Hub Update 1.1.6
#1
Hubitat Elevation Platform update 1.1.6 is now available:
Please note, the process takes about a minute to download (depending on your Internet connection) and extract the hub update, and 1-2 minutes to perform the update after you click 'Update Hub'. We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 1.1.5:
Platform Additions / Changes
  • Added button to cancel Z-Wave repair that is in process.
New Drivers and Devices
  • New drivers:
    • Virtual Temperature Sensor
    • Generic Z-Wave Button Controller (supports Fibaro KeyFob and Button, NodOn Soft and Octan remotes)
    • Zipato Siren (includes chime component device)
  • New driver features:
    • Zooz Power Strip (automatically create child device components)
    • Generic Z-Wave Repeater (add refresh command, and Power Source capability)
    • Generic Z-Wave Shade (fix level and on/off events)
New Built-in App Features
  • Mode Manager:
    • Added set mode with switches.
  • Hubitat Safety Monitor:
    • Added Night-Intrusion support.
  • Rule Machine:
    • New actions: Switches Per Mode, Activate Scene, Activate Scene Per Mode, and Delay (Cancel) Per Mode.
    • Added Lock Codes as Trigger Event or Condition.
    • Added Between Two Dates as Condition or Restriction.
    • Added new rule type: Schedule. Allows scheduling of actions by days of week and time, with optional wait period for second set of actions (e.g. turn on by schedule, off x minutes later).
    • Added action for Send HTTP Request: sends asyncGET to URL; allows %device% and/or %value% in URL for last event device and/or value.
    • Added choice for multiple music players.
  • Scene (upgrades available only for newly created Scenes):
    • Added optional transition time (device dependent).
    • Added option to ignore Off of activator switch: turning On activates Scene, but turning Off does nothing; default remains that turning Off turns off all devices in Scene.
    • Activator switch state now serves as indicator of scene fully set or not: On if scene fully set, Off if any element of scene changed.
  • Alexa Skill:
    • Added option to include Hue devices (are excluded by default).
  • Maker API:
    • Added option to enable or disable cloud and/or local access to endpoints (cloud access is off by default).
    • Added "arrived", "departed","startLevelChange", "stopLevelChange" to allowed commands
Bug Fixes
  • Rule Machine:
    • Fixed capture/restore bug.
    • Fixed disable with Private Boolean bug.
  • Dashboard:
    • Fixed iOS slider not registering changed value.
  • Maker API:
    • Fixed inconsistency between Name and Label in Devices endpoints. Label will now show label if set, and Name if not set. Name will be name.
  • Fixed bug causing Z-Wave network repair to stall on some devices.
  • Fixed issues with multiInstanceV1 command class
  • Fixed bug with modes containing special characters, affected Mode Manager and other apps.
    • Fixed bug when arming changed by external means.
    • Fixed bug for checking contact sensors while arming with Use All selected.
  • Scene
    • Fixed bug in Adjust Scene after adding additional device.
Locks
Feature request for Pending Cancellation
Fibaro 6 button keyfob
Rule still triggering even w/ private boolean as false
Unable to save RM rule if Boolean is true
I give up!
Mode Manager Issue - CONFIRMED BUG - SOLUTION
Groups and Scenes
Rule MachineĀ® Introduction
Mode Manager - Hub Update 1.1.6
Z-Wave Multi Channel (PE653)
Trigger help in RM
Add http calls to rule machine
Groups & Scenes Syncing
#2
Important Bug Fix Update
We pushed a small hot fix for a bug in Rule Machine. Version 1.1.6.112 is now available for download. All Rule Machine users should load this update if you updated to 1.1.6. Bug caused destruction of rules containing time conditions.
[SOLVED] RM rule corruption
#3
Hot Fix Release 1.1.6.114
This small hot fix has a few minor fixes for the Scene App:
  • Ignore Activate Switch Off fixed, now completely ignores the switch when option selected, thus preserving the switch state's tracking of the scene.
  • Scene cloning now clones all of the source Scene captured settings.
#4
Hot Fix Release 1.1.6.116
This small hot fix has two bug fixes in it:
  • Zooz 4-in-1 Sensor bug that affected motion getting stuck in active, thus leaving the device not working.
  • Scene bug with respect to accurately reflecting the scene state in the activator switch state.
Zooz 4 in 1 motion issues
