Release 2.3.7 Available
Release 2.3.7.138 Available
Changes from 2.3.6.144
New Integration
  • Added Matter controller functionality allowing pairing of Matter devices to Hubitat Elevation Model C-8 (other models not supported).
New Devices
  • SmartWings Matter Shade (Matter/Thread)
  • Eve Motion (Matter/Thread)
  • Aqara Door and Window Sensor P2 (Matter/Thread)
  • Google Nest Matter Thermostat (Matter/WiFi)
  • Third Reality Matter Multi-Function Night Light (Matter/WiFi)
  • Tapo Smart matter Outdoor Dual Plug (Matter/WiFi)
  • Generic Matter Multi-Endpoint Switch
  • Generic Matter Outlet
  • Generic Matter RGBW Light
  • Generic Matter CT Light
  • Generic Matter Contact Sensor
  • Generic Matter Switch
  • Generic Matter Dimmer
  • Generic Matter Motion Sensor
  • TRADFRI Remote Control
New Compatible Devices
  • Eve Energy (Matter/Thread) using Generic Matter Outlet driver
  • Eve Door / Window (Matter/Thread) using Generic Matter Contact Sensor driver
  • Onvis Smart Plug (Matter/Thread) using Generic Matter Outlet driver
  • Meross Smart Plug Mini (Matter/WiFi) using Generic Matter Outlet driver
  • Linkind Matter Smart Bulb (Matter/WiFi) using Generic Matter RGBW Light
  • Linkind Matter Smart Plug using Generic Matter Outlet Driver
  • TP-Link Tapo Matter Smart Plug (Matter/WiFi) using Generic Matter Outlet driver
  • TP-Link Tapo Smart Wi-Fi Light Switch (Tapo S505) (Matter/WiFi) using Generic Matter Switch
  • TP-Link Tapo Smart Light Bulb (Matter/WiFi) using Generic Matter RGBW Light
  • Mujoy Smart Bulb (Matter/Thread) using Generic Matter RGBW Light
  • Nanoleaf Essentials Matter Smart Bulb (Matter/Thread) using Generic Matter RGBW Light
  • Nanoleaf Essentials Matter Lightstrip (Matter/Thread) using Generic Matter RGBW Light
  • Nanoleaf Matter Smart Holiday String Lights (Matter/WiFi) using Generic Matter RGBW Light
  • Orein Matter Smart Bulb (Matter/WiFi) using Generic Matter RGBW Light
  • Govee RGBIC LED Strip Lights M1 (Matter/WiFI) using Generic Matter RGBW Light
  • Kasa Matter Smart Switch (Matter/WiFi) using Generic Matter Switch driver
  • Kasa Matter Smart Dimmer Switch (Matter/WiFi) using Generic Matter Dimmer driver
  • Kasa Matter Smart Plug (Matter/WiFi) using Generic Matter Outlet driver
  • Sengled Smart Light Bulb (Matter/WiFi) using Generic Matter RGBW Light driver
  • Consciot Matter Smart Light Bulb (Matter/WiFi) using Generic Matter RGBW Light driver
  • Vuytret Smart Plug (Matter/WiFi) using Generic Matter Outlet driver
  • NEO Matter Smart Plug (Matter/WiFi) using Generic Matter Outlet driver
  • Wiz Color Smart Bulb (Matter/WiFi) using Generic Matter RGBW Light driver
  • Wiz Tunable White Smart Bulb (Matter/WiFi) using Generic Matter CT Light driver
  • Uascent inwall matter micro (V-MT-S01) using Generic Matter Switch
  • Uascent inwall matter micro (V-MT-S02 ) using Generic Matter Multi-Endpoint Switch
  • Yale Assure Lock 2 YRD420 Z-Wave Lock using Generic Z-Wave Lock driver
  • Yale Assure Lock 2 YRD450 Z-Wave Lock using Generic Z-Wave Lock driver
  • frient smart cable 2 (SMRZB-153) using generic zigbee outlet driver
  • frient Smart Plug Mini 2 (SPLZB-141) using generic zigbee outlet driver
  • Smart DIN Relay 2 (SMRZB-342) using generic zigbee outlet driver
  • Kaadas Smart Lock (KA201) using Generic Z-Wave Lock driver
  • Kaadas Smart Lock (KA211) using Generic Z-Wave Lock driver
  • Kaadas Smart Lock (KA200) using Generic Z-Wave Lock driver
New Driver Features
  • Added configuration parameters to Jasco Flood Freeze Humidity Sensor
Platform Changes
  • Updated Zigbee and Z-Wave details UI to match Matter details UI.
  • Added hub events for scheduler failure.
  • Simplified adding virtual devices in the Add Device page.
  • Dashboard: Added 'armingHome' and 'armingNight' to the color template for HSM
  • Added ability to add/remove device to/from dashboard directly from device details page.
  • Added a feature to dynamically update app HTML when device, app, hub, or location event occurs. This feature is incorporated into Hub Variables page and Room Lights device tables.
  • Updated Backup/Restore page with new look and feel.
  • Modified Migrate page UI and restore selection dialog to match Backup/Restore page.
  • Added individual component restore status to the Migrate page.
  • Added hub event for cloud backup results (both successful and failed).
  • Added prominent placement for failed cloud backups.
  • Hid Reset buttons on Zigbee, Z-Wave, and Matter info pages.
  • Modified time control for the apps to use Safari built-in functionality when available.
  • Changed default hub mesh full refresh frequency to 1 hour (from 2 minutes).
Bug Fixes
  • Rule 5.1:
    • Fixed multiple triggers with increased, decreased, increased by over, decreased by over on a single device that would fail on all but the first such trigger.
    • Fixed bug with variable *changed* triggers.
    • Fixed allowed string length for setting Hub Variable to 1024 and error thrown for strings over 256 length.
    • Fixed Variables used in Action Delays not being correctly updated when Hub Variable is renamed.
  • Hub Variables:
    • Fixed error thrown for Hub Meshed variables.
    • Fixed bug caused by use of colon in variable name, disallowing such use, and an error thrown for certain rename-variable situations.
  • Hubitat Safety Monitor: Fixed event name for Gas Detector.
  • Room Lights: Fixed an error thrown if there is an Activator Device but no selected Devices to Automate when Activate Lights Options is selected.
Release 2.3.7.139 Available
Changes from 2.3.7.138
Bug Fixes
  • Creating a migration backup without Hub Protect will ignore previously set cloud backup password since there is no way to reset it in the UI.
  • Rule 5.1:
    • Fixed Variables used in Between Two Dates not setting In-Use in Hub Variables.
    • Fixed missing event for Time Since Event with many intervening events of different attribute.
  • Room Lights:
    • Fixed app UI hanging if tab closed during edit of Time Period name.
    • Fixed illuminance variable not setting In-Use in Hub Variables
Release 2.3.7.140 Available
Changes from 2.3.7.139
Bug Fixes
  • Fixed the issue with apps showing old device name after device has been renamed.
  • If zigbee or z-wave steps of cloud backup fail, the backup is correctly marked as having no zigbee or z-wave component.
  • Rule 5.1:
    • Fixed error thrown for a type mismatch error (line 3056) in certain cases of copying actions and pasting them into existing rule.
    • Fixed evaluating Required Expression when Private Boolean set manually in UI.
Platform Changes
  • Added Zigbee/Z-Wave indicator columns to cloud backup lists on backup/restore and migrate pages.
Release 2.3.7.141 Available
Changes from 2.3.7.140
Bug Fixes
  • HomeKit Integration: Fixed Room Lights Activator device to show up as RGBW bulb in HomeKit if it supports RGBW features.
App Updates
  • Rule 5.1: added cloudBackup and lowMemory location event triggers.
Driver Updates
  • Added LightEffects capability to Wiz RGBW lights.
Platform Changes
  • Added an option of 10Mbps Ethernet speed for connection troubleshooting (Settings - Network setup - Ethernet speed).
Release 2.3.7.142 Available
Changes from 2.3.7.141
Bug Fixes
  • Fixed reported "Zigbee not responding after firmware update" scenario.
Release 2.3.7.143 Available
Changes from 2.3.7.142
Bug Fixes
  • Fixed reported "Zigbee not responding after firmware update" scenario - to be confirmed.
Release 2.3.7.144 Available
Changes from 2.3.7.143
App Update
  • Rule 5.1: Added optional offset (in minutes) to Variable time for Between Two Times condition.
Platform Changes
  • Added HomeKit and Hub mesh status icons to the Status column in Devices and Rooms pages.
Release 2.3.7.145 Available
Changes from 2.3.7.144
Bug Fixes
  • Possible fix for delayed hub web UI response.
Platform Changes
  • Updated hub details page for faster response.
  • Added purge logs option to hub reboot confirmation dialog.
Release 2.3.7.146 Available
Changes from 2.3.7.145
Bug Fixes
  • Revised backup/restore page to create migration backups for C8 pro on C8 hubs.
  • Migration backups list now includes latest backups created on Hub Protect enabled hubs registered on the same account as the current hub.
