Share Your Data Logging and Visualization Implementations
I wanted to make a topic where folks could share their different means of logging historical values and displaying those values in meaningful ways.
The post below made me want to help gather this information for others but I didn't want to derail the original post as it was intended for support:
InfluxDB with Grafana seems to be popular, but perhaps problematic and maybe not that user friendly.
On the other hub I've used Initial State, WebCoRE has it's own fuel streams that are a bit limited, and I believe GroveStreams set out to do this too. I even had a Google Sheets logger for a short while that was functional.
If you have a moment please share what fulfills your needs as maybe it will help others visualize what happens at their abode when they're gone, which is what I would like to better see.
On a personal note I am interested in local storage of data. Storage is expensive, let alone storage running on a cloud platform, but I'm still open to cloud solutions.
Useful LInks:
I've used this early and for a long time to get an idea of how my automations were working...
Looks useful. I'll take a look.
Thanks!
@ogiewon You asked if there was a thread about visualization - here's one!
I just installed Influx and Grafana locally in ~15 minutes. The code I've found here (@potts.mike may have a more recent version, but it was his version I started from) didn't quite work, but needed only some syntactic corrections. I can share that, in the public repository, and start versioning it, if that'd be desirable.
Thanks. I actually have had InfluxDB and Grafana up and running on a Raspberry Pi for a few weeks now. Seems to be working well so far.
Here’s a simple dashboard I created to monitor my HVAC system in my attic (heat pump). I have an ESP8266 running HubDuino to monitor freon line temps, inlet and outlet air temps, etc...
That's my goal too, HVAC monitoring.
A friend mentioned InfluxDB and other Database programs might ruin a SD card over a short amount of time.
Have you heard of that? Are you avoiding that by storing data to a NAS or something?
It is certainly possible to wear out a flash drive over time. I haven't done much investigation into the subject yet. Before I build out my InfluxDB, I plan on figuring out where I would like to host it. I may end up running it on my Windows 10 "Home Server" which has 24TB of storage. That would probably be the best place to run it from a performance and reliability standpoint.
Sounds like it would be best there.
That's impressive.
Excellent! I got it up too, in short order. The smart app I’ve seen published had errors in it though and I’m wondering if there’s a more canonical source. Or I can publish a working copy. Do you know?
Good point about the SD card. I’ll keep Influx on something with a spinning disk.
Honestly, I think this is one of those Apps that needs a Hubitat Caretaker. It would be great if you could host the Hubitat version of this code on your GitHub repository. I did the same thing as you and modified the one posted by @potts.mike in the other thread.
Here is the code I am using, if you want to DIFF it against yours to see if we both found and fixed things...
 *  Copyright David Lomas (codersaur)
 *  Name: InfluxDB Logger
 *  Date: 2017-04-03
 *  Version: 1.11
 *  Source: https://github.com/codersaur/SmartThings/tree/master/smartapps/influxdb-logger
 *  Author: David Lomas (codersaur)
 *  Description: A SmartApp to log SmartThings device states to an InfluxDB database.
 *  For full information, including installation instructions, exmples, and version history, see:
 *   https://github.com/codersaur/SmartThings/tree/master/smartapps/influxdb-logger
 *  IMPORTANT - To enable the resolution of groupNames (i.e. room names), you must manually insert the group IDs
 *   into the getGroupName() command code at the end of this file.
 *  License:
 *   Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *   in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *   Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *   on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *   for the specific language governing permissions and limitations under the License.
definition(
    namespace: "codersaur",
    author: "David Lomas (codersaur)",
    description: "Log SmartThings device states to InfluxDB",
    category: "My Apps",
    iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
    iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
    iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
preferences {
    section("General:") {
        //input "prefDebugMode", "bool", title: "Enable debug logging?", defaultValue: true, displayDuringSetup: true
        input (
        	title: "IDE Live Logging Level:\nMessages with this level and higher will be logged to the IDE.",
        	type: "enum",
        	options: [
        	    "0" : "None",
        	    "1" : "Error",
        	    "2" : "Warning",
        	    "3" : "Info",
        	    "4" : "Debug",
        	    "5" : "Trace"
        	defaultValue: "3",
            displayDuringSetup: true,
        	required: false
    section ("InfluxDB Database:") {
        input "prefDatabaseHost", "text", title: "Host", defaultValue: "10.0.1.13", required: true
        input "prefDatabasePort", "text", title: "Port", defaultValue: "8086", required: true
        input "prefDatabaseName", "text", title: "Database Name", defaultValue: "SmartThings", required: true
        input "prefDatabaseUser", "text", title: "Username", required: false
        input "prefDatabasePass", "text", title: "Password", required: false
    section("Polling:") {
        input "prefSoftPollingInterval", "number", title:"Soft-Polling interval (minutes)", defaultValue: 10, required: true
    section("System Monitoring:") {
        input "prefLogModeEvents", "bool", title:"Log Mode Events?", defaultValue: true, required: true
        input "prefLogHubProperties", "bool", title:"Log Hub Properties?", defaultValue: true, required: true
        input "prefLogLocationProperties", "bool", title:"Log Location Properties?", defaultValue: true, required: true
    section("Devices To Monitor:") {
        input "accelerometers", "capability.accelerationSensor", title: "Accelerometers", multiple: true, required: false
        input "alarms", "capability.alarm", title: "Alarms", multiple: true, required: false
        input "batteries", "capability.battery", title: "Batteries", multiple: true, required: false
        input "beacons", "capability.beacon", title: "Beacons", multiple: true, required: false
        input "buttons", "capability.button", title: "Buttons", multiple: true, required: false
        input "cos", "capability.carbonMonoxideDetector", title: "Carbon Monoxide Detectors", multiple: true, required: false
        input "co2s", "capability.carbonDioxideMeasurement", title: "Carbon Dioxide Detectors", multiple: true, required: false
        input "colors", "capability.colorControl", title: "Color Controllers", multiple: true, required: false
        input "consumables", "capability.consumable", title: "Consumables", multiple: true, required: false
        input "contacts", "capability.contactSensor", title: "Contact Sensors", multiple: true, required: false
        input "doorsControllers", "capability.doorControl", title: "Door Controllers", multiple: true, required: false
        input "energyMeters", "capability.energyMeter", title: "Energy Meters", multiple: true, required: false
        input "humidities", "capability.relativeHumidityMeasurement", title: "Humidity Meters", multiple: true, required: false
        input "illuminances", "capability.illuminanceMeasurement", title: "Illuminance Meters", multiple: true, required: false
        input "locks", "capability.lock", title: "Locks", multiple: true, required: false
        input "motions", "capability.motionSensor", title: "Motion Sensors", multiple: true, required: false
        input "musicPlayers", "capability.musicPlayer", title: "Music Players", multiple: true, required: false
        input "peds", "capability.stepSensor", title: "Pedometers", multiple: true, required: false
        input "phMeters", "capability.pHMeasurement", title: "pH Meters", multiple: true, required: false
        input "powerMeters", "capability.powerMeter", title: "Power Meters", multiple: true, required: false
        input "presences", "capability.presenceSensor", title: "Presence Sensors", multiple: true, required: false
        input "pressures", "capability.sensor", title: "Pressure Sensors", multiple: true, required: false
        input "shockSensors", "capability.shockSensor", title: "Shock Sensors", multiple: true, required: false
        input "signalStrengthMeters", "capability.signalStrength", title: "Signal Strength Meters", multiple: true, required: false
        input "sleepSensors", "capability.sleepSensor", title: "Sleep Sensors", multiple: true, required: false
        input "smokeDetectors", "capability.smokeDetector", title: "Smoke Detectors", multiple: true, required: false
        input "soundSensors", "capability.soundSensor", title: "Sound Sensors", multiple: true, required: false
		input "spls", "capability.soundPressureLevel", title: "Sound Pressure Level Sensors", multiple: true, required: false
		input "switches", "capability.switch", title: "Switches", multiple: true, required: false
        input "switchLevels", "capability.switchLevel", title: "Switch Levels", multiple: true, required: false
        input "tamperAlerts", "capability.tamperAlert", title: "Tamper Alerts", multiple: true, required: false
        input "temperatures", "capability.temperatureMeasurement", title: "Temperature Sensors", multiple: true, required: false
        input "thermostats", "capability.thermostat", title: "Thermostats", multiple: true, required: false
        input "threeAxis", "capability.threeAxis", title: "Three-axis (Orientation) Sensors", multiple: true, required: false
        input "touchs", "capability.touchSensor", title: "Touch Sensors", multiple: true, required: false
        input "uvs", "capability.ultravioletIndex", title: "UV Sensors", multiple: true, required: false
        input "valves", "capability.valve", title: "Valves", multiple: true, required: false
        input "volts", "capability.voltageMeasurement", title: "Voltage Meters", multiple: true, required: false
        input "waterSensors", "capability.waterSensor", title: "Water Sensors", multiple: true, required: false
        input "windowShades", "capability.windowShade", title: "Window Shades", multiple: true, required: false
 *  SmartThings System Commands:
 *  installed()
 *  Runs when the app is first installed.
def installed() {
    state.installedAt = now()
    state.loggingLevelIDE = 5
    log.debug "${app.label}: Installed with settings: ${settings}"
 *  uninstalled()
 *  Runs when the app is uninstalled.
def uninstalled() {
    logger("uninstalled()","trace")
 *  updated()
 *  Runs when app settings are changed.
 *  Updates device.state with input values and other hard-coded values.
 *  Builds state.deviceAttributes which describes the attributes that will be monitored for each device collection
 *  (used by manageSubscriptions() and softPoll()).
 *  Refreshes scheduling and subscriptions.
def updated() {
    logger("updated()","trace")
    // Update internal state:
    state.loggingLevelIDE = (settings.configLoggingLevelIDE) ? settings.configLoggingLevelIDE.toInteger() : 3
    // Database config:
    state.databaseHost = settings.prefDatabaseHost
    state.databasePort = settings.prefDatabasePort
    state.databaseName = settings.prefDatabaseName
    state.databaseUser = settings.prefDatabaseUser
    state.databasePass = settings.prefDatabasePass
    state.path = "/write?db=${state.databaseName}"
    state.headers = [:]
    state.headers.put("HOST", "${state.databaseHost}:${state.databasePort}")
    //state.headers.put("Content-Type", "application/x-www-form-urlencoded")
    if (state.databaseUser && state.databasePass) {
        state.headers.put("Authorization", encodeCredentialsBasic(state.databaseUser, state.databasePass))
    // Build array of device collections and the attributes we want to report on for that collection:
    //  Note, the collection names are stored as strings. Adding references to the actual collection
    //  objects causes major issues (possibly memory issues?).
    state.deviceAttributes = []
    state.deviceAttributes << [ devices: 'accelerometers', attributes: ['acceleration']]
    state.deviceAttributes << [ devices: 'alarms', attributes: ['alarm']]
    state.deviceAttributes << [ devices: 'batteries', attributes: ['battery']]
    state.deviceAttributes << [ devices: 'beacons', attributes: ['presence']]
    state.deviceAttributes << [ devices: 'buttons', attributes: ['button']]
    state.deviceAttributes << [ devices: 'cos', attributes: ['carbonMonoxide']]
    state.deviceAttributes << [ devices: 'co2s', attributes: ['carbonDioxide']]
    state.deviceAttributes << [ devices: 'colors', attributes: ['hue','saturation','color']]
    state.deviceAttributes << [ devices: 'consumables', attributes: ['consumableStatus']]
    state.deviceAttributes << [ devices: 'contacts', attributes: ['contact']]
    state.deviceAttributes << [ devices: 'doorsControllers', attributes: ['door']]
    state.deviceAttributes << [ devices: 'energyMeters', attributes: ['energy']]
    state.deviceAttributes << [ devices: 'humidities', attributes: ['humidity']]
    state.deviceAttributes << [ devices: 'illuminances', attributes: ['illuminance']]
    state.deviceAttributes << [ devices: 'locks', attributes: ['lock']]
    state.deviceAttributes << [ devices: 'motions', attributes: ['motion']]
    state.deviceAttributes << [ devices: 'musicPlayers', attributes: ['status','level','trackDescription','trackData','mute']]
    state.deviceAttributes << [ devices: 'peds', attributes: ['steps','goal']]
    state.deviceAttributes << [ devices: 'phMeters', attributes: ['pH']]
    state.deviceAttributes << [ devices: 'powerMeters', attributes: ['power','voltage','current','powerFactor']]
    state.deviceAttributes << [ devices: 'presences', attributes: ['presence']]
    state.deviceAttributes << [ devices: 'pressures', attributes: ['pressure']]
    state.deviceAttributes << [ devices: 'shockSensors', attributes: ['shock']]
    state.deviceAttributes << [ devices: 'signalStrengthMeters', attributes: ['lqi','rssi']]
    state.deviceAttributes << [ devices: 'sleepSensors', attributes: ['sleeping']]
    state.deviceAttributes << [ devices: 'smokeDetectors', attributes: ['smoke']]
    state.deviceAttributes << [ devices: 'soundSensors', attributes: ['sound']]
	state.deviceAttributes << [ devices: 'spls', attributes: ['soundPressureLevel']]
	state.deviceAttributes << [ devices: 'switches', attributes: ['switch']]
    state.deviceAttributes << [ devices: 'switchLevels', attributes: ['level']]
    state.deviceAttributes << [ devices: 'tamperAlerts', attributes: ['tamper']]
    state.deviceAttributes << [ devices: 'temperatures', attributes: ['temperature']]
    state.deviceAttributes << [ devices: 'thermostats', attributes: ['temperature','heatingSetpoint','coolingSetpoint','thermostatSetpoint','thermostatMode','thermostatFanMode','thermostatOperatingState','thermostatSetpointMode','scheduledSetpoint','optimisation','windowFunction']]
    state.deviceAttributes << [ devices: 'threeAxis', attributes: ['threeAxis']]
    state.deviceAttributes << [ devices: 'touchs', attributes: ['touch']]
    state.deviceAttributes << [ devices: 'uvs', attributes: ['ultravioletIndex']]
    state.deviceAttributes << [ devices: 'valves', attributes: ['contact']]
    state.deviceAttributes << [ devices: 'volts', attributes: ['voltage']]
    state.deviceAttributes << [ devices: 'waterSensors', attributes: ['water']]
    state.deviceAttributes << [ devices: 'windowShades', attributes: ['windowShade']]
    // Configure Scheduling:
    state.softPollingInterval = settings.prefSoftPollingInterval.toInteger()
    manageSchedules()
    // Configure Subscriptions:
 *  Event Handlers:
 *  handleAppTouch(evt)
 *  Used for testing.
def handleAppTouch(evt) {
    logger("handleAppTouch()","trace")
    softPoll()
 *  handleModeEvent(evt)
 *  Log Mode changes.
def handleModeEvent(evt) {
    logger("handleModeEvent(): Mode changed to: ${evt.value}","info")
    def locationId = escapeStringForInfluxDB(location.id.toString())
    def locationName = escapeStringForInfluxDB(location.name)
    def mode = '"' + escapeStringForInfluxDB(evt.value) + '"'
	def data = "_stMode,locationId=${locationId},locationName=${locationName} mode=${mode}"
    postToInfluxDB(data)
 *  handleEvent(evt)
 *  Builds data to send to InfluxDB.
 *   - Escapes and quotes string values.
 *   - Calculates logical binary values where string values can be
 *     represented as binary values (e.g. contact: closed = 1, open = 0)
 *  Useful references:
 *   - http://docs.smartthings.com/en/latest/capabilities-reference.html
 *   - https://docs.influxdata.com/influxdb/v0.10/guides/writing_data/
def handleEvent(evt) {
    //logger("handleEvent(): $evt.unit","info")
    logger("handleEvent(): $evt.displayName($evt.name:$evt.unit) $evt.value","info")
    // Build data string to send to InfluxDB:
    //  Format: <measurement>[,<tag_name>=<tag_value>] field=<field_value>
    //    If value is an integer, it must have a trailing "i"
    //    If value is a string, it must be enclosed in double quotes.
    def measurement = evt.name
    // tags:
    def deviceId = escapeStringForInfluxDB(evt.deviceId.toString())
    def deviceName = escapeStringForInfluxDB(evt.displayName)
    def groupId = escapeStringForInfluxDB(evt?.device.device.groupId)
    def groupName = escapeStringForInfluxDB(getGroupName(evt?.device.device.groupId))
    def hubId = escapeStringForInfluxDB(evt?.device.device.hubId.toString())
    def hubName = escapeStringForInfluxDB(evt?.device.device.hub.name.toString())
    // Don't pull these from the evt.device as the app itself will be associated with one location.
    def unit = escapeStringForInfluxDB(evt.unit)
    def value = escapeStringForInfluxDB(evt.value)
    def valueBinary = ''
    def data = "${measurement},deviceId=${deviceId},deviceName=${deviceName},groupId=${groupId},groupName=${groupName},hubId=${hubId},hubName=${hubName},locationId=${locationId},locationName=${locationName}"
    // Unit tag and fields depend on the event type:
    //  Most string-valued attributes can be translated to a binary value too.
    if ('acceleration' == evt.name) { // acceleration: Calculate a binary value (active = 1, inactive = 0)
        unit = 'acceleration'
        value = '"' + value + '"'
        valueBinary = ('active' == evt.value) ? '1i' : '0i'
        data += ",unit=${unit} value=${value},valueBinary=${valueBinary}"
    else if ('alarm' == evt.name) { // alarm: Calculate a binary value (strobe/siren/both = 1, off = 0)
        unit = 'alarm'
        valueBinary = ('off' == evt.value) ? '0i' : '1i'
    else if ('button' == evt.name) { // button: Calculate a binary value (held = 1, pushed = 0)
        unit = 'button'
        valueBinary = ('pushed' == evt.value) ? '0i' : '1i'
    else if ('carbonMonoxide' == evt.name) { // carbonMonoxide: Calculate a binary value (detected = 1, clear/tested = 0)
        unit = 'carbonMonoxide'
        valueBinary = ('detected' == evt.value) ? '1i' : '0i'
    else if ('consumableStatus' == evt.name) { // consumableStatus: Calculate a binary value ("good" = 1, "missing"/"replace"/"maintenance_required"/"order" = 0)
        unit = 'consumableStatus'
        valueBinary = ('good' == evt.value) ? '1i' : '0i'
    else if ('contact' == evt.name) { // contact: Calculate a binary value (closed = 1, open = 0)
        unit = 'contact'
        valueBinary = ('closed' == evt.value) ? '1i' : '0i'
    else if ('door' == evt.name) { // door: Calculate a binary value (closed = 1, open/opening/closing/unknown = 0)
        unit = 'door'
    else if ('lock' == evt.name) { // door: Calculate a binary value (locked = 1, unlocked = 0)
        unit = 'lock'
        valueBinary = ('locked' == evt.value) ? '1i' : '0i'
    else if ('motion' == evt.name) { // Motion: Calculate a binary value (active = 1, inactive = 0)
        unit = 'motion'
    else if ('mute' == evt.name) { // mute: Calculate a binary value (muted = 1, unmuted = 0)
        unit = 'mute'
        valueBinary = ('muted' == evt.value) ? '1i' : '0i'
    else if ('presence' == evt.name) { // presence: Calculate a binary value (present = 1, not present = 0)
        unit = 'presence'
        valueBinary = ('present' == evt.value) ? '1i' : '0i'
    else if ('shock' == evt.name) { // shock: Calculate a binary value (detected = 1, clear = 0)
        unit = 'shock'
    else if ('sleeping' == evt.name) { // sleeping: Calculate a binary value (sleeping = 1, not sleeping = 0)
        unit = 'sleeping'
        valueBinary = ('sleeping' == evt.value) ? '1i' : '0i'
    else if ('smoke' == evt.name) { // smoke: Calculate a binary value (detected = 1, clear/tested = 0)
        unit = 'smoke'
    else if ('sound' == evt.name) { // sound: Calculate a binary value (detected = 1, not detected = 0)
        unit = 'sound'
    else if ('switch' == evt.name) { // switch: Calculate a binary value (on = 1, off = 0)
        unit = 'switch'
        valueBinary = ('on' == evt.value) ? '1i' : '0i'
    else if ('tamper' == evt.name) { // tamper: Calculate a binary value (detected = 1, clear = 0)
        unit = 'tamper'
    else if ('thermostatMode' == evt.name) { // thermostatMode: Calculate a binary value (<any other value> = 1, off = 0)
        unit = 'thermostatMode'
    else if ('thermostatFanMode' == evt.name) { // thermostatFanMode: Calculate a binary value (<any other value> = 1, off = 0)
        unit = 'thermostatFanMode'
    else if ('thermostatOperatingState' == evt.name) { // thermostatOperatingState: Calculate a binary value (heating = 1, <any other value> = 0)
        unit = 'thermostatOperatingState'
        valueBinary = ('heating' == evt.value) ? '1i' : '0i'
    else if ('thermostatSetpointMode' == evt.name) { // thermostatSetpointMode: Calculate a binary value (followSchedule = 0, <any other value> = 1)
        unit = 'thermostatSetpointMode'
        valueBinary = ('followSchedule' == evt.value) ? '0i' : '1i'
    else if ('threeAxis' == evt.name) { // threeAxis: Format to x,y,z values.
        unit = 'threeAxis'
        def valueXYZ = evt.value.split(",")
        def valueX = valueXYZ[0]
        def valueY = valueXYZ[1]
        def valueZ = valueXYZ[2]
        data += ",unit=${unit} valueX=${valueX}i,valueY=${valueY}i,valueZ=${valueZ}i" // values are integers.
    else if ('touch' == evt.name) { // touch: Calculate a binary value (touched = 1, "" = 0)
        unit = 'touch'
        valueBinary = ('touched' == evt.value) ? '1i' : '0i'
    else if ('optimisation' == evt.name) { // optimisation: Calculate a binary value (active = 1, inactive = 0)
        unit = 'optimisation'
    else if ('windowFunction' == evt.name) { // windowFunction: Calculate a binary value (active = 1, inactive = 0)
        unit = 'windowFunction'
    else if ('touch' == evt.name) { // touch: Calculate a binary value (touched = 1, <any other value> = 0)
        unit = 'touch'
    else if ('water' == evt.name) { // water: Calculate a binary value (wet = 1, dry = 0)
        unit = 'water'
        valueBinary = ('wet' == evt.value) ? '1i' : '0i'
    else if ('windowShade' == evt.name) { // windowShade: Calculate a binary value (closed = 1, <any other value> = 0)
        unit = 'windowShade'
    // Catch any other event with a string value that hasn't been handled:
    else if (evt.value ==~ /.*[^0-9\.,-].*/) { // match if any characters are not digits, period, comma, or hyphen.
		logger("handleEvent(): Found a string value that's not explicitly handled: Device Name: ${deviceName}, Event Name: ${evt.name}, Value: ${evt.value}","warn")
        data += ",unit=${unit} value=${value}"
    // Catch any other general numerical event (carbonDioxide, power, energy, humidity, level, temperature, ultravioletIndex, voltage, etc).
    else {
    //logger("$data","info")
    // Post data to InfluxDB:
 *  Main Commands:
 *  softPoll()
 *  Executed by schedule.
 *  Forces data to be posted to InfluxDB (even if an event has not been triggered).
 *  Doesn't poll devices, just builds a fake event to pass to handleEvent().
 *  Also calls LogSystemProperties().
def softPoll() {
    logger("softPoll()","trace")
    logSystemProperties()
    // Iterate over each attribute for each device, in each device collection in deviceAttributes:
    def devs // temp variable to hold device collection.
    state.deviceAttributes.each { da ->
        devs = settings."${da.devices}"
        if (devs && (da.attributes)) {
            devs.each { d ->
                da.attributes.each { attr ->
                    if (d.hasAttribute(attr) && d.latestState(attr)?.value != null) {
                        logger("softPoll(): Softpolling device ${d} for attribute: ${attr}","info")
                        // Send fake event to handleEvent():
                        handleEvent([
                            value: d.latestState(attr)?.value,
                            unit: d.latestState(attr)?.unit,
                            device: d,
                            deviceId: d.id,
                            displayName: d.displayName
 *  logSystemProperties()
 *  Generates measurements for SmartThings system (hubs and locations) properties.
def logSystemProperties() {
    logger("logSystemProperties()","trace")
    def locationId = '"' + escapeStringForInfluxDB(location.id.toString()) + '"'
    def locationName = '"' + escapeStringForInfluxDB(location.name) + '"'
	// Location Properties:
    if (prefLogLocationProperties) {
        try {
            def tz = '"' + escapeStringForInfluxDB(location.timeZone.ID.toString()) + '"'
            def mode = '"' + escapeStringForInfluxDB(location.mode) + '"'
            def hubCount = location.hubs.size()
            def times = getSunriseAndSunset()
            def srt = '"' + times.sunrise.format("HH:mm", location.timeZone) + '"'
            def sst = '"' + times.sunset.format("HH:mm", location.timeZone) + '"'
            def data = "_heLocation,locationId=${locationId},locationName=${locationName},latitude=${location.latitude},longitude=${location.longitude},timeZone=${tz} mode=${mode},hubCount=${hubCount}i,sunriseTime=${srt},sunsetTime=${sst}"
            //log.debug("LocationData = ${data}")
        } catch (e) {
		    logger("logSystemProperties(): Unable to log Location properties: ${e}","error")
	// Hub Properties:
    if (prefLogHubProperties) {
       	location.hubs.each { h ->
        	try {
                def hubId = '"' + escapeStringForInfluxDB(h.id.toString()) + '"'
                def hubName = '"' + escapeStringForInfluxDB(h.name.toString()) + '"'
                def hubIP = '"' + escapeStringForInfluxDB(h.localIP.toString()) + '"'
                //def hubStatus = '"' + escapeStringForInfluxDB(h.status) + '"'
                //def batteryInUse = ("false" == h.hub.getDataValue("batteryInUse")) ? "0i" : "1i"
                // See fix here for null time returned: https://github.com/codersaur/SmartThings/pull/33/files
                //def hubUptime = h.hub.getDataValue("uptime") + 'i'
                //def hubLastBootUnixTS = h.hub.uptime + 'i'
                //def zigbeePowerLevel = h.hub.getDataValue("zigbeePowerLevel") + 'i'
                //def zwavePowerLevel =  '"' + escapeStringForInfluxDB(h.hub.getDataValue("zwavePowerLevel")) + '"'
                def firmwareVersion =  '"' + escapeStringForInfluxDB(h.firmwareVersionString) + '"'
                def data = "_heHub,locationId=${locationId},locationName=${locationName},hubId=${hubId},hubName=${hubName},hubIP=${hubIP} "
                data += "firmwareVersion=${firmwareVersion}"
                //data += "status=${hubStatus},batteryInUse=${batteryInUse},uptime=${hubUptime},zigbeePowerLevel=${zigbeePowerLevel},zwavePowerLevel=${zwavePowerLevel},firmwareVersion=${firmwareVersion}"
                //data += "status=${hubStatus},batteryInUse=${batteryInUse},uptime=${hubLastBootUnixTS},zigbeePowerLevel=${zigbeePowerLevel},zwavePowerLevel=${zwavePowerLevel},firmwareVersion=${firmwareVersion}"
                //log.debug("HubData = ${data}")
            } catch (e) {
				logger("logSystemProperties(): Unable to log Hub properties: ${e}","error")
 *  postToInfluxDB()
 *  Posts data to InfluxDB.
 *  Uses hubAction instead of httpPost() in case InfluxDB server is on the same LAN as the Smartthings Hub.
def postToInfluxDB(data) {
    logger("postToInfluxDB(): Posting data to InfluxDB: Host: ${state.databaseHost}, Port: ${state.databasePort}, Database: ${state.databaseName}, Data: [${data}]","info")
    //logger("$state", "info")
    try {
        //def hubAction = new physicalgraph.device.HubAction(
        def hubAction = new hubitat.device.HubAction(
                method: "POST",
                path: state.path,
                body: data,
                headers: state.headers
            null,
            [ callback: handleInfluxResponse ]
        log.debug("path: ${state.path}")
        log.debug("body: ${data}")
        log.debug("headers: ${state.headers}")
        sendHubCommand(hubAction)
    catch (Exception e) {
		logger("postToInfluxDB(): Exception ${e} on ${hubAction}","error")
    // For reference, code that could be used for WAN hosts:
     def url = "http://${state.databaseHost}:${state.databasePort}/write?db=${state.databaseName}"
        try {
          httpPost(url, data) { response ->
              if (response.status != 999 ) {
                  //log.debug "Response Status: ${response.status}"
                 //log.debug "Response data: ${response.data}"
                  //log.debug "Response contentType: ${response.contentType}"
      } catch (e) {
          logger("postToInfluxDB(): Something went wrong when posting: ${e}","error")
 *  handleInfluxResponse()
 *  Handles response from post made in postToInfluxDB().
//def handleInfluxResponse(physicalgraph.device.HubResponse hubResponse) {
def handleInfluxResponse(hubitat.device.HubResponse hubResponse) {
    //logger("hubresponse: $hubResponse", "info")
    if(hubResponse.status >= 400) {
		logger("postToInfluxDB(): Something went wrong! Response from InfluxDB: Headers: ${hubResponse.headers}, Body: ${hubResponse.body}","error")
 *  Private Helper Functions:
 *  manageSchedules()
 *  Configures/restarts scheduled tasks:
 *   softPoll() - Run every {state.softPollingInterval} minutes.
private manageSchedules() {
	logger("manageSchedules()","trace")
    // Generate a random offset (1-60):
    Random rand = new Random(now())
    def randomOffset = 0
    // softPoll:
    try {
        unschedule(softPoll)
    catch(e) {
        // logger("manageSchedules(): Unschedule failed!","error")
    if (state.softPollingInterval > 0) {
        randomOffset = rand.nextInt(60)
        logger("manageSchedules(): Scheduling softpoll to run every ${state.softPollingInterval} minutes (offset of ${randomOffset} seconds).","trace")
        schedule("${randomOffset} 0/${state.softPollingInterval} * * * ?", "softPoll")
 *  manageSubscriptions()
 *  Configures subscriptions.
private manageSubscriptions() {
	logger("manageSubscriptions()","trace")
    // Unsubscribe:
    unsubscribe()
    // Subscribe to App Touch events:
    subscribe(app,handleAppTouch)
    // Subscribe to mode events:
    if (prefLogModeEvents) subscribe(location, "mode", handleModeEvent)
    // Subscribe to device attributes (iterate over each attribute for each device collection in state.deviceAttributes):
    def devs // dynamic variable holding device collection.
                logger("manageSubscriptions(): Subscribing to attribute: ${attr}, for devices: ${da.devices}","info")
                // There is no need to check if all devices in the collection have the attribute.
                subscribe(devs, attr, handleEvent)
 *  logger()
 *  Wrapper function for all logging.
private logger(msg, level = "debug") {
    switch(level) {
        case "error":
            if (state.loggingLevelIDE >= 1) log.error msg
            break
        case "warn":
            if (state.loggingLevelIDE >= 2) log.warn msg
            break
        case "info":
            if (state.loggingLevelIDE >= 3) log.info msg
            break
        case "debug":
            if (state.loggingLevelIDE >= 4) log.debug msg
            break
        case "trace":
            if (state.loggingLevelIDE >= 5) log.trace msg
            break
        default:
            log.debug msg
            break
 *  encodeCredentialsBasic()
 *  Encode credentials for HTTP Basic authentication.
private encodeCredentialsBasic(username, password) {
    return "Basic " + "${username}:${password}".encodeAsBase64().toString()
 *  escapeStringForInfluxDB()
 *  Escape values to InfluxDB.
 *  If a tag key, tag value, or field key contains a space, comma, or an equals sign = it must
 *  be escaped using the backslash character \. Backslash characters do not need to be escaped.
 *  Commas and spaces will also need to be escaped for measurements, though equals signs = do not.
 *  Further info: https://docs.influxdata.com/influxdb/v0.10/write_protocols/write_syntax/
private escapeStringForInfluxDB(str) {
    logger("$str", "info")
    if (str) {
        str = str.replaceAll(" ", "\\\\ ") // Escape spaces.
        str = str.replaceAll(",", "\\\\,") // Escape commas.
        str = str.replaceAll("=", "\\\\=") // Escape equal signs.
        str = str.replaceAll("\"", "\\\\\"") // Escape double quotes.
        //str = str.replaceAll("'", "_")  // Replace apostrophes with underscores.
    else {
        str = 'null'
    return str
 *  getGroupName()
 *  Get the name of a 'Group' (i.e. Room) from its ID.
 *  This is done manually as there does not appear to be a way to enumerate
 *  groups from a SmartApp currently.
 *  GroupIds can be obtained from the SmartThings IDE under 'My Locations'.
 *  See: https://community.smartthings.com/t/accessing-group-within-a-smartapp/6830
private getGroupName(id) {
    if (id == null) {return 'Home'}
    //else if (id == 'XXXXXXXXXXXXX') {return 'Group'}
    else {return 'Unknown'}
Thank you for your code! I just got it going yesterday, so I imagine you found further things than I. I'll do that diff.
And I'll make you a deal... I'll put it up in the Habitat-Public organization . . . if you'll share any refinements and take a peek every now and again at any PRs that come through?
Honestly I'll do it no matter what but I'll beg whatever help I can, shamelessly, so why not start here? :wink:
Sounds like a good idea to me! My edits were pretty minor, just a few focusing on making some of the Hub Data feeds work, and commenting out those that I didn't know how to make work. None of them seemed too important, at least for my purposes.
You guys can use the HubitatCommunity repo if you want.
Dan, I've sent an Invite over on GitHub for Member of HubitatCommunity. @joshua , you can be invited too, but I'd need your github ID to send to.
GitHub - HubitatCommunity/InfluxDB-Logger <-- blank, created. I'll delete if there's no interest. :slight_smile:
Thanks to all for stirring this up. I'm excited to see this progress.
@csteele I'm "@tooluser". :wink: Already in.
If you could add me to this one, I'll fill it in and start the versioning/etc process.
I'm also going to (in my copious free time) work on a versioning system that uses GitHub versions rather than a JSON file stored in a repo. I was thinking we could add a wiki to the HubitatCommunity to gather techniques or something? @csteele
Done.
Thanks!
I've posted a version based on Codersaur's at:
And when I say 'based on' I mean really essentially identical with very minor tweaks. . . . that's some really nice code! Thank you, Codersaur!
@ogiewon
worked for me. Finally have the monitoring I want.
