Hub Update 1.0.3.705
Hubitat Elevation Software Update 1.0.3.705 is now available.
Please note, the process takes about a minute to download (depending on your Internet connection) and extract the hub update, and from one to two minutes to perform the update after you click Update.
We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 1.0.3.704
Bug Fixes:
  • Simple Lighting: Sunrise/Sunset scheduling
  • Hubitat™ Safety Monitor: Alert lights being turned off by opening app or changing mode
If you were using Sunrise or Sunset events in Simple Lighting, after you install this update you should go into your Simple Lighting rule and hit Done. This will repair the scheduling for the rule.
