I've been using LightwaveRF devices integrated into ST via a Ras Pi to the Lightwave (LW) hub.
I've got it working with Hubitat Elevation.
I didn't the process but have just been a grateful recipient.
Here is the ST thread which shows you how to set it all up, followed by the DH code which I have amended to work with HE.
Dimmer.
* Lightwave Lights
* Copyright 2015 Adam Clark
* For any information or help please contact ad@mclark.co
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
import java.security.MessageDigest
preferences {
input("serverIP", "text", title: "Server IP Address", description: "IP Address of the Server")
input("lightwaveIP", "text", title: "Lightwave IP Address", description: "IP Address of the Lightwave Hub")
input("roomID", "text", title: "Room ID", description: "The room id")
input("deviceID", "text", title: "Device ID", description: "The device id")
metadata {
definition (name: "Lightwave Dimmer Switch", namespace: "smartthings-users", author: "Adam Clark") {
capability "Switch"
capability "Switch Level"
capability "Refresh"
command "register"
simulator {}
tiles(scale: 2) {
multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#79b821", nextState:"off"
attributeState "off", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"On"
tileAttribute ("device.level", key: "SLIDER_CONTROL") {
attributeState "level", action:"switch level.setLevel", range:"(5..100)"
standardTile("register", "device.status", inactiveLabel:false, decoration:"flat",height: 2, width: 2) {
state "default", label:"Register", icon:"http://www.mocet.com/pic/link-icon.png", action:"register"
main "switch"
details(["switch", "level","register"])
// parse events into attributes
log.debug "Parsing '${description}'"
// TODO: handle 'switch' attribute
// handle commands
def on() {
sendEvent(name: "switch", value: 'on')
apiGet('/on', 0)
def off() {
sendEvent(name: "switch", value: 'off')
apiGet('/off', 0)
def setLevel(value) {
if (value == 0) {
sendEvent(name: "level", value: '0')
apiGet('/off', 0)
} else {
sendEvent(name: "level", value: value)
apiGet('/on', value)
def register() {
apiGet('/register', 0)
private apiGet(path, level) {
log.debug settings.serverIP + ':8000'
def httpRequest = [
method: 'GET',
path: path,
headers: [
HOST: settings.serverIP + ':8000',
Accept: "*/*"
query: [
ip: settings.lightwaveIP,
room: settings.roomID,
device: settings.deviceID,
level: level
log.debug httpRequest.query
return new hubitat.device.HubAction(httpRequest)
Outlet.
* Lightwave Lights
preferences {
metadata {
definition (name: "Lightwave Switch", namespace: "smartthings-users", author: "Adam Clark") {
capability "Switch"
command "register"
simulator {}
tiles(scale: 2) {
multiAttributeTile(name:"switch", type: "outlet", width: 6, height: 4, canChangeIcon: true){
attributeState "level", action:"switch level.setLevel", range:"(100)"
main "switch"
details(["switch","register"])
// handle commands
def on() {
apiGet('/on', 0)
def off() {
apiGet('/off', 0)
if (value == 0) {
apiGet('/off', 0)
} else {
def register() {
def httpRequest = [
method: 'GET',
path: path,
headers: [
Accept: "*/*"
query: [
level: level
