Node-Red Flow Samples/Sharing
Figured I'd add an example of a boolean usage, two contacts and one motion sensor control the garage light.
code
[{"id":"b06e26.d529e1d8","type":"hubitat device","z":"3cc9813d.7dcf4e","name":"Garage: Light","server":"f17566a9.c052b8","deviceId":"1043","attribute":"motion","sendEvent":true,"x":100,"y":400,"wires":[["ceeb1404.3c1c48"]]},{"id":"d7ab6ca8.ff371","type":"hubitat device","z":"3cc9813d.7dcf4e","name":"Laundry: Garage door","server":"f17566a9.c052b8","deviceId":"1234","attribute":"contact","sendEvent":true,"x":120,"y":280,"wires":[["fc75782.8dbf888"]]},{"id":"8b6a319.69fdbd","type":"change","z":"3cc9813d.7dcf4e","name":"STOP","rules":[{"t":"set","p":"payload","pt":"msg","to":"STOP","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":910,"y":320,"wires":[["744954f2.a1080c","d536d92f.bc83b8"]]},{"id":"f634bb21.8e6a48","type":"hubitat command","z":"3cc9813d.7dcf4e","name":"Garage: Light","server":"f17566a9.c052b8","deviceId":"1043","command":"off","commandArgs":"","x":1440,"y":380,"wires":[[]]},{"id":"b0cfe18d.ed17a","type":"switch","z":"3cc9813d.7dcf4e","name":"Check on","property":"payload.value","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1280,"y":380,"wires":[["f634bb21.8e6a48"]]},{"id":"306406ee.0e9a1a","type":"hubitat device","z":"3cc9813d.7dcf4e","name":"Garage: Light","server":"f17566a9.c052b8","deviceId":"1043","attribute":"switch","sendEvent":false,"x":1120,"y":380,"wires":[["b0cfe18d.ed17a"]]},{"id":"744954f2.a1080c","type":"stoptimer-varidelay","z":"3cc9813d.7dcf4e","duration":"3","durationType":"num","units":"Minute","payloadtype":"num","payloadval":"0","name":"","reporting":"last_minute_seconds","x":940,"y":380,"wires":[["306406ee.0e9a1a"],[],[]]},{"id":"b0dc2387.ed01e","type":"hubitat device","z":"3cc9813d.7dcf4e","name":"Garage: Garage door","server":"f17566a9.c052b8","deviceId":"179","attribute":"contact","sendEvent":true,"x":120,"y":340,"wires":[["fc75782.8dbf888"]]},{"id":"ceeb1404.3c1c48","type":"change","z":"3cc9813d.7dcf4e","name":"Motion to Bool","rules":[{"t":"set","p":"payload","pt":"msg","to":"msg.payload.value = "active" ? true : false","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":400,"wires":[["105677ac.b02e58"]]},{"id":"105677ac.b02e58","type":"BooleanLogicUltimate","z":"3cc9813d.7dcf4e","name":"","filtertrue":"both","persist":true,"sInitializeWith":"false","triggertopic":"trigger","outputtriggeredby":"all","inputCount":"3","topic":"result","x":540,"y":360,"wires":[[],["68f1c340.9f16dc"],[]]},{"id":"fc75782.8dbf888","type":"change","z":"3cc9813d.7dcf4e","name":"Contact to Bool","rules":[{"t":"set","p":"payload","pt":"msg","to":"msg.payload.value = "open" ? true : false","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":320,"wires":[["105677ac.b02e58"]]},{"id":"2aa141e9.6a8ebe","type":"hubitat command","z":"3cc9813d.7dcf4e","name":"Garage: Light","server":"f17566a9.c052b8","deviceId":"1043","command":"on","commandArgs":"","x":1440,"y":320,"wires":[[]]},{"id":"685f64ec.e603dc","type":"switch","z":"3cc9813d.7dcf4e","name":"Check on","property":"payload.value","propertyType":"msg","rules":[{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1280,"y":320,"wires":[["2aa141e9.6a8ebe"]]},{"id":"d536d92f.bc83b8","type":"hubitat device","z":"3cc9813d.7dcf4e","name":"Garage: Light","server":"f17566a9.c052b8","deviceId":"1043","attribute":"switch","sendEvent":false,"x":1120,"y":320,"wires":[["685f64ec.e603dc"]]},{"id":"68f1c340.9f16dc","type":"switch","z":"3cc9813d.7dcf4e","name":"True/False","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":710,"y":360,"wires":[["8b6a319.69fdbd"],["744954f2.a1080c"]]},{"id":"f17566a9.c052b8","type":"hubitat config","z":"","name":"","usetls":false,"host":"192.168.2.3","port":"80","appId":"3424","nodeRedServer":"http://192.168.2.9:1880","webhookPath":"/hubitat/webhook","autoRefresh":true,"useWebsocket":false}]
