Release 2.3.5.101 Available
Changes from 2.3.4.153
New Hub Model C-8 Released
- New hub features:
- Z-Wave 800 radio
- Zigbee 3.0 radio (IEEE 802.15.4)
- Wi-Fi and ethernet network connectivity
- External antennas for Z-Wave and Zigbee
- USB-C power adapter
New Service Features
- Free migration via cloud backup from Model C-5 or Model C-7 hub to Model C-8, including both Zigbee and Z-Wave radios (see instructions).
Hub Protect subscription service for C-8 now includes both Zigbee and Z-Wave radios backup and restore.
- C-8 Hub can be connected to the LAN via Ethernet or integrated Wi-Fi for initial setup at go.hubitat.com.
Bug Fixes
- Added small pauses in database cleanup to reduce CPU load peaks.
- Room Lights:
- Fixed to correctly set a shades activator device to the correct state when the shades are operated manually outside of Room Lights.
- Fixed incorrectly turning on a device when Force is checked and On is not checked in device table.
- Fixed incorrectly clearing Force checkbox upon re-capture.
- Thermostat Scheduler: Fixed honoring Away setting if restricted when the mode changes to Away.
- Rule 5.1: Fixed response to endpoints to be properly formatted JSON.
Release 2.3.5.102 Available
Changes from 2.3.5.101
Bug Fixes
- Fixed unsuccessful migration backups for emails containing an underscore.
- Fixed Sinope multi controller child device switch reporting.
- Thermostat Controller: Fixed turning off thermostat when restricted, and UI problems with sensor weights.
- Rule 5.1: Fixed an error on line 241 for new rule Required Expression.
Platform Changes
- Backup/restore page: show C8 migration backup in the list of backups, display warning when last cloud backup fails.
App Updates
- WebCoRE updated to the latest available version.
Release 2.3.5.103 Available
Changes from 2.3.5.102
Bug Fixes
- Fixed "restore failed" while trying to migrate to C8.
Release 2.3.5.104 Available
Changes from 2.3.5.103
Bug Fixes
- Added extra Zigbee logging for C8 hubs.
- Modified cloud backup to skip Zigbee backup if a Zigbee network was never configured on the hub.
Release 2.3.5.105 Available
Changes from 2.3.5.104
Bug Fixes
- Added an endpoint to reset and restore Zigbee on C8 hubs.
- Added database flush before running backup to pick the very latest updates.
Release 2.3.5.109 Available
Changes from 2.3.5.105
Bug Fixes
- Added logic to automatically recreate Zigbee network when Zigbee is stuck on INITIALIZING (C8 only).
- Added options to manually recreate Zigbee network on Settings - Zigbee details page or automatically upon every hub reboot (C8 only).
- Fixed possible delayed update of hub variable.
- Added DNS safeguard to prevent hub dropping cloud connection on router reboot.
Release 2.3.5.110 Available
Changes from 2.3.5.109
Bug Fixes
- Fixes for Zigbee "rebuild network" logic for C8 hubs.
- Rule 5.1:
- Fixed an error for Delay Per Mode.
- Fixed an error for certain corrupted rules involving time variables (line 6359).
- CT100 thermostats: Fixed setting setpoints after thermostat mode is set in multi-command cases from Thermostat Scheduler, Rule 5.1 or Basic Rule.
Release 2.3.5.113 Available
Changes from 2.3.5.110
Bug Fixes
- Possible fixes for C8 Zigbee device join and rejoin issues.
- Possible fixes for C8 Zigbee devices falling off the network and not rejoining on their own.
- Thermostat Scheduler: Fixed ignoring EcoMode when variable setpoint is used.
- Fixed detection of network disconnects on C8 hubs.
Platform Changes
- Added migration specific links for migration ready backups on Backup and Restore page.
Release 2.3.5.117 Available
Changes from 2.3.5.114
Bug Fixes
- Fixed Hue V1 motion sensors not joining on C8 hubs.
- Probably fixed Hue V1 motion sensors falling off network and not rejoining C8 networks as they should.*
- Rule 5.1: Fixed an error thrown after certain editing of actions (line 2608), breaking rule UI.
- Disabled WiFi power management to prevent disconnects.
- CT32 Thermostat: Possibly fixed problem with setting a setpoint after setting thermostatMode.
*NOTE: some devices that fell off the network may require factory resetting before they can join the Zigbee network again.
Release 2.3.5.118 Available
Changes from 2.3.5.117
Bug Fixes
- Zigbee stability tweaks for C8.
Release 2.3.5.121 Available
Changes from 2.3.5.118
Bug Fixes
- Rule 5.1:
- Fixed triggers for Custom Attribute where changed failed to trigger the rule..
- Fixed Wait timeout mistakenly cancelled at midnight when Required Expression involves sunset/sunrise.
Platform Changes
- Added a separate migration workflow in Get Started screen.
- Removed Zigbee stack selection endpoint.
- DHCP DNS server overrides can now be cleared.
Release 2.3.5.123 Available
Changes from 2.3.5.121
Bug Fixes
- Stopping Zigbee inclusion also stops runaway Zigbee device initialization issue on C8.
- DateTime Connector: Fixed setting time when no date, causing date value to be wiped out with invalid value.
- Button Controller: Fixed Actions with long text overflowing the table.
- Schlage BE468/BE469 Lock driver includes an option to silence "Door Operation Reports" which can return inaccurate digital/physical event parameters.
Platform Changes
- Added a Zigbee "legacy" inclusion mode for C8 hubs. The inclusion process suggests this mode only if a device starts initializing but never finishes.
- Group Bulb dimmer now supports the changeLevel capability.
- Room Lights Activator devices now support changeLevel capability.
Release 2.3.5.124 Available
Changes from 2.3.5.123
Bug Fixes
- Fixed Zigbee inclusion stuck on initializing for Third Reality motion sensor and other devices.
- Dashboard: Fixed not being able to remove Set Modes pin.
Release 2.3.5.125 Available
Changes from 2.3.5.124
Bug Fixes
- Fixed the issue causing non-responding devices following Zigbee migration.
- Notify: Fixed setting Hub Variable In Use By, and support for Hub Variable rename.
- Rule Machine: Fixed an error thrown attempting to import Basic Rule or Simple Automation Rule.
Release 2.3.5.130 Available
Changes from 2.3.5.125
New Devices
- Add Lutron Shade Remote (4 group model CS-YJ-4GC-WH)
Bug Fixes
- Bond Integration:
- Fixed supported fan speeds not updating for fan device.
- Added custom increaseSpeed and decreaseSpeed commands.
- Populate missing fanspeed names for 6 speed fans and above.
- Fixed cycleSpeed command getting 'stuck' at certain speeds.
- Fixed occasional issue of initial device state not populating fully.
- Rule 5.1:
- Fixed error on line 1754.
- Fixed displaying Done with Trigger Event button when
**Any Value** selected for Comparison.
- HSM Rule: Fixed to use
both() command for sirens when both siren and strobe are selected for the alert.
- Fixed "unable to restore" issue on large migration backups.
- Room Lights: Fixed turning off lights if time period change adjusts lights during pending off.
Platform Changes
- Zigbee device joining and monitoring tweaks; default Zigbee power level on C8 changed to 8 (value explicitly set by user is not overridden).
- Added logic to use default DNS servers if DHCP does not provide any.
Release 2.3.5.131 Available
Changes from 2.3.5.130
New Drivers
- Sinopé water heater controller.
New App Features
- Room Lights:
- Added earlier/later of two times for time periods.
- Added variable elapsed time as Means to Turn Off.
Bug Fixes
- Fixed dropped WiFi connectivity issue when WiFi router and hub are rebooted around the same time.
- Button Rule: Fixed losing it's trigger subscription button number when the first condition is deleted.
Platform Changes
- Added a toggle to turn off polling of quiet Zigbee devices on the Zigbee details page.
- Cleaned up /hub/zigbee/getChildAndRouteInfo page on C8 hubs.
Release 2.3.5.135 Available
Changes from 2.3.5.131
Bug Fixes
- Fixed Hue v1 motion OTA update.
Platform Changes
- All hub versions - added last Zigbee message timestamp and Zigbee message counter on Zigbee details page.
- C8 only - added ping on/off toggles to individual devices on Zigbee details page, added explicit selection of Zigbee join modes and instructions on when to use them; made change in ZDO message handling.
- Increased max hub variable value size to 1024 characters.
Release 2.3.5.138 Available
Changes from 2.3.5.135
New Devices
- Add Sinopé tank Level Monitor
New App Features
- Rule 5.1: Added increased/decreased by over selected amount for triggers.
Bug Fixes
- Fixed Last Update Time to reflect the last time a message is received from a device (as opposed to the last time device attribute changed).
- Fixed a source of memory leaks while doing cloud backups.
- Basic Rule: Fixed Set Color action that causes UI crash.
- Rule 5.1: Fixed trigger subscriptions incorrectly being created at initialization of a new rule even if Required Expression is false.
Platform Changes
- Minor update for Zigbee library.
- Modified WiFi reconnect to be more proactive immediately after reboot if initial WiFi connection attempt fails.
- Some atomicState performance tweaks.
- C8 only - hide Iris V1 inclusion and compatible devices.
Release 2.3.5.140 Available
Changes from 2.3.5.138
New App Features
- WebCore updated to the latest version.
Bug Fixes
- Room Lights: Fixed an error thrown when a controlled device is offline.
- Rule 5.1:
- Fixed an incorrect "Mismatched attribute value" for JSON attributes as strings.
- Fixed an error thrown when a variable type is changed.
- Onkyo, Denon and Pioneer AVR drivers:
- Implemented missing sendMsg command.
- Fixed rare LIFX crash when LAN connection is lost.
- Possibly fixed growing delay between event and triggered rule execution.
Platform Changes
- Tweaked WiFi for faster reconnection on router reboots.
Release 2.3.5.141 Available
Changes from 2.3.5.140
Bug Fixes
- Fixed JavaScript error while trying to start cloud restore.
- Rule 5.1: Fixed Event Subscriptions for Wait for Event for a button event.
