[RELEASE] Hubitat Package Manager (HPM) -- HubitatCommunity
You may have seen by now that a new version of HPM is available: v1.9.0 and it's important that anyone using HPM with plans to upgrade their Hub to the next Release will need to upgrade HPM now, before upgrading their Hub. Today, while the next version is being tested, is a good time to upgrade HPM. There's no new features, it works the same, it's just ready for the next Platform Release, whenever that occurs.
If you fail to upgrade HPM before your Hub, it's not horrible to recover, but upgrading HPM first will be smoother. :slight_smile:
Hi @csteele, I've just got repository attached to HPM and it was working fine. I made a small update yesterday it updated fine through HPM but this morning HPM is listing that an additional app or driver is available. When proceed through the update the additional app or driver is 'null'. How do I fix that? Thanks.
Your PackageManifest.json is identifying both an App and a Driver are part of the package but that the app is "empty".
	"apps": [{}],
	"drivers": [{
		"id": "3c0691d0-2094-4ae7-a603-d3d32cc28e5c",
		"name": "My Location",
		"namespace": "myLocation",
		"location": "https://raw.githubusercontent.com/wecoyote5/hubitat-MyProjects/main/MyLocation.groovy",
		"required": true,
		"oauth": false,
		"description": "Driver to support Lat/Lon updates from HD+."
Just get rid of the empty "apps": [{}], line(s).
Because the "apps": word is in the manifest, then HPM checks for an app and any updates to the app. But the values are all empty, and so it falls into catch-22 type of logic. If your Package doesn't have an App, then don't half define one. :smiley: Same for Drivers, if the package is an app only, don't half define drivers.
Got it, thanks! and it's now removed.
How do you recover? I did the hub patch before the update. :frowning:
Did you read this Topic?
When trying install and use " Search Method - Fast or Fuzzy Search" I get the following error, how do i search?
java.net.SocketTimeoutException: Read timed out on line 418 (method prefInstallRepositorySearchResults)
Hi there,
I'm seeing a timeout on Package Manager when with the following error and log entry when attempting to search for a new app.
There also appears to be an odd version mismatch as per the below - the app itself displays v1.9, but the app code shows v1.8.12
Not sure if it could be related, but I recently did a C8 upgrade migration and seeing another unusual error with another app.
Any remediation suggestions please? Would it be safe to just delete the app and install the latest version?
I just saw the fuzzy logic post, fast search works perfectly.
Simply do a Repair on HPM. The cosmetic typo has no effect, so you're welcome to just ignore it.
It's a result of how I manage the source I'm working on. When I publish a release, I predict-the-future and get the source ready for the next release. The prior release was 1.8.11 and I predicted that 1.8.12 would be the next.. then the bigger issue was found and I felt it needed a bigger increment. 1.9.0 I caught it in 2 of the 3 places :smiley: If you looked at my source today, it would show 1.9.1 because that's the size of change I'm predicting :slight_smile: We will have to see how well I did...
Haha - got it, thank you!
Just FYI - I just ran the repair and it worked - I'm see a dup in the inventory list though.
Have you given this a read?
Sorted - thanks again!
new problem.. for some reason It wont let me search anymore. any ideas? how do i wipe it and start over, perhaps that is a fix?
Have you read this Topic yet?
I have some parent child apps, often I will only be updating a Child App. Is the release notes section only supported at the package level, or is it possible to have release notes for each of the modules within a package?
Also, do you have any advice on versioning of package\parent\child\driver apps.
Let's say I do an initial release and everything is at V1.0.
Now I find a bug in a child app and I rev that child app to V1.0.1.
Should I always rev the package version with any change to the contents? Or do I only rev the package when I add or delete something from the package?
Thanks, great app and thanks for supporting it. Makes things a lot easier.
HPM simply displays the Release Notes. It doesn't use them. And I think the hint is that it's a "Package" manager :smiley: If 10 items are a Package, then there's one Package Manifest and within, one Release Notes, and so on.
I understand 100% how "we developers" organize and revision our code, but HPM isn't focused in that direction. It's Package oriented not component oriented. HPM does not look into the code itself, it strictly uses the Package Manifest to identify a package that needs updating.
You need only update Package Manifest (whatever you actually name it) to cause an Update. As an extreme example, you could revision your components as v1.0.6 + 1.2.4 + 0.1.2 and so on, for each component.. then in the Package Manifest, revision it as v1000.4.a -- where the relationship is entirely obscure to me... you'd understand it, and the package users wouldn't care. I understand in this example it's MORE difficult to organize, but I'm hoping to clarify the 'no relationship' that actually exists between the code version within the code and the version in the Manifest.
Personally, I update Parent/Child apps independently and when I have a child only code update, the entire package is updated, because a "Package" is the smallest granularity of HPM. (Ignoring Modify, which focuses on components.)
So HPM is only looking at the versions on github and local hub and doing a string compare? If the strings are different then it's an update? The actual version strings are just for us humans.
If the package version changed but none of the Apps or Drivers versions changed would HPM still indicate there was an update available? I'm thinking maybe I'll just go with a perpetually increasing integer for the package version to break any appearance of connection with the app versions.
