Not sure if this could be added as a virtual device or app, but I would love a way to control all my Sonos devices via 1 dashboard "Music Player".
My thought on a Virtual Device is, if the VD could mirror 1 Sonos unit (we use our "Kitchen Sonos" as the primary play/pause/queue controller) I could then make a rule in RM that said when VD is turned up, also turn up Sonos devices X,Y,Z. This would allow for HE Sonos "Zones" to be created and controlled outside of the Sonos app.
As it is now we could write the RM rule, but then EVERY time we turn the Kitchen Sonos up (even outside the dash) it would turn up all my units.
@bravenel I think we have discussed this before as a group/scene but would VD be possible?
If not is there someone out there smart enough, and willing to write an app/device for this (or know of a way to do it)?
I have a Sonos node server running in a docker that I plan on using with http calls for more advanced Sonos integrations. That being said an app that bookmarked favorites and allowed for them to be played on selected player(s) would be awesome.
Big props and thank you to @Cobra for creating a virtual music device, and an app to begin mimicing the Sonos interface on HE Dashboards. This app is new, and we are still working to fine tune it. Anyone that wants to try it out, can do so by installing the driver/app from @Cobra's website.
The driver is obvious, it makes a virtual music player.
The app allows you to designate one "Master" device, and mirror play/pause/volume changes to multiple "Slave" devices (as many as you want). This allows you to control multiple Sonos (or any audio device) at one time from a single dashboard Music Player.
Note: This tile is completely custom CSS. It is added to show the actions visually. The app does not create this dashboard tile. It will create a standard music player 'device' tile. I can help if anyone wants something like above.
Future development - As you can see, right now the volume is a direct mirror. We (@Cobra mostly) are working to make it more of a percentage, or 'variable' adjustment. If you use Sonos zones you may be familiar with this action. Sonos will not turn lower volume devices down, as much as higher volume devices, when the "group" slider is adjusted. It does this in order to not mute, or over increase volume to devices. It would be ideal if the app could be modified to mimic that action.
If one any knows of a way that would make the app raise/lower adjustment "smoother" we would love to hear your input. If am not clear, I can do my best to clarify. Thanks for pondering, testing, or just stopping by and looking.
This is great.
Is it safe to assume that what this app does is it coordinated the controls (next/play/volume) across multiple speakers even if they are not 'grouped' in by the Sonos System?
Or does it actually interact with grouping (group/ungroup) ?
I installed it, but am struggling a bit with what use-case I'm looking for.
In particular with how it will behave when my speakers are group in Sonos v.s. Not grouped.
It does not interact with Sonos groups, you have to faux the groups.
The app allows you to create a master, and then slaves. You can 'mirror' volumes or have them go up by the same relative amount (-+10 or what I move the slider not mirror it) more like the Sonos app does it. This brings a "Sonos like" interface into a HE dashboard. Normally with a HE tile you can only control one Sonos device volume, not many.
@Cobra has plan to make it parent/child, but not sure if that has been done/release yet. It's been a few days since I checked.
I use it to control the volume of all the my Sonos devices via the dash tile in HE. I also added in 2 (of 8) extra 'zones' that I like 'independent' controller over. The top slider "Virtual Sonos" controls all zones by relative increase and then the others you see.
EDIT: That video is old and does not show the relative increase like I thought it did. Play with it and you'll see what I mean.
Sorry for the noob question but I registered for Cobras website in an attempt to find/install this app. Does my account have to be approved to access Cobra Apps? When I go to log in it just says access is currently disabled.
On a somewhat separate note I am running Echo Speaks devices and while voice control works for selecting music most of the time sometimes Amazon doesn't do the best job of finding what I am looking for (I mostly use Apple Music but this is true regardless of the music service) Has anyone devised a way that is a text field that allows searching for music with some sort of rudimentary navigation?
Wonder if there's anyone using this handy app who can explain two behaviors:
What is the difference between the master speaker and the virtual device? I have 6 real speakers which I've added to my dashboard. I'd also like to add an "All Speakers" music player to the dashboard to control all of them as a group, as well. So I created an "All" virtual speaker in @Cobra's awesome app with "follow exactly" selected. Is this virtual speaker the master? Or does the master have to be one of the six actual speakers? Fundamentally I don't understand why there is a virtual device distinct from a master device. I must be missing something.
If I adjust the volume or the mute/unmute status of the virtual, all the slaves change instantly. Great. But if I adjust the channel/source on the virtual, none of the slaves change--only the master does. Is this intended behavior?
For the app to function most effectively the Sonos devices need to be in the same Sonos group.
The "Master speaker" refers to the Sonos apps master controller (the device that started the group and controls track functions)
Yes, again this is a Sonos grouping thing. The app changes the track on the master unit and that changes all the slaves because they are all in the same Sonos group.
I think I might understand now. My environment is a single Sonos, which acts as a source, and then a bunch of speakers managed by a HE-controlled audio matrix unit created by @martinez.mp3 (see this thread). I assumed the Virtual Music Player app worked for this setup because it says in multiple places "any speakers", not just Sonos. Without Sonos "groups", I don't suppose there is a way for this app to control source-select, not just volume?
Thanks for the code -- got me close. I wonder if the differences (especially the vertical spacing of the play-title and the volume) are because I'm not using Smartly. I'll see if I can play around with the code to adjust the spacing. I'm also going to try to abstract the CSS code so that's it works for 4 or 5 speakers, rather than just 2. I'm not a CSS coder, so if you have any pointers on either of these issues, I'm all ears. Thanks again for this.
[Noob here] So is this a straight hubitat tile? I have (3) amps/devices within the Sonos Integration and would like to get the slide bars to show in my tile also. I have @Cobra's Sonos Dashboard Control working to adjust the volume & verified that the individual music player volume will update with the "speaker Group" volume but would love to have the slide. I noticed @TechMedX shared some code but I'm not sure where you would update this &/or its something else needed to make it work.
You can use the Music/media player tile. My display is there tiles combined. To do that you add my code to your CSS. But for just one tile you can just use the built in template.
