Something similar is happening with me but my lights turn off instead. In my case there is a location event that correlates with the light turning off(at sunset when my mode changes to Evening) and can be replicated over and over again by opening HSM. I opened another thread and Pm'd app and event details to you.
@bravenel, should I just go ahead and recreate my HSM or would you like any further info from me first?
Bruce, hopefully you have reviewed the HSM App details I pm’d to you and found some clues to this issue. I went ahead and deleted the entire app and recreated the HSM settings. Unfortunately it did not resolve the issue.
Having my Den Lights (where my family spend most of the evening) shut off on its own is really killing the WAF. Please let me know what info I can provide because I REALLY don’t want to move my water sensors back to ST.
A further update. My Den Lights actually turn off with any Mode change. I tested all today and it doesn’t matter what mode I change to. So at this point, changing modes or just viewing the HSM config page turn my lights off.
Will do…but since we don’t have speakers yet and my phone is not always with my in the family area, it means that I might as well delete the water detection altogether for now. I might have to remove my ST hub from it’s metal enclosure and reattach the water sensors there as this is my most important alert till I replace my a.c. handler.
Both of my Sengled Element Plus bulbs using Zigbee White Color Temperature Bulb driver had completely stopped responding after update to 705. Reset and re-paired and responsiveness was restored, but Hubitat UI very slow and occasionally unresponsive. From Device Details page, either no response on first or second click of ON/OFF buttons or very slow (several seconds). Same slow response time with a Tråfri bulb using Generic Zigbee Bulb driver.
Reverted to 704 and everything fine. Updated to 705 again and the same issues returned. Again reverted to 704 and working fine.
I did but that doesn’t remove the text alert field…just makes it an invalid option. It essentially does the same thing as removing but seems far from ideal. I already rebuilt the HSM app but wanted to share my findings so they can fix down the road.
You can just clear the phone number and click the << App List link. It will be unconfigured. To remove the SMS configuration entirely, clear all fields, turn off all options and then click the << App List link
Is there an easy place to see your current HSM Status,other than location logs? I feel like I’m missing something. Also, would be nice to see HSM status available as a tile in the next dashboard update. I feel
