[RE-RELEASE] Moes ZigBee Wall Switch 1/2/3-Gang (Tuya TS0601 Switches)
This is a re-release of the popular 'Moes ZigBee Wall Switch 1/2/3-Gang' driver, initially published by @martinkura back in 2021.
The driver can now be installed from HPM - search for 'Moes ZigBee Wall Switch '.
Important: if you have this driver already installed manually, first perform a 'MatchUp' in HPM and then update to the latest version.
Note, that Tuya TS0601 switches will not work out of the box using the Hubitat stock drivers.
This (or a simiralr Tuya-specific) driver is required for TS0601 switch devices.
Even when the HPM is used to install the latest stable version, before reporting any issues, please make sure that you have first updated the driver to the latest version - the code can be manually imported from GitHub :
https://raw.githubusercontent.com/martinkura-svk/Hubitat/main/Moes%20ZigBee%20Wall%20Switch
This is an (incomplete) list of Zigbee switches built on Tuya platform that are supported in this driver . There are too many different variations made by different OEMs and sold under different white labels (Zemismart, Moes, etc, etc..), so the list below can never be accurate.
Zemismart 6 Gangs Wall Light Switch
manufacturer: _TZE204_4cl0dzt4
AliExpress: (link)
Manufacturer: _TZE204_xjknlqz8
Manufacturer: _TZE200_r731zlxk _TZE200_9mahtqtg
AliExpress: (link)
Mercator Ikuü six switch :
Manufacturer: _TZE200_wnp4d4va
Zemismart 4 Gangs Zigbee switch
Manufactuer: _TZE204_aagrxlbd
AliExpress: (link)
Manufacturer: _TZE204_shkxsgis TZE200_shkxsgis _TZE200_k6jhsr0q
Zemismart: (link)
Manufacturer: _TZE200_1n2kyphz
AliExpress: (link)
No Neutral ZIGBEE Touch Light Wall Switch EU/US
AliExpres : (link)
Moes Tuya Zigbee Smart Switch AC100-250V No Neutral Wire Required 1/2/3 Gang
AliExpress : (link)
Tuya 12 Way Relay Switch Module DC 7-27V AC 85-250V
AliExpress .us (link)
Revisions history
  • revision 1.0.0 - 2021-05-25 - martinkura - latest original driver version update
  • revision 1.0.1 - 2022-02-22 - kkossev - added Moes 4-Gang Switch / ZTS-EU4
  • revision 1.0.2 - 2022-02-27 - kkossev - added more Tuya fingerprints for 1,2,3 and 4 gangs TS0601 wall switches
  • revision 1.0.3 - 2022-09-26 - kkossev - added Zemismart 6 Gangs Wall Light Switch
  • revision 1.0.4 - 2022-10-12 - kkossev - _TZE200_tz32mtza bug fix; code cleanup
  • revision 1.0.5 - 2023-03-16 - kkossev - added OZ Smart 1-2-3-4 gang switches _TZE200_gbagoilo _TZE200_nh9m9emk _TZE200_go3tvswy _TZE200_mexisfik
  • revision 1.0.6 - 2023-04-24 - kkossev - added importUrl; _TZE200_aqnazj70 _TZE200_wunufsil _TZE200_oisqyl4o _TZE200_atpwqgml
  • revision 1.0.7 - 2023-07-18 - kkossev - added _TZE200_7deq70b8 (@pabutterworth)
  • revision 1.0.8 - 2023-11-20 - kkossev - added TS0601 _TZE204_dqolcpcp (@alex1) (only the first 6 relays should be working)
  • revision 1.0.9 - 2024-01-02 - kkossev - added TS0601 _TZE200_r731zlxk
  • revision 1.1.0 - 2024-03-08 - kkossev - Groovy linting; addeed Zemismart 4-gang switch _TZE200_1n2kyphz; _TZE200_shkxsgis; _TZE204_shkxsgis; added testParse; Tuya cluster 0xEF00 data size check;
  • revision 1.1.1 - 2024-04-03 - kkossev - added TS0601 _TZE200_m*******j @Joao;
  • revision 1.1.2 - 2024-04-28 - kkossev - removed the T3E fingerprint; added _TZE204_aagrxlbd;
  • revision 1.1.3 - 2024-05-06 - kkossev - added _TZE204_xjknlqz8
  • revision 1.1.4 - 2024-05-17 - hhorigian - added _TZE204_4cl0dzt4
  • revision 1.1.5 - 2024-06-28 - kkossev - added TS0006 _TYZB01_ltundz9m _TZ3000_jyupj3fw
  • revision 1.1.6 - 2024-07-22 - hhorigian - added _TZE204_rkbxtclc, _TZE204_zpvusbtv, _TZE204_rzdkn5rxc
  • revision 1.1.7 - 2024-08-20 - kkossev - added _TZE204_dvosyycn (limited to 6 relays only);
  • revision 1.2.0 - 2024-08-20 - kkossev - added syncTuyaDateTime()
  • revision 1.3.0 - 2024-08-30 - kkossev/hhorigian - TratoZemismartKeypad configuration options
  • revision 1.3.1 - 2024-09-07 - kkossev - added Mercator Ikuü six switch _TZE200_wnp4d4va @hpgurgel
  • revision 1.3.2 - 2024-09-29 - kkossev/hhorigian - testing _TZE204_hwyydvqm (device is now handled in the 'Tuya Zigbee Dimmer' driver!)
  • revision 1.3.3 - 2024-10-23 - kkossev - adding TS0601 _TZE204_lmgrbuwf (NOVADIGITAL)
  • revision 1.4.4 - 2025-04-07 - kkossev - (dev.branch) added TS0601 _TZE204_g4au0afs (NOVADIGITAL); added TS0601 _TZE200_mwvfvw8g _TZE200_cduqh1l0 _TZE200_emxxanvi ; added TS0601 _TZE200_kyfqmmyl _TZE200_2hf7x9n3 _TZE204_atpwqgml _TZE200_bynnczcb
If you have recently purchased a Tuya mains-powered switch model 'TS0601' that works with this driver, please post the link to the site, and I will add it to the top post. There are too many different manufacturers and variations, and some old links may not work after time.
How is this one below different? I can confirm it worked out of the box with built-in Generic Zigbee Switch Driver.
https://www.amazon.com/dp/B0C4XXKSWJ
Edit: I checked when I got home, and the model for this switch is TS0011
revision 1.3.1 - 2024-09-07 - kkossev - (dev. branch) added Mercator Ikuü six switch _TZE200_wnp4d4va @ hpgurgel
