Two CMARS RGBW bulbs along with an outlet for $35.99. They're all zigbee 3.0 - and I know the outlet works with Hubitat just fine.
The bulbs are also zigbee 3.0. That Amazon page has a terrible description, but I know that they are RGBW bulbs that support color temperature from warm white to cool white, based on folks using them with zigbee2mqtt.
They were marked as $8.00 off today, so I ordered all three. Will update this post to indicate if the bulbs work with Hubitat and what the color and color temperature look like.
Here's the promised followup. The bulbs pair to Hubitat very easily as "Advanced Zigbee Bulb". They do not respond as anticipated with the "Advanced Zigbee RGBW Bulb" driver, but do work fine with the "Generic Zigbee RGBW Light" driver.
The bulbs identify themselves as:
CT ranges from 2700-6500K. The bulbs put out plenty of light in CT mode.
Color reproduction in RGB mode is pretty good - at least as good as Sengled (examples below), but at a level of 100%, the lumens output is about 30-50% of that output in CT mode at 4000K.
I'm just getting my Hubitat online and thought this would be a good starter set. However, I'm curious if anyone has this bulb working? Using an Advanced Zigbee RGBW setting, I can turn on the bulb and change color, but not the temperature and can not turn off the bulb. the Generic Zigbee RGBW is doing nothing.
What driver are you referring to - the Advanced Zigbee driver? I do see that as a preference option dunno if it works on all devices though but maybe. That would be very cool.
There are several versions of the advanced driver. Did you try the Advanced Zigbee RGB Bulb driver? That seems like it would be the closest other than the basic one.
❥Living a Colorful Life --- Designed with over 16 million colors to choose, scenes DIY, schedule function and 800lm(2700k-6500k) warm white. Just switch to your desired light mode to suit your mood and adjust the brightness to meet your needs.
Wow for the price I can live with whatever driver... am very excited to check this out.
Thanks again for this thread (and many others) and your always excellent advice!
