Hubitat Elevation Software Update 1.0.4.706 is now available.
Please note, the process takes about a minute to download (depending on your Internet connection) and extract the hub update, and from one to two minutes to perform the update after you click Update.
We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 1.0.3.705
Bug Fixes:
Fix for daylight savings time scheduling
Fix for Single Sign On Page
Fix for Zigbee Temperature reporting
Fix for Zone Motion false motion zone types
Fix for Rule Machine Rule truth as a condition
Fix for HSM sending SMS
Fix for Motion Lighting to allow Alexa override for setting level
Fix for Safari Mac OS time input
Additions / Changes:
Check for Updates, Update and download will now be one action
Added driver hex utilities
Added multichannel encapsulate command for Z-Wave
Added Wake On Lan (WOL) support
Added Switch Color Class Support
Added New Fingerprints for better Device matching
Added support to SmartThings Integration to allow modes to be sent from ST to set Hubitat modes
Added dim level override to Motion Lighting
Added Alternative Lutron Setup Method -see Alternative Lutron Integration Setup Method
New Hue Bridge Integration
New Humidity Sensor Driver
