Hi Gary, sorry I missed replying to you.
I used the powerSource attribute as an indicator of the online/offline status of the battery-powered devices, before the time when I started to use the "Health Status" capability and the healthCheck attribute for this purpose. Now it is obsolete, but I keep it for backward compatibility with the previous drivers versions.
Has your TS0044 device started to report the battery percentage later?
In the latest versions, the power cluster is not bound explicitly to the hub, and the battery level reporting is not explicitly configured also, because it is 99% sure for me this was the reason for some Tuya remotes rebooting itself periodically and draining the battery. There were at least 2 such reports here, and I have found later the same symptoms described in Z2M forum. All my TS004F and TS0044 devices report the battery percentage remaining each 4 hours, without the need to configure the reporting period. But other models/manufacturers may behave differently.
If the battery percentage (or battery voltage) is not reported automatically after pairing the device again to HE, the battery reporting interval can be configured manually :
The device must be paired again to HE after changing the battery reporting interval - I will add this as an additional instruction in the next driver version.
P.S.
Great work on Tasmota Sync - Universal Multi Sensor driver, hope I will use it very soon with an Athom smart plug!
As I noted here Request adding fingerprints for iAlarm/Meian devices - #2 by jlv, I have this SOS button. It has Model TS0215A and manufacturer _TZ3000_pkfazisv. I installed this driver and paired the device. The fingerprint matched and this driver was assigned... but it doesn't work. No button events are every reported.
The device comes up with 4 buttons. When I click Configure, I get this in the logs:
Here the problem is that some of the TS0215A devices are single button devices, but other manufacturers TS0215A are 4-button controllers... I will temporary add TS0215A as a single button device (thank you for detecting the bug!), but I should add a customizable number of buttons in the next driver version.
If you enable the debug logs, do you see anything sent from the device when you hold the button for more than 3 seconds and then release it?
This is used in an event to declare what are the possible button operations, and the attribute value is used from some apps ( the Button Controller as example) to alter the app UI, depending on the possible button events... But if the device does not send these, nothing will happen..
I will research on what this button is capable of later.
In Home Assistant this button produces only one action (named 'emergency' in Z2M).
So the supportedValues for the SOS device should be only 'pushed' in Hubitat.
Update: added in the dev. branch version 2.6.5 2023-05-01 - TS0215A _TZ3000_pkfazisv iAlarm (Meian) SOS button fingerprint correction; number of buttons and supportedValues correction for SOS buttons;
I understand your point about re-pairing the remotes but to be honest I have had great battery life out of them as they will go completely dormant and rarely wake-up until a button press.
I have a spare one that I will try pairing with the new driver and see what happens with that one.
So if I understand correctly, the remotes are working just fine, the only issue that I see is that the healthStatus is reported as offline - and that is because the periodic battery reporting is disabled (not configured) and the remotes have not been used for a long time?
@kkossev Just stopping in to say thank you very much for your driver. Working well for me.
I had an Aeotec Quad Wallmote go bad recently and see that a replacement was $70. I decided to give the Tuya Scene Switch TS004F being sold on Amazon ($25) a try and I have to say I like it a lot better than the Wallmote. If I continue to have success with it, I plan to order several more from Alibaba ($13).
FYI Just added a brand new remote of the same kind and with the most recent driver it shows battery voltage but not an estimate of battery level. After enabling the advanced option and turning on battery reporting it does report battery level.
If you want to experiment, I think that it is still possible to use this Lidl remote in Hubitat :
Manually assign a Generic Zigbee Dimmer driver to the remote
Create a Group in HE apps - select this remote and one or more Zigbee bulbs
Make sure the 'Enable Zigbee Group Messaging' option is turned on.
Before clicking on the 'DONE' button, press the remote button to wake up this sleepy device.
Hubitat should send commands to add both the Zigbee bulb and the Zigbee remote in a new common Zigbee group. If the Lidl remote was awake at the time when the Zigbee group was created and accepted the AddGroup command, then you should be able to switch the bulb on and off and even to control the bulb brightness directly from the remote! Directly means that Hubitat hub is not involved at all, you should be able to control the bulb even if the HE hub is switched off!
The disadvantage is that the state of the Zigbee bulb (on/off, brightness level) may not be reflected back to Hubitat.
Maybe this was added by @ymerj and @tomw at some point and I'm just not aware of it, but to my knowledge you cannot use a button device from Home Assistant with HADB in this way.
You can however (and I do this myself) simply use the HE to HA integration from @jason0x43 to expose HE devices to HA, such as Hubitat virtual switches. Just set a 500ms auto OFF on the virtual switch so it simulates a momentary button press. On the HA side, you create a simple automation that turns on the Hubitat device or virtual switch when the button is pressed. A Basic Automation rule on Hubitat can then of course control just about anything you want when the Hubitat virtual switch turns on. If it's a device supported by Jason's integration, you could also just share the Hubitat device you want to control with HA and get the same result without the need for an additional automation rule on Hubitat, but this depends on the device you are trying to control of course.
I have buttons hooked up to Z2M in HA and they do report event trough HADB. That Lidl remote report "Action" state on button press (as a sensor). A specific driver in HADB would be needed to support it.
