Aliexpress
AVATTO Tuya WiFi Zigbee Smart Light Switch Module,No Neutral Wire 2 Ways Control Mini DIY Breaker Work for Alexa, google home
Summary
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:54:22.965[debug](http://192.168.1.147/logs#)AAA Relay 3 refreshing
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:54:22.009[info](http://192.168.1.147/logs#)AAA Relay 3 Turning all child switches off
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:54:19.903[info](http://192.168.1.147/logs#)AAA Relay 3 Turning all child switches on
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:54:16.965[info](http://192.168.1.147/logs#)AAA Relay 3 Turning all child switches on
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:54:10.837[debug](http://192.168.1.147/logs#)AAA Relay 3 Parent createChildDevices
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:54:10.834[debug](http://192.168.1.147/logs#)AAA Relay 3 model: TS0011 buttons: 0
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:54:10.831[debug](http://192.168.1.147/logs#)AAA Relay 3 Parent deleteChildren
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:54:10.828[debug](http://192.168.1.147/logs#)AAA Relay 3 Parent setupChildDevices
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:54:10.824[debug](http://192.168.1.147/logs#)AAA Relay 3 sendZigbeeCommands : [he raw 0x7FC3 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x7FC3 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 0x7FC3 0x01 0x01 6 {A4C1388DA35221C8} {}, delay 2000, he cr 0x7FC3 0x01 6 0 16 0 600 {}, delay 2000, he rattr 0x7FC3 0x01 6 0 {}, delay 2000]
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:54:10.817[debug](http://192.168.1.147/logs#)AAA Relay 3 configure()..
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:54:10.814[info](http://192.168.1.147/logs#)AAA Relay 3 InitializeVars()... fullInit = true
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:54:10.811[debug](http://192.168.1.147/logs#)AAA Relay 3 Initializing...
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:54:04.080[debug](http://192.168.1.147/logs#)AAA Relay 3 sendZigbeeCommands : [he raw 0x7FC3 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x7FC3 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 0x7FC3 0x01 0x01 6 {A4C1388DA35221C8} {}, delay 2000, he cr 0x7FC3 0x01 6 0 16 0 600 {}, delay 2000, he rattr 0x7FC3 0x01 6 0 {}, delay 2000]
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:54:04.071[debug](http://192.168.1.147/logs#)AAA Relay 3 configure()..
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:55.196[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 00 cluster: 0002 attrId: null
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:55.191[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:catchall: 0000 0002 00 00 0040 00 7FC3 00 00 0000 00 00 140000, profileId:0000, clusterId:0002, clusterInt:2, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7FC3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[14, 00, 00]] (description:catchall: 0000 0002 00 00 0040 00 7FC3 00 00 0000 00 00 140000)
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:50.307[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 00 cluster: 0000 attrId: null
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:50.302[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:catchall: 0000 0000 00 00 0040 00 7FC3 00 00 0000 00 00 133EFBE6FEFF6934940000, profileId:0000, clusterId:0000, clusterInt:0, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7FC3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[13, 3E, FB, E6, FE, FF, 69, 34, 94, 00, 00]] (description:catchall: 0000 0000 00 00 0040 00 7FC3 00 00 0000 00 00 133EFBE6FEFF6934940000)
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:50.174[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 00 cluster: 0002 attrId: null
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:50.171[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:catchall: 0000 0002 00 00 0040 00 7FC3 00 00 0000 00 00 120000, profileId:0000, clusterId:0002, clusterInt:2, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7FC3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[12, 00, 00]] (description:catchall: 0000 0002 00 00 0040 00 7FC3 00 00 0000 00 00 120000)
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:46.860[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Parent switch off
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:46.856[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:7FC30100060A00001000, dni:7FC3, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0] (description:read attr - raw: 7FC30100060A00001000, dni: 7FC3, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00)
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:46.761[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Parent switch off
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:46.746[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:7FC30100060A00001000, dni:7FC3, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0] (description:read attr - raw: 7FC30100060A00001000, dni: 7FC3, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00)
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:45.174[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 00 cluster: 0002 attrId: null
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:45.170[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:catchall: 0000 0002 00 00 0040 00 7FC3 00 00 0000 00 00 110000, profileId:0000, clusterId:0002, clusterInt:2, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7FC3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[11, 00, 00]] (description:catchall: 0000 0002 00 00 0040 00 7FC3 00 00 0000 00 00 110000)
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:44.774[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 01 cluster: 0006 attrId: null
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:44.771[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:catchall: 0104 0006 01 01 0040 00 7FC3 00 00 0000 07 01 00000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:7FC3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00, 00, 00, 00]] (description:catchall: 0104 0006 01 01 0040 00 7FC3 00 00 0000 07 01 00000000)
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:44.661[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 01 cluster: 0006 attrId: null
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:44.657[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:catchall: 0104 0006 01 01 0040 00 7FC3 00 00 0000 07 01 00000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:7FC3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00, 00, 00, 00]] (description:catchall: 0104 0006 01 01 0040 00 7FC3 00 00 0000 07 01 00000000)
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:43.175[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 00 cluster: 8021 attrId: null
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:43.172[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:catchall: 0000 8021 00 00 0040 00 7FC3 00 00 0000 00 00 0B00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7FC3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[0B, 00]] (description:catchall: 0000 8021 00 00 0040 00 7FC3 00 00 0000 00 00 0B00)
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:43.071[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 00 cluster: 8021 attrId: null
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:43.068[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:catchall: 0000 8021 00 00 0040 00 7FC3 00 00 0000 00 00 0A00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7FC3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[0A, 00]] (description:catchall: 0000 8021 00 00 0040 00 7FC3 00 00 0000 00 00 0A00)
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.772[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 01 cluster: 0000 attrId: null
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.768[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:catchall: 0104 0000 01 01 0040 00 7FC3 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:7FC3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]] (description:catchall: 0104 0000 01 01 0040 00 7FC3 00 00 0000 04 01 00)
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.761[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 01 cluster: 0000 attrId: null
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.757[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:catchall: 0104 0000 01 01 0040 00 7FC3 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:7FC3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]] (description:catchall: 0104 0000 01 01 0040 00 7FC3 00 00 0000 04 01 00)
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.751[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Model Identifier: TS0011
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.748[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Applicaiton version: 44
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.745[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang ZLC version: 03
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.742[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Manufacturer name: _TZ3000_msxs2bv5
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.739[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:7FC301000068040042105F545A333030305F6D737873326276350000002003010000204405000042065453303031310700003003FEFF003000, dni:7FC3, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZ3000_msxs2bv5, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:44, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0011, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]] (description:read attr - raw: 7FC301000068040042105F545A333030305F6D737873326276350000002003010000204405000042065453303031310700003003FEFF003000, dni: 7FC3, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F6D737873326276350000002003010000204405000042065453303031310700003003FEFF003000)
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.530[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Model Identifier: TS0011
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.526[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Applicaiton version: 44
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.521[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang ZLC version: 03
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.517[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Manufacturer name: _TZ3000_msxs2bv5
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.495[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Parsed descMap: [raw:7FC301000068040042105F545A333030305F6D737873326276350000002003010000204405000042065453303031310700003003FEFF003000, dni:7FC3, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZ3000_msxs2bv5, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:44, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0011, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]] (description:read attr - raw: 7FC301000068040042105F545A333030305F6D737873326276350000002003010000204405000042065453303031310700003003FEFF003000, dni: 7FC3, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F6D737873326276350000002003010000204405000042065453303031310700003003FEFF003000)
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.207[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang sendZigbeeCommands : [he raw 0x7FC3 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x7FC3 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 0x7FC3 0x01 0x01 6 {A4C1388DA35221C8} {}, delay 2000, he cr 0x7FC3 0x01 6 0 16 0 600 {}, delay 2000, he rattr 0x7FC3 0x01 6 0 {}, delay 2000]
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.197[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang configure()..
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.192[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Parent createChildDevices
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.189[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang model: TS0011 buttons: 0
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.183[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Parent deleteChildren
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.180[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Parent setupChildDevices
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.170[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang sendZigbeeCommands : [he raw 0x7FC3 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x7FC3 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 0x7FC3 0x01 0x01 6 {A4C1388DA35221C8} {}, delay 2000, he cr 0x7FC3 0x01 6 0 16 0 600 {}, delay 2000, he rattr 0x7FC3 0x01 6 0 {}, delay 2000]
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.154[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang configure()..
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.151[info](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang InitializeVars()... fullInit = true
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.148[debug](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang Initializing...
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.146[info](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang model TS0011, manufacturer _TZ3000_msxs2bv5, application 44, endpointId 01
[dev:4397](http://192.168.1.147/logs#)2023-05-03 13:53:42.142[info](http://192.168.1.147/logs#)Zemismart ZigBee Wall Switch Multi-Gang **Parent installed**, typeName Zemismart ZigBee Wall Switch Multi-Gang, version 0.5.1 2023/04/15 9:16 AM, deviceNetworkId 7FC3, zigbeeId A4C1388DA35221C8
* [Documentation](http://docs2.hubitat.com/)
* [Community](https://community.hubitat.com/)
* [Videos](https://www.youtube.com/channel/UC_U6xPALM_7_VH1Cw0Nl4CQ)
* [FAQ](https://community.hubitat.com/t/frequently-asked-questions-faq)
