Zigbee 3.0 button controller $8.88 USD at home Depot, includes cct bulb
Hello, saw this at home Depot and grabbed one. includes a bulb and a 4 button remote for $8.88 both of which are zigbee 3.0 certified. Tried to pair it to my hubitat but got no response, anyone think there's any hope for integrating this? Looked up fcc id, and it's made by leardson
EDIT-Apologies-This is posted in the wrong topic-DUH
Did you mean you tried the remote and it wouldn't pair or that you tried the bulb and remote and neither would pair? I'd be surprised if the bulb didn't (the box and manual both mention SmartThings, and both Hubitat and SmartThings users have what could be previous generations of this brand of bulbs working, if not this exact one).
For the remote, that's less surprising: the only thing I see mentioned in the manual is Touch Link. Some of these will work (if they respond to requests from the hub for binding), but many won't (like the Ikea 5-button dimmer and some Zigbee remotes). If you have a Hue Bridge, I suspect it might work there if you pair the remote to the Hue Bridge using Touch Link (manually initiated with a third-party app) and are able to also add the bulb to that network, same as the Ikea 5-button dimmer). Someone who knows more about Zigbee and is able to get their hands on one could tell for sure about Hubitat, but not all hope may be lost if you have Hue.
Did you try factory resetting both before trying to join to Hubitat? The two devices are Zigbee 3.0. So, if they come out of the box paired to each other, they won't be able to pair to Hubitat. However, once you reset them, they should be able to join the ZHA Hubitat network. Now, whether it will work with Hubitat is anybody's guess. I'm almost sure that the bulb will work with Hubitat. But the remote is a different story. They have a bunch of them at my local Home Depot too. I'll probably pick one up tomorrow and see what I can see.
Not sure about this device. If it’s truly Zigbee 3.0, I would have thought it would support pairing with a hub. A friend tried to pair it to his SmartThings v2 hub and didn’t have any luck there either.
Can probably “authorize” it with a Hue bridge and then pair directly to a bulb without stealing the pairing, much like you were able to do with the Lutron Connected Bulb Remote. Does it say it can reset a smart bulb? That would be a handy tool to have around for those that don’t own a Lutron Connected Bulb Remote, or don’t want to buy a Hue dimmer to reset bulbs.
I did reset originally, got nothing, however tried again this morning and it paired as device! What I did different was to start pairing in the hub then reset the remote, while the hub was already searching.
here's the data:
@SmartHomePrimer it does says it can unpair a bulb, here's the instructions ;
Off to work now, will try bulb later today
Thanks everyone
I saw the bulb in the Zigbee certification a few months ago. I avoid the Homeless Despot but I'll have to stop by and get a few to try also. Price is good with the sale.
Hopefully the Zigbee 3.0 is better. I bought tons of Ecosmart Zigbee ZLL GUI10 bulbs before and they were not very reliable. Kept dropping offline on me. Luckily, they were also cheap and I pretty much have them away when I sold my Wink2.
Funny, homeless despot. Anywho the remote looks really sharp, and if some really sharp minds could figure out a driver, this would be a great little device. I saw ecosmart discussions over on ST, but those were from years ago. This device and bulb are relatively new and only went thru FCC in the first half of 2019, and with zig 3.0 my hopes are up
It doesn't work with any generic Zigbee remote driver on the list?
blinking
I have heard the Home Depression also. I heard both somewhere and now interchangeably use them to refer to the Home Depot because I seem to find the place unsatisfactory everytime I try to go there.
In Canada, they improved with years. 10 years ago, find somebody helpful (and sometimes just find somebody only in the store) was very difficult. Now, at least, they say hello...
I'm dying to try, but my HA addiction has me at work, making money to buy more HA stuff.
I'll test later tonight. You guys think my boss would let me go home early if I told him I have some important buttons to press at home?:grin:
Of course the boss will let you go. Get him/her addicted to HA as well so you won't even have to ask next time.
Here's some messages from the logs. Initially had driver set to Iris 1 button, pressed each remote button once, then changed driver to other button devices . Nothing ever registered in the device events, not parsing since no driver exists, but found this;
Past Logs
dev:39142019-12-10 05:58:27.657 pm debugparse: read attr - raw: 3CE60100010820002020, dni: 3CE6, endpoint: 01, cluster: 0001, size: 08, attrId: 0020, encoding: 20, command: 0A, value: 20
dev:39142019-12-10 05:53:57.206 pm warnconfigure...
dev:39142019-12-10 05:53:52.010 pm warnconfigure...
dev:39142019-12-10 05:53:48.573 pm infoskipped: cluster:0001, [raw:catchall: 0104 0001 01 01 0040 00 3CE6 00 00 0000 07 01 00, profileId:0104, clusterId:0001, clusterInt:1, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:3CE6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00]]
dev:39142019-12-10 05:53:48.571 pm debugparse: catchall: 0104 0001 01 01 0040 00 3CE6 00 00 0000 07 01 00
dev:39142019-12-10 05:53:36.964 pm infoAay remote battery is 100%
dev:39142019-12-10 05:53:36.960 pm debuggetBatteryResult: 32
dev:39142019-12-10 05:53:30.618 pm warnPresence timeout set to: 120 seconds
dev:39142019-12-10 05:53:30.593 pm warndescription logging is: true
dev:39142019-12-10 05:53:30.593 pm warndebug logging is: true
dev:39142019-12-10 05:53:30.592 pm infoupdated...
dev:39142019-12-10 05:53:21.507 pm debugrefresh
dev:39142019-12-10 05:53:21.456 pm warnconfigure...
dev:39142019-12-10 05:52:22.152 pm infoAay remote battery is 100%
dev:39142019-12-10 05:52:22.151 pm debuggetBatteryResult: 32
dev:39142019-12-10 05:52:22.150 pm debugparse: [raw:3CE60100010A20002020, dni:3CE6, endpoint:01, cluster:0001, size:0A, attrId:0020, encoding:20, command:01, value:20, clusterInt:1, attrInt:32]
dev:39142019-12-10 05:52:22.141 pm debugmissed: [raw:catchall: 0104 0001 01 01 0040 00 3CE6 00 00 0000 07 01 86000100, profileId:0104, clusterId:0001, clusterInt:1, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:3CE6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[86, 00, 01, 00]]
dev:39142019-12-10 05:52:22.139 pm debugparse: [raw:catchall: 0104 0001 01 01 0040 00 3CE6 00 00 0000 07 01 86000100, profileId:0104, clusterId:0001, clusterInt:1, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:3CE6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[86, 00, 01, 00]]
dev:39142019-12-10 05:52:09.040 pm debugrefresh
dev:39142019-12-10 05:52:09.008 pm warnconfigure...
dev:39142019-12-10 05:52:06.491 pm warndescription logging is: true
dev:39142019-12-10 05:52:06.491 pm warndebug logging is: true
dev:39142019-12-10 05:52:06.490 pm infoupdated...
dev:39142019-12-10 05:52:01.354 pm debugrefresh
dev:39142019-12-10 05:52:01.330 pm warnconfigure...
dev:39142019-12-10 05:51:51.661 pm debugrefresh
dev:39142019-12-10 05:51:51.630 pm warnconfigure...
dev:39142019-12-10 05:51:11.851 pm debugrefresh
dev:39142019-12-10 05:51:11.822 pm warnconfigure...
dev:39142019-12-10 05:50:35.824 pm debugrefresh
dev:39142019-12-10 05:50:35.792 pm warnconfigure...
dev:39142019-12-10 05:48:43.683 pm debugparse: [raw:catchall: 0104 0402 01 01 0040 00 3CE6 00 00 0000 01 01 , profileId:0104, clusterId:0402, clusterInt:1026, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:3CE6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[]]
dev:39142019-12-10 05:48:27.392 pm infoAay remote battery is 100%
dev:39142019-12-10 05:48:27.391 pm debuggetBatteryResult: 31
dev:39142019-12-10 05:48:27.386 pm debugparse: [raw:3CE60100010A2000201F, dni:3CE6, endpoint:01, cluster:0001, size:0A, attrId:0020, encoding:20, command:01, value:1F, clusterInt:1, attrInt:32]
dev:39142019-12-10 05:48:27.347 pm debugparse: [raw:catchall: 0104 0001 01 01 0040 00 3CE6 00 00 0000 07 01 00, profileId:0104, clusterId:0001, clusterInt:1, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:3CE6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00]]
dev:39142019-12-10 05:48:24.165 pm debugparse: [raw:catchall: 0000 8021 00 00 0040 00 3CE6 00 00 0000 00 00 3400, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3CE6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[34, 00]]
dev:39142019-12-10 05:48:24.121 pm debugparse: [raw:catchall: 0000 8021 00 00 0040 00 3CE6 00 00 0000 00 00 3200, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3CE6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[32, 00]]
dev:39142019-12-10 05:48:24.109 pm debugparse: [raw:catchall: 0000 8021 00 00 0040 00 3CE6 00 00 0000 00 00 3300, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3CE6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[33, 00]]
dev:39142019-12-10 05:48:14.533 pm warndescription logging is: true
dev:39142019-12-10 05:48:14.532 pm warndebug logging is: true
dev:39142019-12-10 05:48:14.531 pm infoupdated...
dev:39142019-12-10 05:48:03.546 pm warnconfigure...
Bulbs pairs as a RGBW bulb, changed it to Zigbee Color Temperature bulb and it works fine.
The Homeless Despot was in great form. Went to one that said it had 35 waited 20 minutes for them to find it but they never found it. So went to another Homeless Despot and they were there.
I also bought a kit.
The bulb works fine with the "Generic Zigbee CT Bulb (dev)" driver.
The remote does pair, but I could not get any response out of it - having tried most of the Zigbee button controllers.
Having said that, there is another remote that looks exactly like it - the Aurora AOne Smart Remote. That supposedly works with Smartthings UK (see post #156), and the Ecosmart remote is supposed to work with Smartthings here in US.
Now if one of our Hubitat experts can find a ST driver for us that might work, would be helpful!
Great detective work. I saw the same thing "works with ST" but zero evidence of a driver. It just paired as "thing" to my ST V2 hub.
And worse case, ST puts out a driver and I can use the remote with my ST hub using hubconnect to connect it to HE
I've got 10 of these - when I bought them right after thanksgiving the 2-pack of bulbs without the remote wasn't available. So far the bulbs are working great. The bulbs are still cheaper by $1.00/each if you buy 2 (bulb+remote) packs, rather than the single 2-pack of bulbs only. sigh yay for e-waste.
I can easily pair the remote to ST, Home Assistant, and Hubitat. However, other than the initial paring (which is quite easy - just hold the reset button inside the battery cover until the LED flashes) and a single battery report message from the remote, I never see any other logs indicating the remote sends any messages at all.
Given I have so many of them, I'd love to be able to use them for something.
