Release 2.2.7 Available
Hubitat Elevation Platform update 2.2.7 is now available:
Please note, the process takes about a minute to download (depending on your Internet connection) and extract the hub update, and 1-2 minutes to perform the update after you click 'Update Hub'. We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 2.2.6:
Drivers and Devices
  • New drivers:
    • New Generic Component series drivers:
      • Lock, Omni Sensor, Multi Sensor, CO Sensor, Thermostat, Energy and Power Meters.
    • RGBGenie 5004 Button Controller using RGBgenie Wireless Dimmer Switch.
    • Mode Lighting eDin+ Network Controller using eDIN Network Controller (supporting dimmer/relay modules and control panels).
    • Wally Zigbee MultiSensor using Wally MultiSensor.
    • Generic Z-Wave Plus Dimmer
    • Jasco Smart Motion Sensor (52251)
    • Generic Z-Wave Plus Switch
    • Generic Z-Wave Plus Scene Switch
    • Generic Z-Wave Plus Contact Sensor
    • Generic Z-Wave Plus Scene Dimmer
    • Generic Z-Wave Plus Outlet
    • Jasco Flood Freeze Sensor (52247)
  • New compatible devices:
    • Sunricher HK-LN-SOCKET-A EU outlet strip using Generic Multi Endpoint Switch.
    • Sunricher HK-PLUG-A EU power reporting outlet using Generic Zigbee Outlet.
    • leakSmart and Tuya water valves using Sinope water valve.
    • Tuya Zigbee ODM outlets using Generic Zigbee Outlet.
    • Jasco Smart LED Bulb 52190 using Generic Z-Wave Plus Dimmer
    • Jasco 2-Button Hub/Panel Remote 53829 using Generic Z-Wave Plus Button Controller
    • Jasco 4-Button Hub/Panel Remote 53831 using Generic Z-Wave Plus Button Controller
    • Enbrighten Outdoor Smart Switch 14298 using Generic Z-Wave Plus Switch
    • Enbrighten Smart Switch 43074 using Generic Z-Wave Plus Scene Switch
    • Enbrighten Smart Switch 14293 using Generic Z-Wave Plus Scene Switch
    • Enbrighten Smart Switch 46201 using Generic Z-Wave Plus Scene Switch
    • Enbrighten Smart Switch 43072 using Generic Z-Wave Plus Scene Switch
    • Enbrighten Smart Switch 46202 using Generic Z-Wave Plus Scene Switch
    • UltraPro Smart Switch 39354 using Generic Z-Wave Plus Scene Switch
    • UltraPro Smart Switch 39348 using Generic Z-Wave Plus Scene Switch
    • Jasco Slim Door/Window Sensor 52249 using Generic Z-Wave Plus Contact Sensor
    • UltraPro Smart Dimmer 39351 using GE Enbrighten Z-Wave Smart Dimmer
    • Enbrighten Smart Dimmer 52252 using GE Enbrighten Z-Wave Smart Dimmer
    • Enbrighten Smart Dimmer 46204 using GE Enbrighten Z-Wave Smart Dimmer
    • Enbrighten Smart Dimmer 14296 using GE Enbrighten Z-Wave Smart Dimmer
    • Enbrighten Smart Outlet 55256 using Generic Z-Wave Plus Outlet
    • Enbrighten Smart Outlet 14267 using Generic Z-Wave Plus Outlet
    • Enbrighten Smart Fan Control 55258 using GE Smart Fan Control
    • Enbrighten Smart Switch 55249 using Jasco Z-Wave Dual Outlet
  • New driver features:
    • Added router and LQI logging option to Ikea switch and repeater drivers.
    • updateFirmware command added to the following drivers (see OTA firmware post ):
      • Generic Zigbee Outlet
      • Philips Dimmer Button Controller
      • Advanced Zigbee Bulb
      • Advanced Zigbee CT Bulb
      • Advanced Zigbee RGBW Bulb
      • Advanced Zigbee RGB Bulb
      • Generic ZigBee RGB Light
      • Generic ZigBee RGBW Light
      • Generic Zigbee Bulb
      • Generic Zigbee CT Bulb (dev)
      • Hue Motion Sensor
      • Hue Smart Button
      • Sengled Element Color Plus (and legacy)
      • Sengled Element Plus (and legacy)
    • Added Phase selection option to Sinope dimmer for model DM2550ZB.
    • Added parse description debug logging to debug logging preference for Sonos driver.
    • Lutron VCRX Output: Added ‘maintained’ option for output, as set in Essentials for maintained vs pulsed outputs.
New App Features
  • Basic Rule 1.0:
    • Added Lock triggers.
    • Allow multiple button devices.
    • Added minutes and seconds for durations.
  • Hubitat Safety Monitor:
    • User interface improvements.
    • Added bypass option for arming with open contact.
  • Rule-4.1:
    • Each HSM Rule can now be armed/disarmed/alerts in Rule-4.1.
    • Warn about custom attribute unsupported attribute type.
Bug Fixes
  • Basic Rule-1.0:
    • Fixed bug with time restrictions throwing errors.
    • Fixed bug with switch restriction not showing in app name.
    • Fixed bug with restriction subscriptions after wait.
    • Fixed throwing an error for decimal humidity events.
  • Fixed occasional parsing errors in Z-Wave meterV2-5.
  • Fix Zigbee 0x18 and 0x19 datatypes not returned as Little Endian when included within the readAttributes additionalAttributes map.
  • C-7: Fixed a bug in Z-Wave Multi-Channel causing erroneous Application Busy responses to Multi-Channel Endpoints reporting state updates. This could have caused extra traffic and lost packets under moderate load.
  • Mode Manager: Fixed a bug with before/after sunrise/sunset throwing an error.
  • Rule-4.1: Fixed a bug with custom attribute changed not triggering.
  • Simple Automation Rule-1.1:
    • Fixed bug with after sunset anti-action.
  • Fixed AppExecutor getChildDevices returning null vs an empty list as expected.
  • Fixed Lutron Integration error when clicking done and Interactive setup was being used along with the Telnet Direct option.
  • Fixed power reporting scale for Tuya Zigbee outlets.
  • Fixed bug in Generic Z-Wave Plus Button Controller driver when setting number of buttons in preferences instead of automatic discovery.
  • Lutron Telnet: Fixed bug with Enable Led Events preference.
  • Fixed a motion bug with Zooz Q Sensor driver introduced by device firmware changes.
  • Fixed a bug in HomeSeer Floodlight Sensor G2 driver preventing preference saving.
  • Fixed Mode Manager, Rule-4.1, Thermostat Scheduler and Motion Lighting time inputs.
  • Lutron Thermostat: Fixed setHeatingSetpoint.
  • Scene-1.2: Fixed setting state of activation device to accurately reflect scene fully set.
  • Logs and runtime stats UI tweaks.
  • Fixed a bug in Z-Wave supervisionv1 and supevisionv2 with null values causing invalid commandLength.
  • Fixed hub mesh event spamming.
  • Fixed wakeup on Generic Z-Wave Plus Smoke/CO Detector driver
  • Adjust default Z-Wave wake interval behavior when including devices.
  • Increased Supervision retry limit on Ring Alarm Contact Sensor G2 to be more resilient to S2 Re-Synchronization events.
  • Thermostat Scheduler: Fixed Eco Mode bad setting.
Platform Changes
  • New Z-Wave Command Classes:
    • meterv6
    • doorlockv2
    • doorlockv3
    • doorlockv4
    • zwaveplusinfov1
  • Zigbee OTA firmware update support. (see this post )
  • New Zigbee device command: List zigbee.updateFirmware().
  • New Zigbee IAS enroll response option: List zigbee.enrollResponse(Integer delay, additionalParams[destEndpoint:Integer endPointId]), use this option for binding to an endpoint that’s not the primary device endpoint.
  • New Zigbee IAS zone parser: Map zigbee.parseZoneStatusChange(String description), returns all attributes in addition to the device sourceEndpoint id.
  • ICMP Ping available to apps and drivers (see this post)
  • C-7: Periodic Z-Wave node neighbor updated to assist the SDK in making better routing decisions.
  • Rooms UI - a way to group devices. This is foundational, and there are no uses for rooms at this time beyond the basic organizational UI for them.
  • Database is defragmented/compacted on alternating hub shutdowns.
  • If corrupted database is detected on startup, UI shows suggested actions.
  • Increased cloud file download timeouts.
  • Expand/collapse apps' (grand)children in grid view.
Release 2.2.7.121 Available
Changes from 2.2.7.119
New App Features
  • Basic Rule 1.0: Added "Or Until" to allow waiting for multiple events, and added "Elapsed Time" as a Wait Until option. See this post.
Platform
  • Show child devices in room selection
Bug Fixes
  • Runtime stats search is now case insensitive.
  • Hub mesh processes event data correctly.
  • Hubitat Safety Monitor: Fixed backwards compatibility break with smoke and water alerts.
Release 2.2.7.122 Available
Changes from 2.2.7.121
New App Feature
  • Notifier: Added Power Meter notifications.
Bug Fixes
  • Fix for missing dashboard menu item.
  • First start workflow tweaks.
  • Scene-1.2: Fixed throwing an error on decimal level, hue, saturation from devices.
Release 2.2.7.123 Available
Changes from 2.2.7.122
New App Feature
  • Rule-4.1: Added 'Digital Switch' trigger/wait event.
Bug Fixes
  • Fix for remote access connection drop (affected only some users).
  • Fix for NullPointerException while calling unsubscribe().
Release 2.2.7.124 Available
Changes from 2.2.7.124
New App Feature
  • Basic Rule: Added Power Meter support, including power staying above or below a threshold for period of time.
Platform
  • Expand/collapse all on rooms, devices, and apps pages.
  • App level expand/collapse on apps page.
Bug Fixes
  • Fix for occasional missing child devices on apps page.
  • Basic Rule: Fixed bug with contacts remaining open for time.
  • Rule-4.1: Fixed bug with cancellation of Waits from other rules.
Release 2.2.7.125 Available
Platform
  • Added Ethernet auto speed negotiation/fixed 100mbps switch to Networking settings.
Bug Fixes
  • Device list page: fixed misaligned child devices when parent has a Zigbee id.
  • C7: Adjusted failed node removal process and added additional logging.
  • Notifier: Fixed error thrown for decimal battery level.
Release 2.2.7.126 Available
Changes from 2.2.7.125
Bug Fixes
  • Fix for a possible concurrency issue if code for two different apps is saved at the same time.
Release 2.2.7.128 Available
Changes from 2.2.7.126
Platform
  • Performance and security updates
