[Wiki] webCoRE Documentation Digest
Problem solving:
There are four classes of issues commonly seen:
  • HE firmware is not up to date
    • do keep your HE firmware up to date
  • webCoRE is not installed properly, or not up to date
    • ways to resolve:
      • politely reboot your HE hub (HE console -> Settings -> "Reboot")
        • Let the hub settle after the reboot (3 mins or so)
        • then try again.
      • common resolution: (If using built-in, above suggestion should cover this)
        • Ensure webcore files are up to date:
          • if using the built-in webCoRE, updating your hub above has the latest webCoRE
          • if you have a user installed webCoRE:
            • you can use HPM 'repair' on webCoRE
            • or you can manually install / update the webCoRE source files (see install link in note above)
      • Less Common / not very common
        • you may have a db corruption on your HE hub
          • take a backup of your HE hub and store it on your computer
          • search for 'soft reset' in the HE forum can help
          • otherwise you may need to work with HE support if you still have db problems
