I just confirmed your #3 issue and sent to Zooz, will see what they say about it.
I have confirmed that the other sensors do not report changes when motion is active. Also when they do finally report it is very delayed. Going from bottom up on this log snip the last lux reading was 40 something and then I held the sensor with my finger over top of the lux sensor, you can see multiple motion active reports over a minute. I then pointed it at the wall in the dark and after about another minute it reported the 0 lux. Then I turned it around again towards me and pointed a light directly at the sensor from 3:33 - 3:37 (5 minutes), did not get any lux reports. So then I turned it at the wall again but this time pointed the light at the wall so it would pick up the light (last reading still showing 0). Once there was not any more motion it finally reported the change about 2 minutes later.
It was reported and they were informed over 2 years ago, I wouldn't hold my breath on fixing this defective device. As you will see from reading the thread below, Zooz's "remedy" is they created a new different device for you to purchase.
New ZSE40 driver which allows you to disable the double reports on the ZSE40 FW 32.x
This will cut the traffic every 7s in half (from 2 reports to 1). I have tested with one device going on C7 with no issues, will be testing with 3 in a couple of weeks.
edit: to summarize I think it works for the most part but there may be some battery reporting issues and it's probably a good idea to pair with no security.
Thanks @erktrek, yeah I think it's still not completely 100% ok and the names of the devices confuses me a little 500 vs. 500 V2 vs. 700 I join all my devices with security none to save the hassle down the road.
It's the 500 that's problematic on the C7. It needs joined with no security. 700 series is fine (anything besides s0 is fine, but prefer to pair with no security)
Here is my setup and I have not noticed any significant problems. I am using my custom driver and disabled the duplicate reporting (Parameter 8) on the ZSE40 500 series devices.
ZSE40-700: S2, High Traffic Area (family room)
ZSE40 (500): S0, High Traffic Area (my office)
ZSE40 (500): None, Low Traffic (hallway)
ZSE40 (500): None, Low Traffic (bathroom)
ZSE11 (500): S2, Low Traffic (bathroom)
I might re-pair my office sensor to no security eventually, using Zniffer I can see a lot of stuff flying back and forth due to the extra overhead of the S0 security. When it goes into a route change frenzy stuff really starts flying. I could see if you had 3+ of those in a high traffic area all on S0 where it could degrade the mesh.
And even then it will be problematic. I had 3 of those on a C7 and it caused some issues. I fixed it by moving them to another hub that was a C5.
I just received a 700 series of that sensor that I will be installing in the coming days. Looking forward to seeing how it works. Hoping that it will eventually allow the use of Long Range (LR) technology!
I just installed a ZSE40 700 V2 on my C7 hub. It seems to report everything BUT motion, which I need. I want to use it to detect someone heading for my alarmed front door, from the inside
I think I figured out what is going on. I excluded it and added to my dev hub and it works great. The only difference is the sensor is right next to the hub in this case.
So, I think if I pair it really close to the hub , then move it to the next room it may be ok, will try later.
You can try, but in the end it's a zooz issue. During beta they did say they somewhat were handled, I'd just assume use the stick method to pair them with no security for the 500 series version and skip with the 700 series
I have had 3 running since before the updated firmware with no issues. Optimized the settings with my custom driver. Definitely even better with the Z wave upgrade while I was beta testing.
Also have a 700 series and paired with S2 which works fine using my custom driver.
