If you'd like to nominate a specific switch or dimmer that works with Hubitat Elevation, and exceeded your expectations this year, in terms of reliability and ease of use (it doesn't have to be released in 2023), please drop a comment below* with the make and model of your favorite device.
The products (comments) that receive most likes will be selected for the top 5 Most Popular Switches and Dimmers in 2023.
*NOTE : please use the comments below to nominate one product/reply. If you'd like to nominate multiple devices, please add a comment for each product.
Comments that do not nominate a product or duplicates will be removed from the thread.
If you share a link to a product, please clearly disclose affiliate links, otherwise the link will be removed.
My go-to for a dimmer is Inovelli’s Blue Series (Zigbee) 2-1. Model number (VZM31-SN).
This device can act as a dimmer and a switch, is pretty easy to setup and has a TON of options, from a usable config button (that can be used for rules and such) to multi-taps on the up and down paddles.
It also has a LED switch that can be used to provide notifications - very useful to know that the garage door was left open! (And for a bunch of other things… )
I remodeled my two bathrooms this year. I decided to go Z-Wave and give Zooz products a chance. I used the 700 series of dimmers and switches and have been pleased with every aspect.
A great switch for 3- or 4- way circuits. Why? Not only are they reliable and solid performers, but because the dimming and dim level light bar are at every switch, including the companions.
Here in Straya, I’d say the Aeotec Nano range and Fibaro range of zwave modules are easily the most popular options for lighting.
They would typically be installed behind Clipsal switch plates with Clipsal momentary switch mechanisms (the system is modular). Eg the Iconic range that lets you choose switch caps with different icons:
