Node-Red Flow Samples/Sharing
Good idea!
This thread is being created to give users of the Node-Red platform a place to share 'flows' focused on HE. When posting a flow please be sure to follow the simple formatting outlined below.
Title - this will be used to link your post in the Index on post #1. Please keep them short but descriptive.
Summary - include a brief description of what your flows automates. If it is a complex flow, give as detailed description as possible.
Picture - let everyone visualize the flow and better decide if it could be of use to them.
Flow - put three back-ticks " ``` " (left of the 1 key), and a return in front of, and after your flow json. This will create a code block, and make the code easier to import.
image image
Optional - using the 'Hide Details' option creates a "twist tie" around the code block
How to Import a flow from this thread into Node-Red
Click the 'twist tie' to expand the Flow you want to copy
Highlight and copy ALL the text in the expanded area. Open Your Node-Red UI, and click the hamburger menu, then 'Import'.
Paste the copied text into the open area and click 'Import'
The new flow should now appear in your Node-Red palette
If you are missing nodes that flow needs NR will prompt you. Make note of the nodes need, and install them.
Thanks to all that share, and inspire!!
Index of Shared Flows - Last updated 8-17-2020 17:30 EDT
Motion activated night lighting
Hub restart notification
Z-wave polling ONLY on motion
Office scenes with PC control
Periodic internet speed test
Backup Node Red
Setting the mode when the maid arrives and leaves
All Lux events on 1 trigger
Randomized greeting/departure announcement
Fan control using inside temp comparison with outside temp check.
Outside Light On and Off + Change with Motion
An Example of a boolean usage
motion lighting with dim level adjust
reformat Plex webhook posts to a usable payload object
circadian lighting routine
Log Internet Performance to Influxdb
Sensor offline sends a notice every 24 hours once offline.
Simple button toggle of a switch
Motion Lighting Template
Motion lighting that is disabled with button press
Log Proxmox data to influxDB
Control lights specific to room with Alexa using same phrase
Delay with Intervals Subflow Example
Title - Motion activated night lighting.
Summary - This flow turns a light on at 25%, but only between certain hours. It includes a shut off timer with cancellation if more motion is detected.
EDIT: Update 7/21/2020 - Added/then extended inactive timer to 7:15am to aid final shut off.
Flow
[{"id":"b9d2f5a.b069808","type":"within-time-switch","z":"a0d5236f.7d257","name":"8pm-7am","nameInt":"","positionConfig":"b3a05d3c.fb68f","startTime":"20:00","startTimeType":"entered","startOffset":0,"startOffsetType":"none","startOffsetMultiplier":60000,"endTime":"07:00","endTimeType":"entered","endOffset":0,"endOffsetType":"none","endOffsetMultiplier":60000,"timeDays":"*","timeOnlyOddDays":false,"timeOnlyEvenDays":false,"timeMonths":"*","timedatestart":"","timedateend":"","propertyStart":"","propertyStartType":"none","propertyStartCompare":"true","propertyStartThreshold":"","propertyStartThresholdType":"num","startTimeAlt":"","startTimeAltType":"entered","startOffsetAlt":0,"startOffsetAltType":"none","startOffsetAltMultiplier":60000,"propertyEnd":"","propertyEndType":"none","propertyEndCompare":"true","propertyEndThreshold":"","propertyEndThresholdType":"num","endTimeAlt":"","endTimeAltType":"entered","endOffsetAlt":0,"endOffsetAltType":"none","endOffsetAltMultiplier":60000,"tsCompare":"0","x":640,"y":2400,"wires":[["5caa8700.52a368"],[]]},{"id":"4c989f0d.1db49","type":"hubitat device","z":"a0d5236f.7d257","name":"Kitchen Beam Motion","server":"e56053d2.c7d11","deviceId":"2376","attribute":"motion","sendEvent":true,"x":240,"y":2420,"wires":[["a1e2897e.949af8"]]},{"id":"526127dd.9443f8","type":"hubitat command","z":"a0d5236f.7d257","name":"Under cabinet lights On","server":"e56053d2.c7d11","deviceId":"590","command":"on","commandArgs":"","x":1010,"y":2400,"wires":[["6363f6d0.70cdc8"]]},{"id":"a1e2897e.949af8","type":"switch","z":"a0d5236f.7d257","name":"Active/Inactive","property":"payload.value","propertyType":"msg","rules":[{"t":"eq","v":"active","vt":"str"},{"t":"eq","v":"inactive","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":460,"y":2440,"wires":[["b9d2f5a.b069808"],["b8bd09de.78a078"]]},{"id":"829fb8e2.b63f98","type":"hubitat command","z":"a0d5236f.7d257","name":"Under cabinet lights Off","server":"e56053d2.c7d11","deviceId":"590","command":"off","commandArgs":"","x":1690,"y":2380,"wires":[[]]},{"id":"5caa8700.52a368","type":"hubitat command","z":"a0d5236f.7d257","name":"Set to 25%","server":"e56053d2.c7d11","deviceId":"590","command":"setLevel","commandArgs":"25","x":810,"y":2400,"wires":[["526127dd.9443f8"]]},{"id":"7b372bbe.16e194","type":"comment","z":"a0d5236f.7d257","name":"Under Cabinet Night Lighting","info":" - ","x":200,"y":2360,"wires":[]},{"id":"473d9685.076ab8","type":"stoptimer","z":"a0d5236f.7d257","duration":"1","units":"Minute","payloadtype":"num","payloadval":"0","name":"","x":1480,"y":2380,"wires":[["829fb8e2.b63f98"],[]]},{"id":"6363f6d0.70cdc8","type":"change","z":"a0d5236f.7d257","name":"Send STOP","rules":[{"t":"set","p":"payload","pt":"msg","to":"STOP","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1230,"y":2400,"wires":[["473d9685.076ab8"]]},{"id":"4b5b8e3.96a0f7","type":"hubitat device","z":"a0d5236f.7d257","name":"Kitchen Wide Motion","server":"e56053d2.c7d11","deviceId":"2759","attribute":"motion","sendEvent":true,"x":240,"y":2480,"wires":[["a1e2897e.949af8"]]},{"id":"6b48a2ff.a8ea3c","type":"switch","z":"a0d5236f.7d257","name":"Active/Inactive","property":"payload.value","propertyType":"msg","rules":[{"t":"eq","v":"active","vt":"str"},{"t":"eq","v":"inactive","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":1460,"y":2460,"wires":[[],["473d9685.076ab8"]]},{"id":"910035fe.692fc8","type":"hubitat device","z":"a0d5236f.7d257","name":"Kitchen Wide Motion","server":"e56053d2.c7d11","deviceId":"2759","attribute":"motion","sendEvent":false,"x":1260,"y":2460,"wires":[["6b48a2ff.a8ea3c"]]},{"id":"46332d79.b15bc4","type":"hubitat device","z":"a0d5236f.7d257","name":"Kitchen Beam Motion","server":"e56053d2.c7d11","deviceId":"2376","attribute":"motion","sendEvent":false,"x":860,"y":2460,"wires":[["9e308a92.69c2a8"]]},{"id":"9e308a92.69c2a8","type":"switch","z":"a0d5236f.7d257","name":"Active/Inactive","property":"payload.value","propertyType":"msg","rules":[{"t":"eq","v":"active","vt":"str"},{"t":"eq","v":"inactive","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":1060,"y":2460,"wires":[[],["910035fe.692fc8"]]},{"id":"b8bd09de.78a078","type":"within-time-switch","z":"a0d5236f.7d257","name":"8pm-7:15am","nameInt":"","positionConfig":"b3a05d3c.fb68f","startTime":"20:00","startTimeType":"entered","startOffset":0,"startOffsetType":"none","startOffsetMultiplier":60000,"endTime":"07:15","endTimeType":"entered","endOffset":0,"endOffsetType":"none","endOffsetMultiplier":60000,"timeDays":"*","timeOnlyOddDays":false,"timeOnlyEvenDays":false,"timeMonths":"*","timedatestart":"","timedateend":"","propertyStart":"","propertyStartType":"none","propertyStartCompare":"true","propertyStartThreshold":"","propertyStartThresholdType":"num","startTimeAlt":"","startTimeAltType":"entered","startOffsetAlt":0,"startOffsetAltType":"none","startOffsetAltMultiplier":60000,"propertyEnd":"","propertyEndType":"none","propertyEndCompare":"true","propertyEndThreshold":"","propertyEndThresholdType":"num","endTimeAlt":"","endTimeAltType":"entered","endOffsetAlt":0,"endOffsetAltType":"none","endOffsetAltMultiplier":60000,"tsCompare":"0","x":650,"y":2460,"wires":[["46332d79.b15bc4"],[]]},{"id":"b3a05d3c.fb68f","type":"position-config","z":"","name":"localPosition","isValide":"true","longitude":"0","latitude":"0","angleType":"deg","timeZoneOffset":"99","timeZoneDST":"0","stateTimeFormat":"3","stateDateFormat":"12"},{"id":"e56053d2.c7d11","type":"hubitat config","z":"","name":"Devices Hub","usetls":false,"host":"10.13.9.11","port":"80","appId":"2532","nodeRedServer":"http://10.13.9.28:1880","webhookPath":"/hubitat/webhook__","autoRefresh":true,"useWebsocket":false}]
Title: Reboot notifier
This flow notifies me when either hub has restarted. It also updates a global variable so I can see at an instant how long the hub has been up. You could modify the inject node for a regularly scheduled reboot if necessary.
Summary
[{"id":"1333bb52.429db5","type":"group","z":"12b33325.27e27d","name":"Hub restart notification","style":{"stroke":"#0070c0","fill":"#bfdbef","label":true,"label-position":"nw","color":"#0070c0"},"nodes":["8f2ea924.bfec08","b9034e29.1868b","32584f53.0a3e3","cb8ac681.d779e8","9ac6a6c6.8de0e8","77463c4c.9da2d4","d4762cac.6c5e1","1db0e593.2ea0ca","f3197161.26456"],"x":394,"y":239,"w":892,"h":122},{"id":"cb12a8bd.1d64c8","type":"subflow","name":"Pushover Mechanical","info":"","category":"","in":[{"x":60,"y":80,"wires":[{"id":"babdbeec.49966"}]}],"out":[],"env":[],"color":"#3FADB5","inputLabels":["Message to send"],"icon":"node-red-contrib-pushover/pushover.svg"},{"id":"f9956a67.deab98","type":"pushover api","z":"cb12a8bd.1d64c8","keys":"9adb152e.dc3bc8","title":"","name":"","x":380,"y":80,"wires":[]},{"id":"babdbeec.49966","type":"change","z":"cb12a8bd.1d64c8","name":"mechanical","rules":[{"t":"set","p":"sound","pt":"msg","to":"mechanical","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":190,"y":80,"wires":[["f9956a67.deab98"]]},{"id":"9adb152e.dc3bc8","type":"pushover-keys","z":"","name":"NR Pushover Key"},{"id":"8f2ea924.bfec08","type":"hubitat location","z":"12b33325.27e27d","g":"1333bb52.429db5","name":"Hub 1","server":"83c9a93c.3e4bf8","x":470,"y":280,"wires":[["b9034e29.1868b"]]},{"id":"b9034e29.1868b","type":"switch","z":"12b33325.27e27d","g":"1333bb52.429db5","name":"systemStart","property":"payload.name","propertyType":"msg","rules":[{"t":"eq","v":"systemStart","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":610,"y":280,"wires":[["1db0e593.2ea0ca"]]},{"id":"32584f53.0a3e3","type":"hubitat location","z":"12b33325.27e27d","g":"1333bb52.429db5","name":"Hub 2","server":"8e2931b3.ce395","x":470,"y":320,"wires":[["cb8ac681.d779e8"]]},{"id":"cb8ac681.d779e8","type":"switch","z":"12b33325.27e27d","g":"1333bb52.429db5","name":"systemStart","property":"payload.name","propertyType":"msg","rules":[{"t":"eq","v":"systemStart","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":610,"y":320,"wires":[["f3197161.26456"]]},{"id":"9ac6a6c6.8de0e8","type":"change","z":"12b33325.27e27d","g":"1333bb52.429db5","name":"Hub 1","rules":[{"t":"set","p":"payload","pt":"msg","to":"Hub 1 has restarted.","tot":"str"},{"t":"set","p":"priority","pt":"msg","to":"-1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":970,"y":280,"wires":[["d4762cac.6c5e1"]]},{"id":"77463c4c.9da2d4","type":"change","z":"12b33325.27e27d","g":"1333bb52.429db5","name":"Hub 2","rules":[{"t":"set","p":"payload","pt":"msg","to":"Hub 2 has restarted.","tot":"str"},{"t":"set","p":"priority","pt":"msg","to":"-1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":970,"y":320,"wires":[["d4762cac.6c5e1"]]},{"id":"d4762cac.6c5e1","type":"subflow:cb12a8bd.1d64c8","z":"12b33325.27e27d","g":"1333bb52.429db5","name":"","env":[],"x":1160,"y":300,"wires":[]},{"id":"1db0e593.2ea0ca","type":"moment","z":"12b33325.27e27d","g":"1333bb52.429db5","name":"","topic":"","input":"","inputType":"date","inTz":"America/Indianapolis","adjAmount":0,"adjType":"days","adjDir":"add","format":"LLL","locale":"en_US","output":"hub1Reset","outputType":"global","outTz":"America/Indianapolis","x":800,"y":280,"wires":[["9ac6a6c6.8de0e8"]]},{"id":"f3197161.26456","type":"moment","z":"12b33325.27e27d","g":"1333bb52.429db5","name":"","topic":"","input":"","inputType":"date","inTz":"America/Indianapolis","adjAmount":0,"adjType":"days","adjDir":"add","format":"LLL","locale":"en_US","output":"hub2Reset","outputType":"global","outTz":"America/Indianapolis","x":800,"y":320,"wires":[["77463c4c.9da2d4"]]},{"id":"83c9a93c.3e4bf8","type":"hubitat config","z":"","name":"Hubitat 1","usetls":false,"host":"192.168.4.40","port":"80","appId":"4988","nodeRedServer":"http://192.168.4.198:1880","webhookPath":"/hubitat/webhook_","autoRefresh":true},{"id":"8e2931b3.ce395","type":"hubitat config","z":"","name":"Hubitat 2","usetls":false,"host":"192.168.4.194","port":"80","appId":"196","nodeRedServer":"http://192.168.4.198:1880","webhookPath":"/hubitat2/webhook","autoRefresh":true}]
Title: Device poller
A better way to poll those pre-Z-wave Plus switches. It only polls the device when motion is active in the room. (No one can manually press a switch if they're not in the room.)
Summary
[{"id":"fd187656.080608","type":"inject","z":"f03992cc.3a6bd","g":"42a9e22c.f8cecc","name":"8 sec","repeat":"8","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":120,"y":1560,"wires":[["8d41f91f.944dc8","c44e9168.69fdc","90576dba.49d0f","f5ea51d9.53c4a","d296c6a0.079838"]]},{"id":"8d41f91f.944dc8","type":"hubitat device","z":"f03992cc.3a6bd","g":"42a9e22c.f8cecc","name":"Motion Kitchen","server":"83c9a93c.3e4bf8","deviceId":"464","attribute":"motion","sendEvent":true,"x":340,"y":1480,"wires":[["eebe0f4f.73c9"]]},{"id":"c44e9168.69fdc","type":"hubitat device","z":"f03992cc.3a6bd","g":"42a9e22c.f8cecc","name":"Motion Back Hall","server":"83c9a93c.3e4bf8","deviceId":"132","attribute":"motion","sendEvent":true,"x":350,"y":1520,"wires":[["28a67605.85544a"]]},{"id":"90576dba.49d0f","type":"hubitat device","z":"f03992cc.3a6bd","g":"42a9e22c.f8cecc","name":"Motion Shower","server":"83c9a93c.3e4bf8","deviceId":"403","attribute":"motion","sendEvent":true,"x":340,"y":1560,"wires":[["e16847d8.a9a318"]]},{"id":"f5ea51d9.53c4a","type":"hubitat device","z":"f03992cc.3a6bd","g":"42a9e22c.f8cecc","name":"Motion Bathroom","server":"83c9a93c.3e4bf8","deviceId":"2195","attribute":"motion","sendEvent":true,"x":350,"y":1600,"wires":[["e16847d8.a9a318"]]},{"id":"d296c6a0.079838","type":"hubitat device","z":"f03992cc.3a6bd","g":"42a9e22c.f8cecc","name":"Office Sensor","server":"83c9a93c.3e4bf8","deviceId":"3062","attribute":"motion","sendEvent":true,"x":340,"y":1640,"wires":[["416e5d51.084c64"]]},{"id":"416e5d51.084c64","type":"switch","z":"f03992cc.3a6bd","g":"42a9e22c.f8cecc","name":"active","property":"payload.value","propertyType":"msg","rules":[{"t":"eq","v":"active","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":510,"y":1640,"wires":[["282b91f.1db986e"]]},{"id":"e16847d8.a9a318","type":"switch","z":"f03992cc.3a6bd","g":"42a9e22c.f8cecc","name":"active","property":"payload.value","propertyType":"msg","rules":[{"t":"eq","v":"active","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":510,"y":1580,"wires":[["f826cde3.9ea0f"]]},{"id":"28a67605.85544a","type":"switch","z":"f03992cc.3a6bd","g":"42a9e22c.f8cecc","name":"active","property":"payload.value","propertyType":"msg","rules":[{"t":"eq","v":"active","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":510,"y":1520,"wires":[["60c66c9.3225294"]]},{"id":"eebe0f4f.73c9","type":"switch","z":"f03992cc.3a6bd","g":"42a9e22c.f8cecc","name":"active","property":"payload.value","propertyType":"msg","rules":[{"t":"eq","v":"active","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":510,"y":1480,"wires":[["4ab6391a.119068"]]},{"id":"4ab6391a.119068","type":"hubitat command","z":"f03992cc.3a6bd","g":"42a9e22c.f8cecc","name":"Kitchen Sink Light","server":"83c9a93c.3e4bf8","deviceId":"467","command":"poll","commandArgs":"","x":690,"y":1480,"wires":[[]]},{"id":"60c66c9.3225294","type":"hubitat command","z":"f03992cc.3a6bd","g":"42a9e22c.f8cecc","name":"Laundry Light","server":"83c9a93c.3e4bf8","deviceId":"270","command":"poll","commandArgs":"","x":680,"y":1520,"wires":[[]]},{"id":"f826cde3.9ea0f","type":"hubitat command","z":"f03992cc.3a6bd","g":"42a9e22c.f8cecc","name":"Shower Light","server":"83c9a93c.3e4bf8","deviceId":"175","command":"poll","commandArgs":"","x":670,"y":1580,"wires":[[]]},{"id":"282b91f.1db986e","type":"hubitat command","z":"f03992cc.3a6bd","g":"42a9e22c.f8cecc","name":"Office Closet Light","server":"83c9a93c.3e4bf8","deviceId":"3574","command":"poll","commandArgs":"","x":690,"y":1640,"wires":[[]]},{"id":"83c9a93c.3e4bf8","type":"hubitat config","z":"","name":"Hubitat 1","usetls":false,"host":"192.168.4.40","port":"80","appId":"4988","nodeRedServer":"http://192.168.4.198:1880","webhookPath":"/hubitat/webhook_","autoRefresh":true}]
Title Office scenes with PC control
Summary -
Part 1 - Work Alarm turns mode to "work Time" at 7:00AM If I am home and if it's a weekday.
Part 2 - Office Scenes when mode changes turn on/ off devices, mute/unmute computer and turn on/off computer monitors. This uses https://assistantcomputercontrol.com/ on a windows machine bypassing IFTT and dropbox by writing directly to a windows share.
discussed here Node-RED work and bed time flows
flow
"id": "16c8a7d5.e07098",
"type": "tab",
"label": "Week Day Alarm",
"disabled": false,
"info": ""
"id": "1ed910a2.658ddf",
"type": "cronplus",
"z": "16c8a7d5.e07098",
"name": "weekday 7AM",
"outputField": "payload",
"timeZone": "America/New_York",
"persistDynamic": false,
"commandResponseMsgOutput": "output1",
"outputs": 1,
"options": [
"name": "7AM weekday",
"topic": "7AM weekday",
"payloadType": "str",
"payload": "",
"expressionType": "cron",
"expression": "0 7 * * 1-5 ",
"location": "",
"offset": "0",
"solarType": "all",
"solarEvents": "sunrise,sunset"
"x": 120,
"y": 280,
"wires": [
"9457d1a7.e9a53"
"id": "9457d1a7.e9a53",
"type": "hubitat device",
"name": "Pat Richards’s iPhone XS max",
"server": "6b0c5f4f.a782d",
"deviceId": "8",
"attribute": "presence",
"sendEvent": true,
"x": 390,
"y": 280,
"wires": [
"eeecdf71.ac468"
"info": "If Pat's home"
"id": "eeecdf71.ac468",
"type": "switch",
"name": "if present",
"property": "payload.currentValue",
"propertyType": "msg",
"rules": [
"t": "cont",
"v": "present",
"vt": "str"
"checkall": "false",
"repair": false,
"outputs": 1,
"x": 650,
"y": 280,
"wires": [
"a1dc5328.f6f7b"
"id": "a1dc5328.f6f7b",
"type": "hubitat mode-setter",
"name": "Set WorkTime",
"modeId": "5",
"x": 860,
"y": 280,
"wires": [
"id": "fb8a7795.755618",
"type": "hubitat mode",
"name": "",
"sendEvent": true,
"x": 80,
"y": 440,
"wires": [
"3c2864af.26696c"
"id": "3c2864af.26696c",
"type": "switch",
"name": "",
"property": "payload.value",
"rules": [
"t": "eq",
"v": "Work Time",
"vt": "str"
"t": "eq",
"v": "Bed time",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 210,
"y": 440,
"wires": [
"2ac28f0b.a1b1b"
"172b1b3a.ba57b5"
"id": "2ac28f0b.a1b1b",
"type": "hubitat command",
"name": "Activate Worktime Scene",
"deviceId": "17",
"command": "on",
"commandArgs": "",
"x": 410,
"y": 360,
"wires": [
"1ebd0a36.e33af6"
"id": "172b1b3a.ba57b5",
"name": "Actvate Bedtime Scene",
"deviceId": "18",
"command": "on",
"commandArgs": "",
"x": 410,
"y": 480,
"wires": [
"5109eb60.350d44"
"id": "88df61cd.48dd1",
"type": "file",
"name": "Send command to ACC",
"filename": "/mnt/ACC/mute.txt",
"appendNewline": true,
"createDir": false,
"overwriteFile": "true",
"encoding": "none",
"x": 870,
"y": 360,
"wires": [
"1f0bffc.264b7"
"id": "1ebd0a36.e33af6",
"type": "change",
"name": "unmute command",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "mute:false",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 650,
"y": 360,
"wires": [
"88df61cd.48dd1"
"id": "5109eb60.350d44",
"type": "change",
"name": "mute command",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "mute:true",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 640,
"y": 480,
"wires": [
"9af79771.648408"
"id": "9af79771.648408",
"type": "file",
"createDir": false,
"encoding": "none",
"x": 870,
"y": 480,
"wires": [
"9466b2ed.4dc53"
"id": "86b1c8ae.7f64b8",
"type": "file",
"filename": "/mnt/ACC/run.txt",
"createDir": false,
"encoding": "none",
"x": 870,
"y": 540,
"wires": [
"id": "9466b2ed.4dc53",
"type": "change",
"name": "Monitors off",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "open:c:\scratch\screenoff 2.exe",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 630,
"y": 540,
"wires": [
"86b1c8ae.7f64b8"
"id": "1f0bffc.264b7",
"type": "change",
"name": "Monitors on",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "key_shortcut:SPACE",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 630,
"y": 420,
"wires": [
"463a73a0.22883c"
"id": "463a73a0.22883c",
"type": "file",
"filename": "/mnt/ACC/space.txt",
"createDir": false,
"encoding": "none",
"x": 870,
"y": 420,
"wires": [
"id": "6b0c5f4f.a782d",
"type": "hubitat config",
"z": "",
"name": "",
"usetls": false,
"host": "192.168.1.74",
"port": "80",
"appId": "45",
"nodeRedServer": "http://192.168.1.74:1880",
"webhookPath": "/hubitat/webhook",
"autoRefresh": true,
"useWebsocket": true
Can you share the scripts you are using, if they are not 'sensative' (passwords)?
Like mute.txt, and run.txt
no scripts :slight_smile: its in the message payload generated in the change node that precede each send command to ACC
Title - Backup Node Red
Summary
This flow is one I found, I'm not sure where though so unable to credit the person who created it. But thought it useful after I trashed my Node Red recently, due to an oversight on my part (oops).
This requires a piece of software installing on your PI called Resilio.
Instructions can be found here. You can also install on Windows too on their main website here.
To configure, browse to you PI IP and port 8888, you can then set up the pairing, and share the key to yourself, for another machine to access your backups.
The flow
You can modify the paths accordingly in the nodes "backup .node-red" and "delete older than 7 days" (and the number of days to keep). I added Pushover and receive a nice message when complete. Which I use as a reminder to copy the backup back.
The Flow
[{"id":"cad1c731.992228","type":"tab","label":"Pi-Backup","disabled":false,"info":"Rotating backup of .node-red folder"},{"id":"9f50db03.848e48","type":"exec","z":"cad1c731.992228","command":"sudo zip -rq /home/royski/sync/Backups/node-red-pi4-backup-$(date +%Y-%m-%d).zip /home/royski/.node-red","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"backup .node-red","x":410,"y":40,"wires":[["ef8d10db.d8e83"],["ef8d10db.d8e83"],["1bd3ae23.6e9f22"]]},{"id":"a7b79704.1505c8","type":"inject","z":"cad1c731.992228","name":"daily @2200","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"00 22 * * ","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":40,"wires":[["9f50db03.848e48"]]},{"id":"ad21052b.df89d8","type":"debug","z":"cad1c731.992228","name":"backup-log","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":990,"y":120,"wires":[]},{"id":"1bd3ae23.6e9f22","type":"switch","z":"cad1c731.992228","name":"check op success","property":"payload.code","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":230,"y":180,"wires":[["b329b40c.035f38"],["45de1bdb.02cd24"]]},{"id":"b329b40c.035f38","type":"exec","z":"cad1c731.992228","command":"sudo find /home/royski/sync/Backups/.zip -mtime +7 -type f -delete","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"delete older than 7 days","x":470,"y":140,"wires":[["ef8d10db.d8e83"],["ef8d10db.d8e83"],["954f68c7.dc2988"]]},{"id":"45de1bdb.02cd24","type":"change","z":"cad1c731.992228","name":"custom error msg","rules":[{"t":"set","p":"payload","pt":"msg","to":":red_circle: There was an error in Pi4 backup flow. Check logs.","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":260,"wires":[["ad21052b.df89d8","a45d5a55.614c48"]]},{"id":"954f68c7.dc2988","type":"switch","z":"cad1c731.992228","name":"check op success","property":"payload.code","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":490,"y":200,"wires":[["17260390.570bec"],["45de1bdb.02cd24"]]},{"id":"17260390.570bec","type":"template","z":"cad1c731.992228","name":"success msg","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":":white_check_mark: RPi4 Backup compelete.","output":"str","x":750,"y":120,"wires":[["ad21052b.df89d8","a45d5a55.614c48"]]},{"id":"ef8d10db.d8e83","type":"switch","z":"cad1c731.992228","name":"filter null","property":"payload","propertyType":"msg","rules":[{"t":"nnull"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":660,"y":40,"wires":[["ad21052b.df89d8"],[]]},{"id":"a45d5a55.614c48","type":"pushover api","z":"cad1c731.992228","keys":"54ad51a1.76db6","title":"","name":"","x":960,"y":260,"wires":[]},{"id":"54ad51a1.76db6","type":"pushover-keys","z":"","name":"Pushover"}]
The backup is scheduled, but can be changed in the first node, and executes here at 22:00 every day.
@aaiyar ok I tried copy and pasting the net monitoring flow and am getting an unexpected token at 2060 font color="cyan">{{msg.
any ideas
Yep me too.
It's the first one you post, internet speed test
Waiting in line - will fix it when I’m back home. Basically, its a linkout to an email node that sends me an SMS.
Title - All Lux events on 1 trigger
Summary - very basic, but posting as an idea that you can have all your lux based events on one lux trigger rather than using many. This could help minimize processing time, and allow all flows to operate smoother (in theory). For me it also helps troubleshooting. Also using Groups and colors to know which is an On/Off group
Flow
[{"id":"892e3f54.4c9e3","type":"group","z":"3e9ba05f.df3bc","name":"","style":{"stroke":"#999999","fill":"#bfdbef","fill-opacity":"0.47","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["95c0fdb.5b485","c08812cf.47394","dc7da0cf.7122c","e969ed8e.eac46","3df09ee1.4898d2","6f089d3c.c1f6f4","533b7de2.542fb4","2abcab9c.915934","29def96f.4d8636","d5aca7ad.c83d18","2628c75e.a7bd18","2aee9a01.736f96"],"x":34,"y":139,"w":1572,"h":222},{"id":"95c0fdb.5b485","type":"switch","z":"3e9ba05f.df3bc","g":"892e3f54.4c9e3","name":"+/- 1 Lux","property":"payload.value","propertyType":"msg","rules":[{"t":"gt","v":"1","vt":"str"},{"t":"lt","v":"1","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":440,"y":320,"wires":[["c08812cf.47394"],[]]},{"id":"c08812cf.47394","type":"hubitat command","z":"3e9ba05f.df3bc","g":"892e3f54.4c9e3","name":"Mnt Multch Light Off","server":"e40ec0b5.83be","deviceId":"526","command":"off","commandArgs":"","x":640,"y":320,"wires":[[]]},{"id":"dc7da0cf.7122c","type":"switch","z":"3e9ba05f.df3bc","g":"892e3f54.4c9e3","name":"On?","property":"payload.value","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":710,"y":220,"wires":[["533b7de2.542fb4"]]},{"id":"e969ed8e.eac46","type":"switch","z":"3e9ba05f.df3bc","g":"892e3f54.4c9e3","name":"+/- 100","property":"payload.value","propertyType":"msg","rules":[{"t":"lt","v":"100","vt":"str"},{"t":"gt","v":"100","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":1080,"y":220,"wires":[["d5aca7ad.c83d18"],[]]},{"id":"3df09ee1.4898d2","type":"hubitat command","z":"3e9ba05f.df3bc","g":"892e3f54.4c9e3","name":"Family Room - Bias Lighting On","server":"e40ec0b5.83be","deviceId":"2631","command":"on","commandArgs":"","x":1450,"y":220,"wires":[[]]},{"id":"6f089d3c.c1f6f4","type":"hubitat device","z":"3e9ba05f.df3bc","g":"892e3f54.4c9e3","name":"Living Room - -Harmoney Hub","server":"cd3ac91b.fa39d8","deviceId":"257","attribute":"switch","sendEvent":false,"x":510,"y":220,"wires":[["dc7da0cf.7122c"]]},{"id":"533b7de2.542fb4","type":"hubitat device","z":"3e9ba05f.df3bc","g":"892e3f54.4c9e3","name":"Front Porch Lux","server":"e40ec0b5.83be","deviceId":"455","attribute":"illuminance","sendEvent":false,"x":860,"y":220,"wires":[["2abcab9c.915934"]]},{"id":"2abcab9c.915934","type":"rbe","z":"3e9ba05f.df3bc","g":"892e3f54.4c9e3","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":975,"y":220,"wires":[["e969ed8e.eac46"]],"l":false},{"id":"29def96f.4d8636","type":"hubitat device","z":"3e9ba05f.df3bc","g":"892e3f54.4c9e3","name":"Front Porch Lux","server":"e40ec0b5.83be","deviceId":"455","attribute":"illuminance","sendEvent":true,"x":140,"y":320,"wires":[["6f089d3c.c1f6f4","95c0fdb.5b485"]]},{"id":"d5aca7ad.c83d18","type":"hubitat command","z":"3e9ba05f.df3bc","g":"892e3f54.4c9e3","name":"Set to 25%","server":"e40ec0b5.83be","deviceId":"2631","command":"setLevel","commandArgs":"25","x":1230,"y":220,"wires":[["3df09ee1.4898d2"]]},{"id":"2628c75e.a7bd18","type":"comment","z":"3e9ba05f.df3bc","g":"892e3f54.4c9e3","name":"TV Bias Lighting ON at dark if TV was on before dark","info":"","x":570,"y":180,"wires":[]},{"id":"2aee9a01.736f96","type":"comment","z":"3e9ba05f.df3bc","g":"892e3f54.4c9e3","name":"Mount Multh Off when day light","info":"","x":510,"y":280,"wires":[]},{"id":"e40ec0b5.83be","type":"hubitat config","z":"","name":"Devices Hub","usetls":false,"host":"10.13.9.11","port":"80","appId":"2532","nodeRedServer":"http://10.13.9.15:1880","webhookPath":"/hubitat/webhook","autoRefresh":true,"useWebsocket":false},{"id":"cd3ac91b.fa39d8","type":"hubitat config","z":"","name":"Apps Hub","usetls":false,"host":"10.13.9.12","port":"80","appId":"899","nodeRedServer":"http://10.13.9.15:1880","webhookPath":"/hubitat/webhook___","autoRefresh":true,"useWebsocket":false}]
A lot of things to learn here thank you everyone.
I can attest to that as long as you don't tattle on me for skype-n-driving. My husband tells me that it's their anniversary today and that you can get TWO DOZEN for the price of one. @aaiyar you're holding out?
Hour seriously? Guess I take Krispy Kreme for granted growing up near where they got started. Was interesting to watch when I lived in CA as they were opening stores and people would be carrying 2 dozen in the airport as if they were precious goods.
I did get two dozen. I gave one dozen to my godson's parents (mom is expecting his younger brother). I gave half-a-dozen to a medical resident that lives down the street. Not sure what happened to the last half-dozen. Couldn't be me - I'm diabetic.
There's a famous outlet in Japan next to our office there where I was told people used to queue down the street every day when it first opened. This practice continued for several years apparently, it was so so popular. Love 'em but they're not good for my diet (which is not really a diet at all, it's more just wishful thinking really) :rofl:
Donuts, too.
Bad donuts are hardware. KKs are definitely software.
