Fixed.
Linked
i need Hyundai HT Drivers for hubitat please
Iβm not at all familiar with Hyundaiβs platforms for connected cars, so this might be related to your system but I believe the only potentially related thread is here:
Edit: actually it looks like Hyundai HT has nothing to do with Hyundai cars.
https://www.hyundaiht.co.kr/product/en/
Since this thread is for device drivers developed by the community that already exist, please consider starting a new thread if youβd like to discuss more about this Hyundai smart home platform.
thank you for your response actually I'm not talking about the Hyundai cars l'm talking about Hyundai smart home they have a product for smart home solution so please take a look at this link bellow
thank you very much.
There is this thread : [Updated and re-released by a new developer] Rheem EcoNet Integration - #43 by dman2306. which is a new Rheem driver. It worked for me, so wondering if the list should be updated?
Hi, am trying to use this driver
for a tuya zigbee 1 gang wall switch. drivers contain the device definition but didn't work
Manufacturer name: _TZE200_oisqyl4o (already on the driver)
ZLC version: 03
Model Identifier: TS0601
Applicaiton version: 44 (on drivers is defined as 42)
this is the log from HE
dev:9182023-05-29 10:09:57.880 PMinfoRefreshing...
dev:9182023-05-29 10:09:57.783 PMdebugThis device have only: 1 button, Child devices not needed.
dev:9182023-05-29 10:09:57.782 PMdebugParent createChildDevices
dev:9182023-05-29 10:09:57.780 PMinfomodel: _TZE200_oisqyl4o buttons: 1
dev:9182023-05-29 10:09:57.771 PMdebugParent deleteChildren
dev:9182023-05-29 10:09:57.769 PMdebugParent setupChildDevices
dev:9182023-05-29 10:09:57.767 PMwarnDebug logging will be automatically disabled after 30 minutes!
dev:9182023-05-29 10:09:57.766 PMinfoInitializing...
dev:9182023-05-29 10:09:17.643 PMdebug[raw:catchall: 0104 EF00 01 01 0040 00 EFCF 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EFCF, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:9182023-05-29 10:09:17.590 PMinfoTurn all switches OFF
dev:9182023-05-29 10:09:17.072 PMdebug[raw:catchall: 0104 EF00 01 01 0040 00 EFCF 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EFCF, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:9182023-05-29 10:09:16.930 PMinfoTurn all switches ON
dev:9182023-05-29 10:03:54.099 PMerrororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: user_driver_Moes_1_31_Moes_ZigBee_Wall_Switch_1_2_3_Gang_1014.ping() is applicable for argument types: () values: []
Possible solutions: find(), print(java.lang.Object), print(java.lang.Object), print(java.io.PrintWriter), find(groovy.lang.Closure), run() (method ping)
dev:9182023-05-29 10:01:01.234 PMerrororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: user_driver_Moes_1_31_Moes_ZigBee_Wall_Switch_1_2_3_Gang_1014.checkPresence() is applicable for argument types: () values: [] (method checkPresence)
dev:9182023-05-29 10:00:58.631 PMdebug[raw:catchall: 0104 EF00 01 01 0040 00 EFCF 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EFCF, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
if i phisically turn it ON i get this on the debug log.
[raw:catchall: 0104 EF00 01 01 0040 00 EFCF 01 00 0000 02 01 00350101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EFCF, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 35, 01, 01, 00, 01, 01]]
when phisically OFF , this.
[raw:catchall: 0104 EF00 01 01 0040 00 EFCF 01 00 0000 02 01 00340101000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EFCF, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 34, 01, 01, 00, 01, 00]]
Probably worth posting your question on a new Topic here on the Community, rather than here on the Wiki page for drivers. Unfortunately I can't help you with your issue, though...
Hi,
I created several drivers for z-wave devices more used in Europe:
For the Remotec/ZVIDAR Z-TRV-V01 : [RELEASE] ZVIDAR/Remotec Z-TRV-V01 Thermostat Radiator Valve Driver with secure S2 support
For the Qubino DIM Dimmer and Smart Plug 16A: [RELEASE] Qubino DIM Dimmer and Smart Plug 16A Drivers
For the Heatit ZM Dimmer 250W: [RELEASE] Heatit ZM Dimmer 250W with secure S2 support
For the Aeotec Smart Switch 7 EU: [RELEASE] Aeotec Smart Switch Driver 7 EU version
and the Shellt Wave 1PM: [RELEASE]Shelly Wave 1PM Driver
Cheers Rene
Rene,
Nice work! If you haven't already, please update the first post in this thread with your additional entries and links to your threads for each. The first post is a Wiki post that anyone can edit. ![]()
Thanks, didn't know that. Just did add them.
I just published:
rnoia/DirecTV-IP-Control-for-Hubitat: Hubitat driver for DirecTV IP control of receivers (github.com)
and is posted in the community:
[RELEASE] DirecTV satellite receiver direct, local, IP-based control -
Custom Apps and Drivers / Custom Drivers - Hubitat
A post was split to a new topic: Struggling to get started with Leviton Z-Wave devices
I have been searching the forum for EcoSmart Button and it looks like everyone gave up on it back in 2020. Is this still correct? I can find it @ Database of Zigbee devices compatible with ZHA, Tasmota, Zigbee2MQTT, deCONZ, ZiGate and ioBroker
If the button pairs to your HE hub and stays connected, and you see in the device web page 'Device Details' - data section the following :
- model: 6ARCZABZH
- manufacturer: ZBT-CCTSwitch-D0001
then create a new thread in this forum, and I will follow up there.
Thanks for the reply! I have not purchased the hub yet, I am still on Smartthings & HA. Hence the reason I asked. Tired of updates breaking in HA & Smartthings, so looking for something more local and less headaches. I am also considering Homey Pro, where I see they will work.
This device may be one of the few Zigbee devices that still use Zigbee Group broadcasts, and it may not work with Hubitat.
However, don't let this exception affect your final decision. Hubitat Elevation is a great platform, despite still filtering the inbound Zigbee messages. This is no longer a problem with IKEA remotes after IKEA's latest firmware updates. As for the EcoSmart buttons, they are not available here, so I am unsure if anything has changed in the last few years.
Thanks for your help @kkossev
Got a small problem...
I was away when my girlfriend got us some new bulb, it was needed.
She checked the list on the forum... good GF ![]()
but now it seems there is no driver in the first post.
I already tried some drivers like generic etc.
The E27 innr 'comfort' dimmable warm/cold white bulb get's connected to hubitat but i can't change anything, not 'on' or 'off'...
Could anybody save my from my GF saying 'useless list... stupid hub... gonna leave you'
