Release 2.4.3 Available
Release 2.4.3.122 Available
Changes from 2.4.2.160
Platform Changes
  • Added Shelly device integration app, with support of:
    • v1 switches, relays, lights, natural gas and leak sensors.
    • v2+ switches, relays, dimmers, lights, power meters, temperature, and humidity sensors.
  • Completely re-wrote ZWave-JS value parsing to fix missing reports from some devices.
  • Added the ability to navigate between dashboards for EZ cloud dashboards.
  • Added ability to publish user apps, drivers, and libraries to all of user's registered hubs simultaneously from the "..." menu in the code editor (top right corner).
  • Modified legacy dashboards to transparently load dashboard and tile background image files in /local folder from the cloud. File size limit of ~100k applies.
  • Added a prominent warning for failed Z-Wave cloud restore.
  • Tweaked network reconnect logic.
  • Added device names to found/suggested LAN devices.
  • Renamed Z-Wave repair to network rebuild on z-wave details page, added warnings against running rebuild repeatedly.
  • Added cloud indicator to legacy dashboards.
  • Improved reliability of Z-Wave migrations to C-8 Pro.
New Devices
  • Zooz ZSE50 Siren & Chime
New Apps
  • Added UniFi Network Integration app for UniFi network client devices and UniFi network devices.
  • STR Code Manager, manage lock codes for short term rentals.
New App Features
  • Added hub variable endpoints to Maker API
App Changes
  • Hue Bridge Integration app now supports Hue Bridge Pro. (Integration app and drivers now use HTTPS by default; SSE must be disabled to force HTTP, e.g., for V1 bridge. Most users will notice no visible changes.)
New Driver Features
  • Added fourth fan speed to GE Smart Fan Control driver for model 58446/ZWA4013
Bug Fixes
  • Fixed bogus "not enough space left on device" error while using API to upload a file.
  • Fixed Generic Z-Wave Lock driver loop when unexpected user code received.
  • Fixed commandRetry issues with blinds.
  • Fixed HomeKit pairings backup/restore issue. Please create a new manual database backup ASAP.
  • Fixed some non-standard Switch Multilevel reports being dropped by ZWave-JS.
Release 2.4.3.123 Available
Changes from 2.4.3.122
Platform Changes
  • Removed the need for hub restart after enabling Shelly integration.
Release 2.4.3.127 Available
Changes from 2.4.3.123
New Compatible Devices
  • Third Reality temperature humidity sensor (3RTHS0224Z) using GenericZigbeeTemperature/Humidity Sensor
  • Third Reality RGBW bulb (3RCB01057Z) using Third Reality ZigBee RGBW Bulb
  • Third Reality shade (3RSB015BZ) using Generic Zigbee Shade
  • eWeLink Door and Window Sensor (DS01) using Generic Zigbee Contact Sensor (no temp)
New Devices
  • Third Reality plug (3RSPU01080Z)
  • Third Reality dual plug (3RDP01072Z)
New Driver Features
  • Added configuration parameters to Fibaro Smart Implant.
Platform Changes
  • Added native graph support to EZ dashboards more details .
  • Added checks to prevent repair, inclusion, and exclusion from being started in parallel.
  • Added a button bringing up support chatbot to the top menu bar.
  • Added Phillips Hue MotionAware areas to Hue Bridge integration app
  • Updated mDNS library and disabled unnecessary mDNS listeners when Connect Devices to Your Hub is hidden.
Bug Fixes
  • Fixed ZWave-JS Sensor Alarm command class.
  • Rule 5.1: Fixed Rule Functions which were being lost.
  • Fixed command error from Lutron VCRX Output driver when installed.
  • Fixed ZWave-JS Association command class when using List of nodeIds.
  • Fixed reporting on Aeotec Dual Nano driver when using ZWave-JS.
Release 2.4.3.131 Available
Changes from 2.4.3.127
Platform Changes
  • Refined WiFi join logic for both initial setup access point and WiFi changes during normal hub operation.
  • Added option in Generic Matter Bridge to allow changing a Generic Composite contact sensor to a Generic composite water sensor should that in fact be the actual device type on the bridge. The device type needs to be changed on the child device.
New Devices
  • Zooz Zen78 High Power Relay
Bug Fixes
  • Fixed CommandRetry issues with open/close commands for blinds and shades.
  • Fixed EZ dashboard graph tile for non-sensor devices.
  • Fixed AirPlay pairing (app not asking for the code).
  • Added explicit dashboard sorting by name in mobile Devices view.
  • Fixed sporadic "missing column ZW_DEVICE_CLASS" database error.
  • Fixed the condition causing stopped rules to become active.
  • Fixed migration from C-7 to C-8/C-8 Pro.
  • Fixed subscription issues with Generic Matter Bridge
  • Fixed battery reporting for Locks, contact and water sensors in the Generic Matter Bridge driver.
Release 2.4.3.133 Available
Changes from 2.4.3.131
Platform Changes
  • Added one click firmware update option for all hubs that belong to the current user.
  • Added a Settings option to hide the chatbot.
  • Added automatic hub reboot if CPU load remains at a critical level for 15 minutes or more.
New Devices
  • Zooz Zen56 RGBW Dimmer
  • Generic matter smoke detector
Bug Fixes
  • Fixed the issue with the replaced devices not immediately shown in the room original device belonged to.
  • Added log error messages for legacy dashboards trying to access a device that's not authorized for that dashboard.
  • Added setProtocol command to Shelly devices to manually update protocol for devices where it was not automatically detected.
Release 2.4.3.137 Available
Changes from 2.4.3.133
Platform Changes
  • Added file deployment from one hub to all hubs connected to the same user's account to Settings - File Manager. File size limit applies.
  • The endpoint to disable hub process monitor /hub/advanced/disableHubProcessMonitor now disables reboot on critical CPU level, too. Use /hub/advanced/enableHubProcessMonitor to enable it back.
New App
  • Added Power Aggregators app to summarize power use of multiple devices into one - useful with EZ dashboards Graph feature.
New App and Driver Features
  • Hue Bridge Integration app:
    • Added support for Hue Doorbell and Hue Chime.
    • Renamed "reachable" attribute on bulb devices to "networkStatus" for consistency and fixed parsing; removed from group devices (as this data is not reported by the Hue API).
  • Added motion events for Hue doorbell (and likely all types of Hue Secure cameras)
Bug Fixes
  • Fixed EZ dashboard layout update issue for cloud dashboards.
  • Fixed ZWave-JS basic V2 CC missing values.
  • Possible fix for ZWave-JS inconsistent reports on door state / door tilt notifications.
  • Increased ZWave-JS send attempts on missed ack/supervision.
  • Adjusted Zooz ZSE70 default reporting on Lux/Temp on install.
  • Disabled critical CPU load reboot for the first hour of hub's uptime.
  • Fixed extra login issue for EZ dashboards on the mobile app while UI security is on.
  • Added error logging for when Shelly devices are unreachable or if login is incorrect.
  • Fixed missing navigation for PIN protected EZ dashboards.
  • Stopped chatbot files from loading when the chatbot is disabled.
  • More ZWave-JS basic CC fixes.
Release 2.4.3.149 Available
Changes from 2.4.3.137
Platform Changes
  • Updated ZWave-JS to version 15.15.3. Update happens after boot so Z-Wave will take longer on first boot to start.
  • Added low battery and weather QuickView tiles to the main page.
  • Added customizations to EZ dashboard helper tiles and graphs.
  • Added ZWave-JS reported devices details to the Device Info section.
  • Added TV remote tile option for button controllers with at least 8 buttons in EZ dashboard.
New App Features
  • Added AI powered rule building and automation suggestions to Visual Rule Builder app.
  • Added numerous device based conditions to Visual Rules Builder.
  • Visual Rule Builder actions and conditions can now appear disabled if there are no associated devices (e.g. Motion Sensor option is disabled if there are no motion sensors on the hub).
  • Govee Star Light Projector (Aurora) using Generic Matter RGBW Light driver.
  • Leviton ZW6HD Dimmer.
New Driver Features
  • Added "battery" attribute for Hue integration button devices
  • Added "minimum motion active for" setting to Hue Motion Area driver to prevent rapid active/inactive cycles (Hue MotionAware or Hue cameras)
Bug Fixes
  • Fixed networkStatus attribute on Hue RGB Light driver.
  • Fixed the issue preventing power-only devices from showing as Graphs on EZ dashboards.
  • Improved ZWave-JS initial install for battery powered devices, blocking driver WakeupNoMoreInformation until reinterview is complete.
  • Fix parse logs appearing in Eve Motion driver when debug logging disabled
  • Fix missing hue and saturation attributes on Sengled Element Color Plus bulbs for new installs
  • Fixed missing child device for dual plug driver.
  • Fixed ZWave-JS WindowCovering command class.
  • Fixed ZWave-JS Switch Multilevel Report v4 when duration is not sent.
  • Fixed an unnecessary/duplicate ZWave-JS update issue.
  • Fixed ZWave-JS battery cc low battery notifications.
  • Fixed ZWave-JS log parsing missing the first character.
  • Fixed "Set Color" command that failed in certain cases on Hue Bridge Integration lights.
Release 2.4.3.155 Available
Changes from 2.4.3.150
Platform Changes
  • Added a section to show SmartStart devices pending inclusion on the Devices page (for hubs running ZWaveJS only).
  • Added detection of ZWave devices requiring security (e.g. locks) malfuntioning due to having joined without security (for hubs running ZWaveJS only).
  • Kwikset HomeConnect 620 Z-Wave Lock using Generic Z-Wave Lock driver.
Bug Fixes
  • Removed ability to edit Easy mode rules outside of main Easy mode manager UI.
  • Fixed dropped lightEffects attribute for legacy dashboards.
  • Added lightEffects population for Wiz RGBW lights. Go to device's Preferences tab and save to populate on existing devices.
  • Added optional timeout parameters to ping function:
    PingData ping(String IPAddress, Integer count, Integer timeout = 3)
  • Improved instructions to OpenWeather driver.
  • Added the logic to produce missing reports in ZWave-JS based on supervision response, per Z-Wave specs.
  • Introduced better handling of no response from synchronous commands in ZWave-JS.
  • Possibly fixed firmware update timeouts.
  • Added fixes for ZWave-JS alarm sensor command class and for ZWave-JS EU Region showing as US.
  • Fixed ZWave-JS command class get commands where the return was a single integer value.
  • Fixed error after sending cetain hueBridgeGroup commands (e.g., flashOnce).
Release 2.4.3.156 Available
Changes from 2.4.3.155
New App Features
  • Added custom port option to UniFi Network Integration app
Bug Fixes
  • Fixed erroneous SmartStart devices pending inclusion error.
Release 2.4.3.158 Available
Changes from 2.4.3.156
Bug Fixes
  • Fixed iOS app crash while trying to use SmartStart.
  • Possibly fixed occasional high CPU use by mDNS discovery.
Release 2.4.3.164 Available
Changes from 2.4.3.158
Platform Changes
  • Added retry logic to firmware downloads.
  • Added Google Maps based address lookup to hub onboarding.
Bug Fixes
  • Fixed ZWaveJS installation.
  • Fixed empty SmartStart page after deleting all devices.
  • Fixed Zooz RGBW Dimmer driver when using ZWave-JS.
Release 2.4.3.167 Available
Changes from 2.4.3.164
  • Wiz dual zone RGBW devices.
Bug Fixes
  • Fixed missing SmartStart listing at the top of the Devices page.
Release 2.4.3.171 Available
Changes from 2.4.3.167
New App Features
  • Added calendar import feature to STR code manager for AirBnB and iGMS PMS iCal links. Allows for automatic booking creation and setting lock code to the last 4 digits of guests phone number.
Bug Fixes
  • Fixed incorrect secondary Wiz device as a switch instead of an RGBW bulb.
  • Added reasonable status defaults for heat only thermostats to EZ dashboards.
  • Fixed an infrequent Matter join issue.
  • Possibly fixed runaway Matter device check background process.
  • Fixed an issue with RGBW bulbs reporting color temp based state to Apple Home even while in RGB mode.
Release 2.4.3.172 Available
Changes from 2.4.3.171
Platform Changes
  • Added a way to easily disable Hubitat cloud under Settings.
Bug Fixes
  • Increased color temp range in Visual Rule Builder app.
  • Increased thermostat temperature range in HomeKit app.
  • Various performance and security fixes.
Release 2.4.3.173 Available
Changes from 2.4.3.172
App Updates
  • SharpTools updated to minimize the amount of data the app subscribes to.
Bug Fixes
  • Likely fix for Ecobee "Authentication failed" errors.
Release 2.4.3.176 Available
Changes from 2.4.3.173
Bug Fixes
  • Fixed the label for "before sunset" trigger in Visual Rule Builder.
  • Likely fixed the issue of autocomplete silently filling PIN fields for EZ dashboards.
  • Fixed broken EZ dashboard media player tile when player status is "idle".
  • Fixed missing setThermostatFanMode method for HomeKit thermostat devices.
  • Fixed rare "Z-Wave stuck post cloud restore" issue.
Release 2.4.3.177 Available
Changes from 2.4.3.176
Bug Fixes
  • Fixed an issue where rapidly growing app state caused the Devices tab to fail to load in the mobile app.
