Update 11/27/18:
v2.0.20181029
See updated driver below. I am leaving the original sync driver in the original post for those that prefer it. I only have one Lifx bulb remaining that will soon be converted to hue so this will be my last update of this driver. I will do my best to fix any bugs but will not be adding any new features.
I originally ported this driver from ST and converted it from asynchronous to synchronous because HE did not support it in the early goings. Now that they do support async, I have reverted this driver back to that method and added a new setState() method. This was requested, tested and approved by @kilowatts so direct any questions his way...just kidding. Big Thank You to @kilowatts for taking the time to test this out for me.
So pretty much everything is the same except for the aforementioned async calls to the Lifx servers and the new setState() command.
Set State command's input value is a map. Managing 4 separate inputs in HE did not respond as expected, so I set this up as a map similar to how setColor works.
setState(map) syntax:
[power:<val>,color:<val>,level:<val>, duration<val>]
power value options: on, off
color value option: see Color Options below
level value options: 0-100
duration value options: 0-3155760000 (in seconds)
*All inputs are optional
Example 1:
To transition from an off state to a brightness of 100, with a color of blue, over 5 minutes
[power:on, color:blue, level:100, duration:300]
Example 2:
To transition to the color red over 2 minutes and a brightness of 85
[color:red, level:85, duration:120]
Example 3:
To transition to off state over 1 minute
[power:off, duration:60]
Color options can be any Hex RGB code OR
Any of the "color name"s listed below (derived from CSS Color Module Level 4):
| Named | Numeric | Color name | Hex rgb | Decimal |
| aliceblue | #F0F8FF | 240,248,255 | ||
| antiquewhite | #FAEBD7 | 250,235,215 | ||
| aqua | #00FFFF | 0,255,255 | ||
| aquamarine | #7FFFD4 | 127,255,212 | ||
| azure | #F0FFFF | 240,255,255 | ||
| beige | #F5F5DC | 245,245,220 | ||
| bisque | #FFE4C4 | 255,228,196 | ||
| black | #000000 | 0,0,0 | ||
| blanchedalmond | #FFEBCD | 255,235,205 | ||
| blue | #0000FF | 0,0,255 | ||
| blueviolet | #8A2BE2 | 138,43,226 | ||
| brown | #A52A2A | 165,42,42 | ||
| burlywood | #DEB887 | 222,184,135 | ||
| cadetblue | #5F9EA0 | 95,158,160 | ||
| chartreuse | #7FFF00 | 127,255,0 | ||
| chocolate | #D2691E | 210,105,30 | ||
| coral | #FF7F50 | 255,127,80 | ||
| cornflowerblue | #6495ED | 100,149,237 | ||
| cornsilk | #FFF8DC | 255,248,220 | ||
| crimson | #DC143C | 220,20,60 | ||
| cyan | #00FFFF | 0,255,255 | ||
| darkblue | #00008B | 0,0,139 | ||
| darkcyan | #008B8B | 0,139,139 | ||
| darkgoldenrod | #B8860B | 184,134,11 | ||
| darkgray | #A9A9A9 | 169,169,169 | ||
| darkgreen | #006400 | 0,100,0 | ||
| darkgrey | #A9A9A9 | 169,169,169 | ||
| darkkhaki | #BDB76B | 189,183,107 | ||
| darkmagenta | #8B008B | 139,0,139 | ||
| darkolivegreen | #556B2F | 85,107,47 | ||
| darkorange | #FF8C00 | 255,140,0 | ||
| darkorchid | #9932CC | 153,50,204 | ||
| darkred | #8B0000 | 139,0,0 | ||
| darksalmon | #E9967A | 233,150,122 | ||
| darkseagreen | #8FBC8F | 143,188,143 | ||
| darkslateblue | #483D8B | 72,61,139 | ||
| darkslategray | #2F4F4F | 47,79,79 | ||
| darkslategrey | #2F4F4F | 47,79,79 | ||
| darkturquoise | #00CED1 | 0,206,209 | ||
| darkviolet | #9400D3 | 148,0,211 | ||
| deeppink | #FF1493 | 255,20,147 | ||
| deepskyblue | #00BFFF | 0,191,255 | ||
| dimgray | #696969 | 105,105,105 | ||
| dimgrey | #696969 | 105,105,105 | ||
| dodgerblue | #1E90FF | 30,144,255 | ||
| firebrick | #B22222 | 178,34,34 | ||
| floralwhite | #FFFAF0 | 255,250,240 | ||
| forestgreen | #228B22 | 34,139,34 | ||
| fuchsia | #FF00FF | 255,0,255 | ||
| gainsboro | #DCDCDC | 220,220,220 | ||
| ghostwhite | #F8F8FF | 248,248,255 | ||
| gold | #FFD700 | 255,215,0 | ||
| goldenrod | #DAA520 | 218,165,32 | ||
| gray | #808080 | 128,128,128 | ||
| green | #008000 | 0,128,0 | ||
| greenyellow | #ADFF2F | 173,255,47 | ||
| grey | #808080 | 128,128,128 | ||
| honeydew | #F0FFF0 | 240,255,240 | ||
| hotpink | #FF69B4 | 255,105,180 | ||
| indianred | #CD5C5C | 205,92,92 | ||
| indigo | #4B0082 | 75,0,130 | ||
| ivory | #FFFFF0 | 255,255,240 | ||
| khaki | #F0E68C | 240,230,140 | ||
| lavender | #E6E6FA | 230,230,250 | ||
| lavenderblush | #FFF0F5 | 255,240,245 | ||
| lawngreen | #7CFC00 | 124,252,0 | ||
| lemonchiffon | #FFFACD | 255,250,205 | ||
| lightblue | #ADD8E6 | 173,216,230 | ||
| lightcoral | #F08080 | 240,128,128 | ||
| lightcyan | #E0FFFF | 224,255,255 | ||
| lightgoldenrodyellow | #FAFAD2 | 250,250,210 | ||
| lightgray | #D3D3D3 | 211,211,211 | ||
| lightgreen | #90EE90 | 144,238,144 | ||
| lightgrey | #D3D3D3 | 211,211,211 | ||
| lightpink | #FFB6C1 | 255,182,193 | ||
| lightsalmon | #FFA07A | 255,160,122 | ||
| lightseagreen | #20B2AA | 32,178,170 | ||
| lightskyblue | #87CEFA | 135,206,250 | ||
| lightslategray | #778899 | 119,136,153 | ||
| lightslategrey | #778899 | 119,136,153 | ||
| lightsteelblue | #B0C4DE | 176,196,222 | ||
| lightyellow | #FFFFE0 | 255,255,224 | ||
| lime | #00FF00 | 0,255,0 | ||
| limegreen | #32CD32 | 50,205,50 | ||
| linen | #FAF0E6 | 250,240,230 | ||
| magenta | #FF00FF | 255,0,255 | ||
| maroon | #800000 | 128,0,0 | ||
| mediumaquamarine | #66CDAA | 102,205,170 | ||
| mediumblue | #0000CD | 0,0,205 | ||
| mediumorchid | #BA55D3 | 186,85,211 | ||
| mediumpurple | #9370DB | 147,112,219 | ||
| mediumseagreen | #3CB371 | 60,179,113 | ||
| mediumslateblue | #7B68EE | 123,104,238 | ||
| mediumspringgreen | #00FA9A | 0,250,154 | ||
| mediumturquoise | #48D1CC | 72,209,204 | ||
| mediumvioletred | #C71585 | 199,21,133 | ||
| midnightblue | #191970 | 25,25,112 | ||
| mintcream | #F5FFFA | 245,255,250 | ||
| mistyrose | #FFE4E1 | 255,228,225 | ||
| moccasin | #FFE4B5 | 255,228,181 | ||
| navajowhite | #FFDEAD | 255,222,173 | ||
| navy | #000080 | 0,0,128 | ||
| oldlace | #FDF5E6 | 253,245,230 | ||
| olive | #808000 | 128,128,0 | ||
| olivedrab | #6B8E23 | 107,142,35 | ||
| orange | #FFA500 | 255,165,0 | ||
| orangered | #FF4500 | 255,69,0 | ||
| orchid | #DA70D6 | 218,112,214 | ||
| palegoldenrod | #EEE8AA | 238,232,170 | ||
| palegreen | #98FB98 | 152,251,152 | ||
| paleturquoise | #AFEEEE | 175,238,238 | ||
| palevioletred | #DB7093 | 219,112,147 | ||
| papayawhip | #FFEFD5 | 255,239,213 | ||
| peachpuff | #FFDAB9 | 255,218,185 | ||
| peru | #CD853F | 205,133,63 | ||
| pink | #FFC0CB | 255,192,203 | ||
| plum | #DDA0DD | 221,160,221 | ||
| powderblue | #B0E0E6 | 176,224,230 | ||
| purple | #800080 | 128,0,128 | ||
| rebeccapurple | #663399 | 102,51,153 | ||
| red | #FF0000 | 255,0,0 | ||
| rosybrown | #BC8F8F | 188,143,143 | ||
| royalblue | #4169E1 | 65,105,225 | ||
| saddlebrown | #8B4513 | 139,69,19 | ||
| salmon | #FA8072 | 250,128,114 | ||
| sandybrown | #F4A460 | 244,164,96 | ||
| seagreen | #2E8B57 | 46,139,87 | ||
| seashell | #FFF5EE | 255,245,238 | ||
| sienna | #A0522D | 160,82,45 | ||
| silver | #C0C0C0 | 192,192,192 | ||
| skyblue | #87CEEB | 135,206,235 | ||
| slateblue | #6A5ACD | 106,90,205 | ||
| slategray | #708090 | 112,128,144 | ||
| slategrey | #708090 | 112,128,144 | ||
| snow | #FFFAFA | 255,250,250 | ||
| springgreen | #00FF7F | 0,255,127 | ||
| steelblue | #4682B4 | 70,130,180 | ||
| tan | #D2B48C | 210,180,140 | ||
| teal | #008080 | 0,128,128 | ||
| thistle | #D8BFD8 | 216,191,216 | ||
| tomato | #FF6347 | 255,99,71 | ||
| turquoise | #40E0D0 | 64,224,208 | ||
| violet | #EE82EE | 238,130,238 | ||
| wheat | #F5DEB3 | 245,222,179 | ||
| white | #FFFFFF | 255,255,255 | ||
| whitesmoke | #F5F5F5 | 245,245,245 | ||
| yellow | #FFFF00 | 255,255,0 | ||
| yellowgreen | #9ACD32 | 154,205,50 |
