Release 2.4.0 Available
Release 2.4.0.142 Available
Changes from 2.3.9.201
Platform Changes
  • Updated, modern user interface.
  • Added Z-Wave WindowCoveringV1 command class.
  • New Generic Z-Wave DT (Device Type) fingerprint driver matching by Z-Wave Device Class with dynamic configuration parameters. For better user experience with new untested Z-Wave devices.
New Devices
  • Generic Z-Wave DT Repeater
  • Generic Z-Wave DT Binary Switch
  • Generic Z-Wave DT Multilevel Switch
  • Generic Z-Wave DT Thermostat
  • Generic Z-Wave DT Window Covering
  • Generic Z-Wave DT Notification Sensor
  • Generic Z-Wave DT Meter Sensor
  • Generic Z-Wave DT Central Scene
  • Generic Z-Wave DT Gateway
  • Generic Z-Wave DT Generic Controller
  • Generic Z-Wave DT Multilevel Sensor
  • Generic Z-Wave DT Sound Switch
  • Generic Z-Wave DT Color Switch
  • Zooz ZAC38 Z-Wave Range Extender
  • Zooz ZEN53 DC Motor Controller
  • Eve Weather (Matter/Thread)
  • Human Presence Sensor (ZG-204ZM Zigbee)
  • Third Reality Soil Moisture Sensor (3RSM0147Z, Zigbee)
  • Third Reality ZigBee RGBW Bulb (3RCB01057Z)
  • Third Reality Zigbee Smart Watering Kit (3RWK0148Z)
  • Fingerbot Plus Zigbee Actuator
  • Aqara Opple button (WXCJKG12LM , WXCJKG12LM both Zigbee)
  • Russound Zone Controller
  • Centralite Zigbee Plugin Dimmer (4257050-ZHAC)
  • Wiz color temperature lights. Please remove existing device stubs if they're stuck in that state and run device discovery again.
  • Shelly Wave 1
  • Shelly Wave 1PM
  • Shelly Wave 2PM
  • Shelly Wave i4
  • Shelly Wave PM Mini
  • Shelly Wave PRO 1
  • Shelly Wave PRO 1PM
  • Shelly Wave PRO 2
  • Shelly Wave PRO 2PM
  • Shelly Wave PRO 3
  • Shelly Wave PRO Shutter
  • Shelly Wave Shutter
New Compatible Devices
  • Zooz ZSE11 800LR using Zooz Zooz Q Sensor ZSE11 driver
  • Sonoff MINIR4M Matter Smart Switch using Generic Matter Switch driver
  • Sonoff SNZB-05P using Generic Zigbee Moisture Sensor (no temp)
  • Shelly Wave 1 Mini using Shelly Wave 1 driver
  • Shelly Wave i4 DC using Shelly Waver i4 driver
New App Features
  • Hue Bridge Integration app updated with support for scenes, motion sensors, contact sensors, button devices, and additional device features in drivers (NOTE: after updating to 2.4.0, downgrading to 2.3.9 or earlier will require restoring an old, matching hub database [the easiest option for most users]; removing and reconfiguring the app as new; or a special downgrade process as noted in the documentation in order for the integration to work again on the old version)
  • Added IF/THEN/ELSE logic to Visual Rule Builder.
  • Rule 5.1:
    • Added new table based UI for Triggers and Conditions, allowing one click to create new, edit or delete.
    • Rule Functions available (see this post ). There is a known bug in this version; there must be a param selected for using Rule Function in another rule. Select any Hub Variable as the param, and all will be OK. This bug is already fixed, but that fix is not in this release.
New Driver Features
  • Added preference setting for volume up/down commands to AVR and component Zone drivers.
  • Added unsubscribe to all Aqara drivers (removes jobs from community drivers)
  • Added getZigbeeAttributeValue command for Zigbee drivers, getParameterValue command for ZWave was renamed to getZWaveParameterValue.
Bug Fixes
  • Fixed unsupported command response to Zigbee OTA image page requests (fixes Third Reality Multi-Function Night Light firmware update issues).
  • Remove extraneous logging from Custom Mirror sensor automations.
  • Add power/energy metering capabilities to Shelly Z-Wave Plug driver.
  • Swap erroneous motion capability for contact in Wally Multisensor driver.
  • Fixed "ASAP" auto-inactive option in Virtual Motion Sensor.
  • Fixed reversed position on Aeotec Nano Shutter driver.
  • Fixed battery divisor on Third Reality Switch driver.
  • Added supportedFanSpeeds to Hampton Bay Fan driver.
  • Fixed parse error in Aqara Zigbee Contact Sensor driver.
  • Fixed Z-Wave DT drivers configuration poll.
  • Rule 5.1: Removed option to 'Ignore Trigger Events While Running'. There are certain edge cases in which this feature would fail. Rules with this option selected will still work exactly as before.
  • Fixed insane temperature values for Matter and Zigbee Aqara Weather (temp humidity) sensors.
  • Fixed precision with Ecobee thermostat driver when using Celsius scale.
Release 2.4.0.143 Available
Changes from 2.4.0.142
Platform Changes
  • Made summary tiles on home page clickable, to show the list of devices (for instance, all locks that are unlocked).
  • Added logout button at the top right corner (for hubs with Hub Login Security enabled in Settings) next to messages.
Release 2.4.0.144 Available
Changes from 2.4.0.143
Platform Changes
  • Tweaked summary tiles logic and added a home page settings dialog for some customization.
  • Added device status polling to home page.
Bug Fixes
  • Fixed a "command failed" response for some component devices.
  • Ensured that user apps/drivers with import URL show that URL by default.
Release 2.4.0.145 Available
Changes from 2.4.0.144
Platform Changes
  • Added custom icons and notes for devices.
  • Added proper handling of connector variables to rooms/devices pages.
New App Features
  • Added Smart Scenes and custom scene activation options to Hue Bridge Integration.
  • Notifier: Added support for illuminance sensors.
Bug Fixes
  • Possibly fixed OwnTracks app high resource usage issues.
  • Possibly fixed for modes not changing after upgrade to 2.4.0.
  • Fixed empty device details page when name contains unexpected characters.
  • Fixed missing firmware update warning.
  • Fixed missing device events search box.
  • Fixed parse and semaphore errors/hangups in Hue integration,
Release 2.4.0.146 Available
Changes from 2.4.0.145
Bug Fixes
  • Fixed OAuth dialog for user apps.
  • Improved search responsiveness and rendering speed on mobile devices.
Release 2.4.0.147 Available
Changes from 2.4.0.146
Bug Fixes
  • Fixed blank error pages (e.g. missing app or broken database).
  • Fixed rare instances of MyNewHubitat WiFi endpoint still present after Ethernet connection has been established.
  • Fixed Z-Wave repair stop issue.
  • Custom device icon can be removed/reset to default now.
  • Fixed scrolling issues on Apps/Devices/Rooms pages.
  • Added back links to source hub mesh devices in Devices/Rooms pages.
Release 2.4.0.148 Available
Changes from 2.4.0.147
Bug Fixes
  • Revised network reconnection logic when hub is connected through both Ethernet and WiFi.
  • Rule 5.1: Possible fix for delays caused by Run Actions.
  • Fixed GH issues with Dome water valve and Bond fireplace controller being dropped from the integration when added.
Release 2.4.0.149 Available
Release has been pulled.
Changes from 2.4.0.148
Platform Changes
  • Built-in mode manager now supports primary/alternative trigger conditions for different days of the week.
Bug Fixes
  • Fixed missing account emails on Hub details page.
  • "Devices with no room" no longer brings up room details page.
  • Fixed code download button on the app code edit page.
  • Rule 5.1:
    • Fixed problems with adding ELSE or ELSE-IF.
    • Fixed delays for Cancel Rule Timer for **This Rule**
Release 2.4.0.150 Available
Changes from 2.4.0.149
  • Rule 5.1:
    • Fixed MissingMethodException reported in 2.4.0.149 (problem with Variable triggers).
Release 2.4.0.151 Available
Changes from 2.4.0.150
Bug Fixes
  • Reverted time and date device preference inputs to browser native ones.
  • Rule 5.1: Fixed missing Done button for editing While.
