Hi Bryan. This is not a specific device. Mentioned in this thread, I did take a C8, restore platform, and a few other steps, and can join LR devices, and it works. Had the same problem with the C8 before I restored the platform. Tried a similar on the C8 Pro that I use for my Day to Day operations with the main difference of not wiping all devices, and I cannot get it to work.
This is not z-wave device related, it is something with the hub.
@bcopeland
Hi Bryan. Understanding this may be an odd condition, what or how would you like to proceed, or what is the suggested next steps. I really do not want to remove and re-add everything.
Both devices I tried work fine on my other C8 hub.
The Z-Wave DB on my main hub was migrated from a C7 a while back.
Also, the main device I was trying to get added, I added in mesh mode using SmartStart and it worked fine that time, just wont join with LR. The device says "LR" right on it.
Just to bring this discussion back.
First, I want to say I am glad to see someone duplicate the problem, as well as sad to see..
I am hoping this will get some visibility, as I really feel like I was swept to the side.
I do understand a push for the release, and being busy. Could have been better with
communications. I am not new to software and hardware development, spending
better than 25 years developing commercial products and applications.
To summarize:
The C8 I listed above that "worked" did not have any devices restored from a backup, instead it was reset, had a platform update, and then a release update.
The C8-Pro was similar, no reset, platform update, release update. Retained "all" devices. This is the device that will not add LR.
This is a tricky one... the underlying issue is with zwave/ip gateway, and we have to find a workaround. We're working with the vendor to see what can be done here.
Since a few shared the link outside the beta already, I am moving this post public, as who ever tries to access the shared link will get an error, otherwise.
Did you reset the z-wave radio on that hub first?
Was that hub previously migrated to your new hub? Whatever issue the current hub has may have carried over from the old one, so a radio reset would clear that out (hopefully).
This was incorrectly marked as a solution by "bfara83".
Currently there is no solution.
Resetting the radio does appear to work, until you restore a Cloud backup.
As noted in this thread, my C8-Pro has roots back to C5, with Cloud migrations starting with the C7->C8->C8 Pro...
Steps:
Cloud Backup
Soft Reset
Reset Radios
Add LR Device
Up to this point I can add/remove both z-wave devices, including LR devices.
But wait!!
Next I restored from a cloud backup. After I attempted to add LR devices, and exhibit the same failed attempt with the S2 bootstrapping error.
I broke down and completely rebuilt my network.
Why you might ask ??
First I must say that I really did not want to spend an entire day doing this. I have a need to use a few LR devices, and the only way I could determine to do that was either use a different Hubitat device or not restoring from cloud after I reset the radios. I chose the rebuild...
Steps (starting from a V 2.3.9.150, fully restored from the cloud):
Removed all z-wave devices
Reset Radio Z-Wave.
Power down device for 5 minutes, then reapplied power
Re-added all Z-Wave
Fixed all rules, groups, controllers, etc..
All now works (including LR devices).
Only took 14 hours...
At this time, I am not sure if "restoring" a cloud backup will break it again. Might try on one of the test hubs.
Hey Victor, I wanted to check and see if you had any progress with the vendor on this?
I had a LR device paired with my C-8 but the migration to a C-8 Pro broke it and the device won't add again due to this unfortunately need LR in this case.
