GIRIER Tuya ZigBee 3.0 Light Switch Module, Smart DIY Breaker 1 2 3 4 Gang Supports 2 Way Control
This is a hardcoded info/reminder and it will not go away when you actually paired the device with this driver pre-installed and the driver was selected automatically.
But I just got an idea, probably it is probably possible to distinguish between the two scenarios, will have to experiment when I have time.
That would be ideal situation, wouldn't it, rather than a re-pairing exercise. I guess there is no way to check to see if the driver was selected from a clean driver install, or was selected after.
Does Not work with this switch, Some idea how to fix it?
  • endpointId: 01
  • application: 48
  • manufacturer: _TZ3000_zmy4lslw
  • model: TS0002
If you provide some more details what exactly does not work and what you are trying, I may be able to help.
i cannot switch on and off. nothing.
What I can provide more?
This is a very reasonable question.
I will need some more days to put together a guide what information is needed to successfully troubleshoot problems with Zigbee devices, especially Tuya.
Is there a way to prevent these check-in messages?
The device (_TZ3000_zmy4lslw) is sending them every 2.5 minutes give or take. It makes an otherwise good device very chatty.
I have not found a way to reduce the check-in interval for the Tuya devices. This one sends a message to the hub every 150 seconds, and it seems this interval is hard-coded.
