (3RTHS24BZ) using Generic Zigbee * Temperature/Humidity Sensor driver
- Third Reality Smart Plugs (3RSP019BZ, 3RSP02028BZ and 3RSPE01044BZ) using Generic Zigbee Outlet driver
- Aqara Smart Hub M3 using Generic Matter Bridge driver
- Aqara Smart Plug
- Aqara Presence Sensor FP1E
- Aqara LED Strip T1
- Aqara Door and Window Sensor
- Aqara Vibration Sensor
- Aqara Temperature / Humidity Sensor
- Hue Bridge using Generic Matter Bridge driver
New Devices
- Aqara LED Strip T1 (Zigbee)
- Aqara Smart Plug (Zigbee)
- Aqara Zigbee Double Rocker Switch
- Aqara Zigbee Double Relay Switch
- Aqara Zigbee Curtain Driver E1
- Aqara Zigbee Weather Sensor (WSDCGQ11LM)
- Aqara Zigbee Contact Sensor (MCCGQ11LM)
- Strips Guard (Z-Wave 700/800 LR)
- Strips Drip (Z-Wave 700/800 LR)
- Aqara Motion and Light Sensor P2 (Matter/Thread)
- Generic Matter Bridge
- Hue Contact Sensor (Zigbee)
- Virtual Shade (no level)
Platform Changes
- Added
matter.cleanSubscribe(), for replacing subscriptions, and matter.getMatterEndpoints().
- Added a delay in cloud, Matter and HomeKit startups until network is available.
- Updated Zigbee device inclusion to better handle problematic Zigbee 3.0 devices that wouldn't previously join the network, or became unresponsive after inclusion.
- Faster hub onboarding.
- Reloading add device page stops ongoing inclusion/exclusion for Zigbee and Z-Wave.
Bug Fixes
- Fixed a bug in Z-Wave ConfigurationPropertiesReport V3+ when using 4-byte maxValue > Java Integer Max Value.
- Fixed a bug in Matter Events preventing events from reaching the driver.
- Fixed a bug that occasionally caused a new Z-Wave device to get stuck during initialization.
- Fix for S2 Z-Wave devices firmware update failing in Device Firmware Updater app.
- Fixed numberOfButtons attribute not being populated in Frient button devices.
Release 2.3.9.193 Available
Changes from 2.3.9.192
Bug Fixed
- Fixed the issue causing cloud and some network services to become unavailable on C3/C4 hubs.
- Added more guidance to device inclusion pages.
Release 2.3.9.196 Available
Changes from 2.3.9.193
New Devices
- Aqara Zigbee Mini Switch (WXKG11LM)
- Aqara Presence Sensor FP1E (FP1E)
- Aqara Zigbee Water Sensor (SJCGQ11LM)
- Aqara Vibration Sensor (DJT11LM)
Bug Fixes
- Made some cloud reconnect tweaks.
- Removed devices with children from suggested device replacement in Add device workflow.
- Fixed mishandled HSM rule alerts in EZ dashboards.
- Rule 5.1: Fixed IF-THEN-ELSE failures.
- Fixed an issue with Generic Matter Bridge driver preventing humidity updates.
- Updated Zooz Double Switch driver to work with Zooz ZEN30 800LR model
- Fixed issue with Sengled Smart Window and Door Sensor G2 (E2D-G73) not reporting contact status.
- Added new Zigbee alert if weak Zigbee channel is discovered.
- Added a Replace device check to prevent replacement for the devices with children.
- Added a check to force kill Matter process if graceful shutdown fails.
Release 2.3.9.197 Available
Changes from 2.3.9.196
New Devices
- Human Presence Sensor (ZG-204ZM) Zigbee
- Third Reality Soil Moisture Sensor (3RSM0147Z) Zigbee
- Third Reality Zigbee RGBW Bulb (3RCB01057Z)
- Third Reality Zigbee Smart Watering Kit (3RWK0148Z)
Bug Fixes
- Added missing supportedFanSpeeds attribute for Hampton Bay Zigbee Fan Controller and Generic Component Fan Control.
- Fixed battery reporting for Third Reality Switch (3RSS009Z).
- Fixed Aeotec Nano Shutter driver reporting position and windowShade attributes reversed from standards.
- Fixed "Set Level" error in Generic Matter RGBW driver and fixed ignored 0 transition times
Platform Changes
- Added error handling for devices with large "data" values.
Release 2.3.9.200 Available
Changes from 2.3.9.197
Platform Changes
- Added logic to ping all Zigbee devices on hub startup (C8 and C8 Pro hubs only).
- Sped up Zigbee restarts when Zigbee error is encountered.
- Added compatible devices link to the home page.
- Modified soft reset to use a pre-built database for faster startup.
Bug Fixes
- Rule 5.1: Fixed Start/Stop Z-Wave Polling UI and dimmers selection.
- Fixed issue with setting HomeKit thermostat heating point while in auto mode.
- Added Zigbee hub code to respond to active endpoint and match descriptor requests coming from devices.
Release 2.3.9.201 Available
Changes from 2.3.9.200
Platform Changes
- Minor wording revisions for onboarding screens.
