And here is the Code I am using.
* Copyright David Lomas (codersaur)
* Name: InfluxDB Logger
* Date: 2017-04-03
* Version: 1.11
* Source: https://github.com/codersaur/SmartThings/tree/master/smartapps/influxdb-logger
* Author: David Lomas (codersaur)
* Description: A SmartApp to log SmartThings device states to an InfluxDB database.
* For full information, including installation instructions, exmples, and version history, see:
* https://github.com/codersaur/SmartThings/tree/master/smartapps/influxdb-logger
* IMPORTANT - To enable the resolution of groupNames (i.e. room names), you must manually insert the group IDs
* into the getGroupName() command code at the end of this file.
* License:
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
namespace: "codersaur",
author: "David Lomas (codersaur)",
description: "Log SmartThings device states to InfluxDB",
category: "My Apps",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
preferences {
section("General:") {
//input "prefDebugMode", "bool", title: "Enable debug logging?", defaultValue: true, displayDuringSetup: true
input (
title: "IDE Live Logging Level:\nMessages with this level and higher will be logged to the IDE.",
type: "enum",
options: [
"0" : "None",
"1" : "Error",
"2" : "Warning",
"3" : "Info",
"4" : "Debug",
"5" : "Trace"
defaultValue: "3",
displayDuringSetup: true,
required: false
section ("InfluxDB Database:") {
input "prefDatabaseHost", "text", title: "Host", defaultValue: "192.168.0.100", required: true
input "prefDatabasePort", "text", title: "Port", defaultValue: "8086", required: true
input "prefDatabaseName", "text", title: "Database Name", defaultValue: "Hubitat", required: true
input "prefDatabaseUser", "text", title: "Username", required: false
input "prefDatabasePass", "text", title: "Password", required: false
section("Polling:") {
input "prefSoftPollingInterval", "number", title:"Soft-Polling interval (minutes)", defaultValue: 10, required: true
section("System Monitoring:") {
input "prefLogModeEvents", "bool", title:"Log Mode Events?", defaultValue: true, required: true
input "prefLogHubProperties", "bool", title:"Log Hub Properties?", defaultValue: true, required: true
input "prefLogLocationProperties", "bool", title:"Log Location Properties?", defaultValue: true, required: true
section("Devices To Monitor:") {
input "accelerometers", "capability.accelerationSensor", title: "Accelerometers", multiple: true, required: false
input "alarms", "capability.alarm", title: "Alarms", multiple: true, required: false
input "batteries", "capability.battery", title: "Batteries", multiple: true, required: false
input "beacons", "capability.beacon", title: "Beacons", multiple: true, required: false
input "buttons", "capability.button", title: "Buttons", multiple: true, required: false
input "cos", "capability.carbonMonoxideDetector", title: "Carbon Monoxide Detectors", multiple: true, required: false
input "co2s", "capability.carbonDioxideMeasurement", title: "Carbon Dioxide Detectors", multiple: true, required: false
input "colors", "capability.colorControl", title: "Color Controllers", multiple: true, required: false
input "consumables", "capability.consumable", title: "Consumables", multiple: true, required: false
input "contacts", "capability.contactSensor", title: "Contact Sensors", multiple: true, required: false
input "doorsControllers", "capability.doorControl", title: "Door Controllers", multiple: true, required: false
input "energyMeters", "capability.energyMeter", title: "Energy Meters", multiple: true, required: false
input "humidities", "capability.relativeHumidityMeasurement", title: "Humidity Meters", multiple: true, required: false
input "illuminances", "capability.illuminanceMeasurement", title: "Illuminance Meters", multiple: true, required: false
input "locks", "capability.lock", title: "Locks", multiple: true, required: false
input "motions", "capability.motionSensor", title: "Motion Sensors", multiple: true, required: false
input "musicPlayers", "capability.musicPlayer", title: "Music Players", multiple: true, required: false
input "peds", "capability.stepSensor", title: "Pedometers", multiple: true, required: false
input "phMeters", "capability.pHMeasurement", title: "pH Meters", multiple: true, required: false
input "powerMeters", "capability.powerMeter", title: "Power Meters", multiple: true, required: false
input "presences", "capability.presenceSensor", title: "Presence Sensors", multiple: true, required: false
input "pressures", "capability.sensor", title: "Pressure Sensors", multiple: true, required: false
input "shockSensors", "capability.shockSensor", title: "Shock Sensors", multiple: true, required: false
input "signalStrengthMeters", "capability.signalStrength", title: "Signal Strength Meters", multiple: true, required: false
input "sleepSensors", "capability.sleepSensor", title: "Sleep Sensors", multiple: true, required: false
input "smokeDetectors", "capability.smokeDetector", title: "Smoke Detectors", multiple: true, required: false
input "soundSensors", "capability.soundSensor", title: "Sound Sensors", multiple: true, required: false
input "spls", "capability.soundPressureLevel", title: "Sound Pressure Level Sensors", multiple: true, required: false
input "switches", "capability.switch", title: "Switches", multiple: true, required: false
input "switchLevels", "capability.switchLevel", title: "Switch Levels", multiple: true, required: false
input "tamperAlerts", "capability.tamperAlert", title: "Tamper Alerts", multiple: true, required: false
input "temperatures", "capability.temperatureMeasurement", title: "Temperature Sensors", multiple: true, required: false
input "thermostats", "capability.thermostat", title: "Thermostats", multiple: true, required: false
input "threeAxis", "capability.threeAxis", title: "Three-axis (Orientation) Sensors", multiple: true, required: false
input "touchs", "capability.touchSensor", title: "Touch Sensors", multiple: true, required: false
input "uvs", "capability.ultravioletIndex", title: "UV Sensors", multiple: true, required: false
input "valves", "capability.valve", title: "Valves", multiple: true, required: false
input "volts", "capability.voltageMeasurement", title: "Voltage Meters", multiple: true, required: false
input "waterSensors", "capability.waterSensor", title: "Water Sensors", multiple: true, required: false
input "windowShades", "capability.windowShade", title: "Window Shades", multiple: true, required: false
* SmartThings System Commands:
* installed()
* Runs when the app is first installed.
def installed() {
state.installedAt = now()
state.loggingLevelIDE = 5
log.debug "${app.label}: Installed with settings: ${settings}"
* uninstalled()
* Runs when the app is uninstalled.
def uninstalled() {
logger("uninstalled()","trace")
* updated()
* Runs when app settings are changed.
* Updates device.state with input values and other hard-coded values.
* Builds state.deviceAttributes which describes the attributes that will be monitored for each device collection
* (used by manageSubscriptions() and softPoll()).
* Refreshes scheduling and subscriptions.
def updated() {
logger("updated()","trace")
// Update internal state:
state.loggingLevelIDE = (settings.configLoggingLevelIDE) ? settings.configLoggingLevelIDE.toInteger() : 3
// Database config:
state.databaseHost = settings.prefDatabaseHost
state.databasePort = settings.prefDatabasePort
state.databaseName = settings.prefDatabaseName
state.databaseUser = settings.prefDatabaseUser
state.databasePass = settings.prefDatabasePass
state.path = "/write?db=${state.databaseName}"
state.headers = [:]
state.headers.put("HOST", "${state.databaseHost}:${state.databasePort}")
//state.headers.put("Content-Type", "application/x-www-form-urlencoded")
if (state.databaseUser && state.databasePass) {
state.headers.put("Authorization", encodeCredentialsBasic(state.databaseUser, state.databasePass))
// Build array of device collections and the attributes we want to report on for that collection:
// Note, the collection names are stored as strings. Adding references to the actual collection
// objects causes major issues (possibly memory issues?).
state.deviceAttributes = []
state.deviceAttributes << [ devices: 'accelerometers', attributes: ['acceleration']]
state.deviceAttributes << [ devices: 'alarms', attributes: ['alarm']]
state.deviceAttributes << [ devices: 'batteries', attributes: ['battery']]
state.deviceAttributes << [ devices: 'beacons', attributes: ['presence']]
state.deviceAttributes << [ devices: 'buttons', attributes: ['button']]
state.deviceAttributes << [ devices: 'cos', attributes: ['carbonMonoxide']]
state.deviceAttributes << [ devices: 'co2s', attributes: ['carbonDioxide']]
state.deviceAttributes << [ devices: 'colors', attributes: ['hue','saturation','color']]
state.deviceAttributes << [ devices: 'consumables', attributes: ['consumableStatus']]
state.deviceAttributes << [ devices: 'contacts', attributes: ['contact']]
state.deviceAttributes << [ devices: 'doorsControllers', attributes: ['door']]
state.deviceAttributes << [ devices: 'energyMeters', attributes: ['energy']]
state.deviceAttributes << [ devices: 'humidities', attributes: ['humidity']]
state.deviceAttributes << [ devices: 'illuminances', attributes: ['illuminance']]
state.deviceAttributes << [ devices: 'locks', attributes: ['lock']]
state.deviceAttributes << [ devices: 'motions', attributes: ['motion']]
state.deviceAttributes << [ devices: 'musicPlayers', attributes: ['status','level','trackDescription','trackData','mute']]
state.deviceAttributes << [ devices: 'peds', attributes: ['steps','goal']]
state.deviceAttributes << [ devices: 'phMeters', attributes: ['pH']]
state.deviceAttributes << [ devices: 'powerMeters', attributes: ['power','voltage','current','powerFactor']]
state.deviceAttributes << [ devices: 'presences', attributes: ['presence']]
state.deviceAttributes << [ devices: 'pressures', attributes: ['pressure']]
state.deviceAttributes << [ devices: 'shockSensors', attributes: ['shock']]
state.deviceAttributes << [ devices: 'signalStrengthMeters', attributes: ['lqi','rssi']]
state.deviceAttributes << [ devices: 'sleepSensors', attributes: ['sleeping']]
state.deviceAttributes << [ devices: 'smokeDetectors', attributes: ['smoke']]
state.deviceAttributes << [ devices: 'soundSensors', attributes: ['sound']]
state.deviceAttributes << [ devices: 'spls', attributes: ['soundPressureLevel']]
state.deviceAttributes << [ devices: 'switches', attributes: ['switch']]
state.deviceAttributes << [ devices: 'switchLevels', attributes: ['level']]
state.deviceAttributes << [ devices: 'tamperAlerts', attributes: ['tamper']]
state.deviceAttributes << [ devices: 'temperatures', attributes: ['temperature']]
state.deviceAttributes << [ devices: 'thermostats', attributes: ['temperature','heatingSetpoint','coolingSetpoint','thermostatSetpoint','thermostatMode','thermostatFanMode','thermostatOperatingState','thermostatSetpointMode','scheduledSetpoint','optimisation','windowFunction']]
state.deviceAttributes << [ devices: 'threeAxis', attributes: ['threeAxis']]
state.deviceAttributes << [ devices: 'touchs', attributes: ['touch']]
state.deviceAttributes << [ devices: 'uvs', attributes: ['ultravioletIndex']]
state.deviceAttributes << [ devices: 'valves', attributes: ['contact']]
state.deviceAttributes << [ devices: 'volts', attributes: ['voltage']]
state.deviceAttributes << [ devices: 'waterSensors', attributes: ['water']]
state.deviceAttributes << [ devices: 'windowShades', attributes: ['windowShade']]
// Configure Scheduling:
state.softPollingInterval = settings.prefSoftPollingInterval.toInteger()
manageSchedules()
// Configure Subscriptions:
* Event Handlers:
* handleAppTouch(evt)
* Used for testing.
def handleAppTouch(evt) {
logger("handleAppTouch()","trace")
softPoll()
* handleModeEvent(evt)
* Log Mode changes.
def handleModeEvent(evt) {
logger("handleModeEvent(): Mode changed to: ${evt.value}","info")
def locationId = escapeStringForInfluxDB(location.id.toString())
def locationName = escapeStringForInfluxDB(location.name)
def mode = '"' + escapeStringForInfluxDB(evt.value) + '"'
def data = "_stMode,locationId=${locationId},locationName=${locationName} mode=${mode}"
postToInfluxDB(data)
* handleEvent(evt)
* Builds data to send to InfluxDB.
* - Escapes and quotes string values.
* - Calculates logical binary values where string values can be
* represented as binary values (e.g. contact: closed = 1, open = 0)
* Useful references:
* - http://docs.smartthings.com/en/latest/capabilities-reference.html
* - https://docs.influxdata.com/influxdb/v0.10/guides/writing_data/
def handleEvent(evt) {
//logger("handleEvent(): $evt.unit","info")
logger("handleEvent(): $evt.displayName($evt.name:$evt.unit) $evt.value","info")
// Build data string to send to InfluxDB:
// Format: <measurement>[,<tag_name>=<tag_value>] field=<field_value>
// If value is an integer, it must have a trailing "i"
// If value is a string, it must be enclosed in double quotes.
def measurement = evt.name
// tags:
def deviceId = escapeStringForInfluxDB(evt.deviceId.toString())
def deviceName = escapeStringForInfluxDB(evt.displayName)
def groupId = escapeStringForInfluxDB(evt?.device.device.groupId)
def groupName = escapeStringForInfluxDB(getGroupName(evt?.device.device.groupId))
def hubId = escapeStringForInfluxDB(evt?.device.device.hubId.toString())
def hubName = escapeStringForInfluxDB(evt?.device.device.hub.toString())
// Don't pull these from the evt.device as the app itself will be associated with one location.
def unit = escapeStringForInfluxDB(evt.unit)
def value = escapeStringForInfluxDB(evt.value)
def valueBinary = ''
def data = "${measurement},deviceId=${deviceId},deviceName=${deviceName},groupId=${groupId},groupName=${groupName},hubId=${hubId},hubName=${hubName},locationId=${locationId},locationName=${locationName}"
// Unit tag and fields depend on the event type:
// Most string-valued attributes can be translated to a binary value too.
if ('acceleration' == evt.name) { // acceleration: Calculate a binary value (active = 1, inactive = 0)
unit = 'acceleration'
value = '"' + value + '"'
valueBinary = ('active' == evt.value) ? '1i' : '0i'
data += ",unit=${unit} value=${value},valueBinary=${valueBinary}"
else if ('alarm' == evt.name) { // alarm: Calculate a binary value (strobe/siren/both = 1, off = 0)
unit = 'alarm'
valueBinary = ('off' == evt.value) ? '0i' : '1i'
else if ('button' == evt.name) { // button: Calculate a binary value (held = 1, pushed = 0)
unit = 'button'
valueBinary = ('pushed' == evt.value) ? '0i' : '1i'
else if ('carbonMonoxide' == evt.name) { // carbonMonoxide: Calculate a binary value (detected = 1, clear/tested = 0)
unit = 'carbonMonoxide'
valueBinary = ('detected' == evt.value) ? '1i' : '0i'
else if ('consumableStatus' == evt.name) { // consumableStatus: Calculate a binary value ("good" = 1, "missing"/"replace"/"maintenance_required"/"order" = 0)
unit = 'consumableStatus'
valueBinary = ('good' == evt.value) ? '1i' : '0i'
else if ('contact' == evt.name) { // contact: Calculate a binary value (closed = 1, open = 0)
unit = 'contact'
valueBinary = ('closed' == evt.value) ? '1i' : '0i'
else if ('door' == evt.name) { // door: Calculate a binary value (closed = 1, open/opening/closing/unknown = 0)
unit = 'door'
else if ('lock' == evt.name) { // door: Calculate a binary value (locked = 1, unlocked = 0)
unit = 'lock'
valueBinary = ('locked' == evt.value) ? '1i' : '0i'
else if ('motion' == evt.name) { // Motion: Calculate a binary value (active = 1, inactive = 0)
unit = 'motion'
else if ('mute' == evt.name) { // mute: Calculate a binary value (muted = 1, unmuted = 0)
unit = 'mute'
valueBinary = ('muted' == evt.value) ? '1i' : '0i'
else if ('presence' == evt.name) { // presence: Calculate a binary value (present = 1, not present = 0)
unit = 'presence'
valueBinary = ('present' == evt.value) ? '1i' : '0i'
else if ('shock' == evt.name) { // shock: Calculate a binary value (detected = 1, clear = 0)
unit = 'shock'
else if ('sleeping' == evt.name) { // sleeping: Calculate a binary value (sleeping = 1, not sleeping = 0)
unit = 'sleeping'
valueBinary = ('sleeping' == evt.value) ? '1i' : '0i'
else if ('smoke' == evt.name) { // smoke: Calculate a binary value (detected = 1, clear/tested = 0)
unit = 'smoke'
else if ('sound' == evt.name) { // sound: Calculate a binary value (detected = 1, not detected = 0)
unit = 'sound'
else if ('switch' == evt.name) { // switch: Calculate a binary value (on = 1, off = 0)
unit = 'switch'
valueBinary = ('on' == evt.value) ? '1i' : '0i'
else if ('tamper' == evt.name) { // tamper: Calculate a binary value (detected = 1, clear = 0)
unit = 'tamper'
else if ('thermostatMode' == evt.name) { // thermostatMode: Calculate a binary value (<any other value> = 1, off = 0)
unit = 'thermostatMode'
else if ('thermostatFanMode' == evt.name) { // thermostatFanMode: Calculate a binary value (<any other value> = 1, off = 0)
unit = 'thermostatFanMode'
else if ('thermostatOperatingState' == evt.name) { // thermostatOperatingState: Calculate a binary value (heating = 1, <any other value> = 0)
unit = 'thermostatOperatingState'
valueBinary = ('heating' == evt.value) ? '1i' : '0i'
else if ('thermostatSetpointMode' == evt.name) { // thermostatSetpointMode: Calculate a binary value (followSchedule = 0, <any other value> = 1)
unit = 'thermostatSetpointMode'
valueBinary = ('followSchedule' == evt.value) ? '0i' : '1i'
else if ('threeAxis' == evt.name) { // threeAxis: Format to x,y,z values.
unit = 'threeAxis'
def valueXYZ = evt.value.split(",")
def valueX = valueXYZ[0]
def valueY = valueXYZ[1]
def valueZ = valueXYZ[2]
data += ",unit=${unit} valueX=${valueX}i,valueY=${valueY}i,valueZ=${valueZ}i" // values are integers.
else if ('touch' == evt.name) { // touch: Calculate a binary value (touched = 1, "" = 0)
unit = 'touch'
valueBinary = ('touched' == evt.value) ? '1i' : '0i'
else if ('optimisation' == evt.name) { // optimisation: Calculate a binary value (active = 1, inactive = 0)
unit = 'optimisation'
else if ('windowFunction' == evt.name) { // windowFunction: Calculate a binary value (active = 1, inactive = 0)
unit = 'windowFunction'
else if ('touch' == evt.name) { // touch: Calculate a binary value (touched = 1, <any other value> = 0)
unit = 'touch'
else if ('water' == evt.name) { // water: Calculate a binary value (wet = 1, dry = 0)
unit = 'water'
valueBinary = ('wet' == evt.value) ? '1i' : '0i'
else if ('windowShade' == evt.name) { // windowShade: Calculate a binary value (closed = 1, <any other value> = 0)
unit = 'windowShade'
// Catch any other event with a string value that hasn't been handled:
else if (evt.value ==~ /.*[^0-9\.,-].*/) { // match if any characters are not digits, period, comma, or hyphen.
logger("handleEvent(): Found a string value that's not explicitly handled: Device Name: ${deviceName}, Event Name: ${evt.name}, Value: ${evt.value}","warn")
data += ",unit=${unit} value=${value}"
// Catch any other general numerical event (carbonDioxide, power, energy, humidity, level, temperature, ultravioletIndex, voltage, etc).
else {
//logger("$data","info")
// Post data to InfluxDB:
* Main Commands:
* softPoll()
* Executed by schedule.
* Forces data to be posted to InfluxDB (even if an event has not been triggered).
* Doesn't poll devices, just builds a fake event to pass to handleEvent().
* Also calls LogSystemProperties().
def softPoll() {
logger("softPoll()","trace")
logSystemProperties()
// Iterate over each attribute for each device, in each device collection in deviceAttributes:
def devs // temp variable to hold device collection.
state.deviceAttributes.each { da ->
devs = settings."${da.devices}"
if (devs && (da.attributes)) {
devs.each { d ->
da.attributes.each { attr ->
if (d.hasAttribute(attr) && d.latestState(attr)?.value != null) {
logger("softPoll(): Softpolling device ${d} for attribute: ${attr}","info")
// Send fake event to handleEvent():
handleEvent([
value: d.latestState(attr)?.value,
unit: d.latestState(attr)?.unit,
device: d,
deviceId: d.id,
displayName: d.displayName
* logSystemProperties()
* Generates measurements for SmartThings system (hubs and locations) properties.
def logSystemProperties() {
logger("logSystemProperties()","trace")
def locationId = '"' + escapeStringForInfluxDB(location.id.toString()) + '"'
def locationName = '"' + escapeStringForInfluxDB(location.name) + '"'
// Location Properties:
if (prefLogLocationProperties) {
try {
def tz = '"' + escapeStringForInfluxDB(location.timeZone.ID.toString()) + '"'
def mode = '"' + escapeStringForInfluxDB(location.mode) + '"'
def hubCount = location.hubs.size()
def times = getSunriseAndSunset()
def srt = '"' + times.sunrise.format("HH:mm", location.timeZone) + '"'
def sst = '"' + times.sunset.format("HH:mm", location.timeZone) + '"'
def data = "_stLocation,locationId=${locationId},locationName=${locationName},latitude=${location.latitude},longitude=${location.longitude},timeZone=${tz} mode=${mode},hubCount=${hubCount}i,sunriseTime=${srt},sunsetTime=${sst}"
} catch (e) {
logger("logSystemProperties(): Unable to log Location properties: ${e}","error")
// Hub Properties:
if (prefLogHubProperties) {
location.hubs.each { h ->
try {
def hubId = '"' + escapeStringForInfluxDB(h.id) + '"'
def hubName = '"' + escapeStringForInfluxDB(h.name) + '"'
def hubIP = '"' + escapeStringForInfluxDB(h.localIP) + '"'
def hubStatus = '"' + escapeStringForInfluxDB(h.status) + '"'
def batteryInUse = ("false" == h.hub.getDataValue("batteryInUse")) ? "0i" : "1i"
// See fix here for null time returned: https://github.com/codersaur/SmartThings/pull/33/files
//def hubUptime = h.hub.getDataValue("uptime") + 'i'
def hubLastBootUnixTS = h.hub.uptime + 'i'
def zigbeePowerLevel = h.hub.getDataValue("zigbeePowerLevel") + 'i'
def zwavePowerLevel = '"' + escapeStringForInfluxDB(h.hub.getDataValue("zwavePowerLevel")) + '"'
def firmwareVersion = '"' + escapeStringForInfluxDB(h.firmwareVersionString) + '"'
def data = "_stHub,locationId=${locationId},locationName=${locationName},hubId=${hubId},hubName=${hubName},hubIP=${hubIP} "
//data += "status=${hubStatus},batteryInUse=${batteryInUse},uptime=${hubUptime},zigbeePowerLevel=${zigbeePowerLevel},zwavePowerLevel=${zwavePowerLevel},firmwareVersion=${firmwareVersion}"
data += "status=${hubStatus},batteryInUse=${batteryInUse},uptime=${hubLastBootUnixTS},zigbeePowerLevel=${zigbeePowerLevel},zwavePowerLevel=${zwavePowerLevel},firmwareVersion=${firmwareVersion}"
} catch (e) {
logger("logSystemProperties(): Unable to log Hub properties: ${e}","error")
* postToInfluxDB()
* Posts data to InfluxDB.
* Uses hubAction instead of httpPost() in case InfluxDB server is on the same LAN as the Smartthings Hub.
def postToInfluxDB(data) {
logger("postToInfluxDB(): Posting data to InfluxDB: Host: ${state.databaseHost}, Port: ${state.databasePort}, Database: ${state.databaseName}, Data: [${data}]","info")
//logger("$state", "info")
//try {
// //def hubAction = new physicalgraph.device.HubAction(
// def hubAction = new hubitat.device.HubAction(
// method: "POST",
// path: state.path,
// body: data,
// headers: state.headers
// null,
// [ callback: handleInfluxResponse ]
// sendHubCommand(hubAction)
// //logger("hubAction command sent", "info")
//catch (Exception e) {
// logger("postToInfluxDB(): Exception ${e} on ${hubAction}","error")
// For reference, code that could be used for WAN hosts:
def url = "http://${state.databaseHost}:${state.databasePort}/write?db=${state.databaseName}"
try {
httpPost(url, data) { response ->
if (response.status != 999 ) {
//log.debug "Response Status: ${response.status}"
//log.debug "Response data: ${response.data}"
//log.debug "Response contentType: ${response.contentType}"
} catch (e) {
logger("postToInfluxDB(): Something went wrong when posting: ${e}","error")
* handleInfluxResponse()
* Handles response from post made in postToInfluxDB().
//def handleInfluxResponse(physicalgraph.device.HubResponse hubResponse) {
def handleInfluxResponse(hubitat.device.HubResponse hubResponse) {
//logger("hubresponse: $hubResponse", "info")
if(hubResponse.status >= 400) {
logger("postToInfluxDB(): Something went wrong! Response from InfluxDB: Headers: ${hubResponse.headers}, Body: ${hubResponse.body}","error")
* Private Helper Functions:
* manageSchedules()
* Configures/restarts scheduled tasks:
* softPoll() - Run every {state.softPollingInterval} minutes.
private manageSchedules() {
logger("manageSchedules()","trace")
// Generate a random offset (1-60):
Random rand = new Random(now())
def randomOffset = 0
// softPoll:
try {
unschedule(softPoll)
catch(e) {
// logger("manageSchedules(): Unschedule failed!","error")
if (state.softPollingInterval > 0) {
randomOffset = rand.nextInt(60)
logger("manageSchedules(): Scheduling softpoll to run every ${state.softPollingInterval} minutes (offset of ${randomOffset} seconds).","trace")
schedule("${randomOffset} 0/${state.softPollingInterval} * * * ?", "softPoll")
* manageSubscriptions()
* Configures subscriptions.
private manageSubscriptions() {
logger("manageSubscriptions()","trace")
// Unsubscribe:
unsubscribe()
// Subscribe to App Touch events:
subscribe(app,handleAppTouch)
// Subscribe to mode events:
if (prefLogModeEvents) subscribe(location, "mode", handleModeEvent)
// Subscribe to device attributes (iterate over each attribute for each device collection in state.deviceAttributes):
def devs // dynamic variable holding device collection.
logger("manageSubscriptions(): Subscribing to attribute: ${attr}, for devices: ${da.devices}","info")
// There is no need to check if all devices in the collection have the attribute.
subscribe(devs, attr, handleEvent)
* logger()
* Wrapper function for all logging.
private logger(msg, level = "debug") {
switch(level) {
case "error":
if (state.loggingLevelIDE >= 1) log.error msg
break
case "warn":
if (state.loggingLevelIDE >= 2) log.warn msg
break
case "info":
if (state.loggingLevelIDE >= 3) log.info msg
break
case "debug":
if (state.loggingLevelIDE >= 4) log.debug msg
break
case "trace":
if (state.loggingLevelIDE >= 5) log.trace msg
break
default:
log.debug msg
break
* encodeCredentialsBasic()
* Encode credentials for HTTP Basic authentication.
private encodeCredentialsBasic(username, password) {
return "Basic " + "${username}:${password}".encodeAsBase64().toString()
* escapeStringForInfluxDB()
* Escape values to InfluxDB.
* If a tag key, tag value, or field key contains a space, comma, or an equals sign = it must
* be escaped using the backslash character \. Backslash characters do not need to be escaped.
* Commas and spaces will also need to be escaped for measurements, though equals signs = do not.
* Further info: https://docs.influxdata.com/influxdb/v0.10/write_protocols/write_syntax/
private escapeStringForInfluxDB(str) {
//logger("$str", "info")
if (str) {
str = str.replaceAll(" ", "\\\\ ") // Escape spaces.
str = str.replaceAll(",", "\\\\,") // Escape commas.
str = str.replaceAll("=", "\\\\=") // Escape equal signs.
str = str.replaceAll("\"", "\\\\\"") // Escape double quotes.
//str = str.replaceAll("'", "_") // Replace apostrophes with underscores.
else {
str = 'null'
return str
* getGroupName()
* Get the name of a 'Group' (i.e. Room) from its ID.
* This is done manually as there does not appear to be a way to enumerate
* groups from a SmartApp currently.
* GroupIds can be obtained from the SmartThings IDE under 'My Locations'.
* See: https://community.smartthings.com/t/accessing-group-within-a-smartapp/6830
private getGroupName(id) {
if (id == null) {return 'Home'}
//else if (id == 'XXXXXXXXXXXXX') {return 'Group'}
else {return 'Unknown'}
