Release 2.3.1 available
Hubitat Elevation Platform update 2.3.1 is now available:
Please note, the process takes about a minute to download (depending on your Internet connection) and extract the hub update, and 1-2 minutes to perform the update after you click 'Update Hub'. We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 2.3.0
New Drivers
  • Centralite Zigbee Dimmer (spectrum) Spectrum edition HA Dimmer Switch 3385001-ZHA
  • Lutron fan control driver (no level commands)
  • Aeotec Panic Button (DSA38)
  • Zooz Zen51 Dry Contact Relay
  • Zooz Zen52 Double Relay
  • Zooz 4-in-1 Sensor New
  • Heatit Z-Water
  • Heatit ZM Single Relay
  • Heatit ZM Thermostat
  • LIFX 4-Gang Switch
  • Lutron Shade (no level or switch commands)
  • Monoprice 6 Zone Audio Controller
  • Generic Component Audio Zone
  • Global Connect Relay Module [Global Cache GCRL3A]
  • Generic Component Sound Sensor
  • Generic Component Presence Sensor
  • Global Connect IR Module [Global Cache GCIR3]
  • Inovelli Z-Wave Red Scene Dimmer (replacement of "Inovelli Z-Wave Smart Scene Dimmer S2")
New Compatible Devices
  • Ikea ASKVADER Outlet strip using Ikea TRADFRI control outlet
  • Ring Outdoor Contact Sensor using Ring Alarm Contact Sensor G2 driver
  • Candeo rotary dimmer using Generic Zigbee Dimmer
  • KAIPULE Ceiling-Mounted Motion Sensor using BeSense Motion Sensor driver
  • Tuya, Blitzwolf and Third Reality water sensors using Generic Zigbee Moisture Sensor (no temp)
  • Visonic Glass Break Detector using Generic Zigbee Glass Break Sensor
  • ESTTECH EST-LED-GH001 grow light using Advanced Zigbee Bulb
New Driver Features
  • Add double Tapped event to Lutron Pico Driver
  • Centralite Keypad, enable motion events
  • Add position change commands to Generic Z-Wave Shade driver
  • Add turn on transition time preference to Caseta/RA2 Lutron Dimmer driver
  • Add option to disable battery reporting for line powered Zigbee valves
  • Added missing battery capability for Generic Z-Wave Shade driver.
  • Add change level capability to Nanoleaf Aurora driver
  • Added ChangeLevel capability to LIFX Color, LIFX CT, LIFX White, LIFX Color Legacy drivers.
  • Pushover: Added preference option for Emergency.
New App Features
  • Rule 5.1: Added “sticky” triggers, to trigger when a device state persists for selected period, and several other new features (see this post).
  • Rule Machine: Added ability to import a Basic Rule or Simple Automation Rule to create new equivalent Rule 5.1 (see this post).
  • Scene-1.2: Added option to pre-capture Scene devices before Scene activation, and restore when activator device turned off.
  • HubitatÂŽ Safety Monitor/HSM Custom Rule:
    • Added option to turn off switches upon alert.
    • Added support for gas detectors.
  • Thermostat Controller: Added option to use thermostat mode:off to induce idle operating state in controlled thermostat, as alternative to changing the setpoint.
  • Basic Rule:
    • Added set thermostat mode and thermostat fan mode
    • Added Control Music Player
    • Added Control HubitatÂŽ Safety Monitor
    • Added option to allow a restricted rule to continue to run when restriction occurs after the rule has been triggered (see this post ).
  • Simple Automation Rule: Added option to allow a restricted rule to continue to run when restriction occurs after the rule has been triggered (see this post ).
  • Motion Lighting: added option to use contact sensors in addition to motion sensors to trigger.
  • COLOR picker added to all apps that allow color selection.
  • Scene In-Use-By now visible on device page for Scene Activator device, for Motion Lighting, Rule 5.1, and Scene Transition.
  • All apps with time inputs now have Erase Time button to remove a time setting; was missing for mobile browsers, now easier for desktop.
  • Rule 5.1 has some new trigger optimizations. To take advantage of these, open your Rule 5.1 rules and hit Done.
Bug Fixes
  • Thermostat Controller: Fixed starup “null Controller” bug.
  • Motion Lighting:
    • Fixed bug with ‘Do turn on all even if any already on’.
    • Fixed bugs with options involving multiple contact sensors.
  • Rule 5.1/Button Rule 5.1:
    • Fixed Set Color Temperature per Mode bugs with level and fade.
    • Fixed mistaken options for Simple Conditional Action (Repeat While Expression and Wait for Expression).
    • Fixed missing date option for Certain Time sunset/sunrise.
    • Fixed bug with selecting Wait for Event after Wait for Expression.
    • Fixed bug that prevents using a string variable for a local file name.
    • Fixed bug setting Thermostat Scheduler mode based temperatures.
    • Fixed bug setting multiple DateTime variables.
    • Fixed bug with close valve.
    • Fixed a bug with timeout on Wait for Expression, where the timeout threw an error.
    • Fixed not setting In Use By correctly for variables used in %variable-name%.
    • Fixed paste of Simple Conditional action.
    • Fixed issue of Set Private Boolean for **This Rule** for clone and copy/paste to another rule.
    • Fixed bug with relative-to-device comparison in trigger.
  • All fan control drivers: Populate missing supported fan speed event.
  • Mirror, Lock Mirror: Fix failed lock notification including all locks rather than just the failed lock.
  • Pioneer AVR driver: Fix reversed mute status event.
  • Fixed issue with apostrophe in app name for export.
  • Fixed issue with Ignore Off option in Scene, if changed back.
  • Fixed LIFX SetExtendedColorZones command.
  • Fixed switch reporting not working for Sinope switch and dimmer drivers.
  • Zooz Zen77,Zen74,Zen72 handle basic report.
  • Fixed bugs in Thermostat Scheduler with setting mode temperatures or variable times from RM.
  • Lutron Thermostat driver: Fixed bug with setHeatingSetpoint where it threw an error.
  • Generic ZigBee Lock, fix duplicate events for Kwikset locks.
  • Fixed configuration input error on Zooz ZSE44
  • Nanoleaf Aurora driver:
    • Fix duplicate text in description text
    • Prevent setLevel 0 event
  • RGBgenie Controller ZB-3009/10, add missing number of buttons event.
  • Fixed Turn on Indicator configuration on Leviton DZ6HD Z-Wave Dimmer driver.
Platform Changes
  • C7: Optional Z-Wave firmware update to 7.17.1.
  • New getting started workflow.
  • Logs page shows pending hub actions, and apps/drivers generating excessive hub actions are marked in the logs.
  • New Setting option allows swapping one device for another.
  • Groovy version updated from 2.4.19 to 2.4.21.
  • Added /hub/advanced/databaseAlertThreshold and /hub/advanced/databaseAlertThreshold/123 endpoint to view and update database size alert threshold, respectively.
  • Hub's IP address is no longer permanently cached in the UI.
  • All app/device searches are now case insensitive.
  • Better rendering of Log page tabs on smaller devices.
  • Updated confirmation dialog on database restore.
  • New color pick up for setColor on device page.
  • Minor IFTTT update for future service update.
  • Added roomName to DeviceWrapper.
  • Long app labels are trimmed instead of throwing an exception.
  • Enables multiple destinations for HubAction with type LAN_TYPE_UDPCLIENT.
  • Reduced default state and event history size to 11 entries and max event/state age to 31 days.
  • Reduced hub mesh reconnect interval (when no other hubs are detected) from 5 minutes to 2 minutes.
Release 2.3.1.129 Available
Changes from 2.3.1.128
New App Features
Bug Fixes
  • Rule 5.1:
    • Fixed scheduling date in future year.
    • Fixed error thrown for line 8590.
    • Fixed error when pasting set time variable action.
    • Fixed UI display for ‘stays’ trigger.
    • Fixed failure to trigger on mode *changed*. You must open any rule that you setup or hit Done on with 2.3.1.128 for mode *changed*, and hit Done once on 2.3.1.129.
Platform Changes
  • Added an option to stop sharing all devices currently shared in Hub Mesh.
Release 2.3.1.130 Available
Changes from 2.3.1.129
New Drivers
  • Lutron Pico Legacy (previous version of driver without doubleTap capability)
New App Features
  • Rule 5.1: Added Wait for Event: Cloud Endpoint and Local Endpoint.
Bug Fixes
  • Rule 5.1:
    • Fixed bug with Set Variable to device attribute when special characters are in the variable name.
    • Fixed bug with edit Wait for Elapsed Time.
    • Fixed display bug with Last Event Device.
    • Fixed false trigger from removed End Point trigger.
    • Fixed error thrown by Custom Action metering.
    • Fixed creating new conditions for Required Expression.
    • Fixed bug with displaying correct state of Required Expression for Private Boolean.
    • Fixed bug with overflowed number values when setting variables to large numbers.
  • Dashboards:
    • Fixed bug with hub variables not being updated when changed outside dashboard
  • RGBgenie Controller ZB-3009/10, changed button count to 4 for EU device version.
  • Export/Import/Clone: Fixed error for line 356.
Platform Changes
  • Forces OS file buffer flush every 5 minutes.
  • Minor UI tweaks.
Release 2.3.1.132 Available
Changes from 2.3.1.130
Bug Fixes
  • Fixed horizontal scrolling on device events page for small screens.
  • Hub mesh now properly propagates disabled device flag.
  • Rule 5.1:
    • Fixed variable stays triggers.
    • Fixed UI break on *is empty* string variable comparison.
    • Fixed trigger subscriptions for all devices in a multi-device trigger.
  • HSM Rule: Fixed to clear out light alert captured values when armed.
Platform Changes
  • Hub mesh tweaks to child devices' enable/disable logic.
  • Getting started is now limited to empty (or reset) hubs. It also skips registration for hubs that are already registered.
Release 2.3.1.133 Available
Changes from 2.3.1.132
Bug Fixes
  • Fixed MissingMethodException in MakerAPI.
  • Rule 5.1: Fixed error with copy of Simple Conditional with NOT.
  • HSM Rule: Fixed lights turning on/off from disarm.
  • Motion Lighting: Fixed error thrown with scenes per mode from previous release being updated.
  • Scene 1.2: Fixed error thrown with ‘activator’.
Release 2.3.1.134 Available
Changes from 2.3.1.133
Bug Fixes
  • Rule 5.1: Fixed errors and Broken Actions with Set Variable to Device Attribute.
  • Dashboards: fixed "click logo to go to dashboards menu" issue on legacy dashboard links.
Release 2.3.1.135 Available
Changes from 2.3.1.134
Bug Fixes
  • Fixed missing local dashboard icons and incorrect fan commands on thermostat tile.
  • Fixed 'activator' error. If you experience this error, open Groups and Scenes (parent app) and hit Done. This error occurs with other apps, such as Motion Lighting or RM.
  • Fixed edit for DateTime Variables on Dashboards
Release 2.3.1.137 Available
Changes from 2.3.1.135
Bug Fixes
  • Motion Lighting: Fixed Activate Scenes.
  • Network settings page - reconnect section fix.
  • Rule 5.1: Fixed error from line 7804, Time Since Event for pre-existing rules.
Platform changes
  • Improved atomicState handling.
  • Increased memory allocation for hub process.
  • Improved WiFi reconnect logic.
Release 2.3.1.138 Available
Changes from 2.3.1.137
New App Feature
  • Rule 5.1: New button to allow abort of action editing, for when action editing gets hung up. If stuck, click on gear icon (upper right), then Go To App. Abort button on Rule page should clear up the problem. That action may need to be removed and replaced.
Bug fixes
  • Motion Lighting: Fixed multiple Scene activation.
  • Dashboards: Separate datetime field into date and time.
Platform changes
  • Tweaks to router ping and network reconnect logic.
Release 2.3.1.139 Available
Changes from 2.3.1.138
Bug fixes
  • Getting started properly handle skipping location entry.
  • Thermostat Scheduler: Fixed problems with EcoMode and UI.
Release 2.3.1.140 Available
Changes from 2.3.1.139
Bug fixes
*Rule 5.1: Fixed page crash from Time Since Event in IF-THEN action.
Release 2.3.1.141 Available
Changes from 2.3.1.140
Bug fixes
  • Fixed GB postal codes verification and location fetching.
Release 2.3.1.142 Available
Changes from 2.3.1.141
Bug fixes
  • Fix issue with Life360 Connector Application unable to retrieve a list of Family Members.
