Yes that is the one! I tried pairing it yesterday but gave up pretty quickly. I was under the house pairing a few remaining, far reach devices, which that is one of. It turns on my crawl lights based on motion. I moved it under there once I got a large order of Iris motion sensors that look nicer.
Did you do anything special to pair? I have had a hellofa time with ST Zigbee devices pairing on Hubitat lately.
ok thanks, will try again this weekend. I was under the house, just under the Hubitat hub so surprised it didnāt pair easily. I gave up pretty quickly because I thought I remembered someone saying the old v1ās used some proprietary Zigbee and wouldnāt work. Will try again, thanks! That will leave the keypad, which I honestly donāt use that often and more use it for temperature reporting.
Eventually the locks will come over. I had to move my ST hub to keep them working since I only have 2 zwave devices left.
ok having the same problem suddenly I can not see and pair any Zigbee devices
Where is the polling timer? I donāt see it
I have tried changing channels, rebooting and disabling and deleteling all apps
@bravenel Appreciate everyoneās patience. I have updated a fourth time to 705 and Iām pleased to report that this time, Iām not experiencing any slow UI behavior and my Sengled Element Plus bulbs did not stop responding. All seems fine so far.
@mike.maxwell Not sure if you think it would be beneficial to have a specific driver for these bulbs, as SmartThings does. These bulbs are unique in their capability to be dimmed by a conventional dimmer, but I have no clue if that makes their Zigbee characteristics unique among color tunable bulbs. They do seem to be behaving more erratically with Hubitat using the Zigbee White Color Temperature Bulb driver than they had on ST using the specific Sengled Element Plus DTH.
I am experiencing the same issue as OP here. I'm trying to move a SmartThings Water Leak Sensor (2016 model) and I cannot get Hubitat to discover it. I've done the following many, many times:
Done a factory reset on the device and confirmed with the blue LED flashing that it is discoverable.
Placed it within a few feet of Hubitat
Unplugged and yanked batteries from SmartThings to avoid interference.
Disable/update then enable/update Zigbee radio in Hubitat.
Tested having SmartThings discover it (always happens immediately)
I only have one of these things, but I had to go through the same process that [ritchierich] described.
I turned off Zigbee and then back on only after reseting the actual sensor twice. Then immediately after turning Zigbee back on and starting pairing mode, it came up.
When attempting before the pairing, I had the sensor sitting on top of the hub itself so well within range. The channel did not change and was always set to 18 before turning the radio off and back on.
I didn't have this problem with my other Zigbee devices when moving to Hubitat. I just find it interesting that it doesn't appear to be due to a change in channel. Still not sure if it's a Hubitat bug or a ST bug.
