Had the same issue with maker API
Did remove/re-add work for you as well?
Oh...and @kkossev, I've been wondering if your driver should get its own thread?
I tried a few things before it started working... I think remove/add from Maker API was one of them.
I was trying to access it from Node Red. It was showing the attribute in the device node, but it just wasn't updating when changed at first.
Done :
Let's use the new thread for VINDSTYRKA-related discussions.
On the OP "What to buy?" - seems like that a Drigera hub is a must-have for those of us, who are using a lot of IKEA buttons and remotes.
Latest IKEA firmware updates made possible a lot of buttons and remotes (probably all?) to pair and work directly to Hubitat hubs !
There are two new excellent drivers by @dandanache (the author of the Zigbee mesh graph) for IKEA remotes :
I haven't tried the E1743 on/off dimmer yet (this is what we use the most), but it would be great if I could.
Right now I'm running my Ikea buttons through my SmartThings hub.
My long term hope is to be able to use Matter between HE and the Dirigera, but direct pairing to HE (without battery issues) would be even better.
E1743 on/off dimmer will work with HE only if the device firmware is upgraded to the latest version - can be done using a Drigera hub or Z2M/ZHA.
The older firmware was using only ZIgbee Groups broadcasts, which are filtered in Hubitat (bit work in ST and Z2M/ZHA).
Works amazing with your Tuya ZigBee Button Driver and the HE Button Controller app.
I've been having issues with these buttons lately on SmartThings since the last ST firmware update.
If they don't eat batteries while connected to HE, this could ultimately remove another piece of hardware from my setup once I find a way to use my Ikea motion sensors.
@kkossev just wanted to let you know that the fairly new Ikea RODRET button is working with your Tuya Zigbee Button driver.
Well, I had the opportunity to confirm my hypothesis today… 100 for the TVOC index is purely a relative metric…
I am currently seasoning my cast iron skillets, which produced a LOT of fumes… it saturated the sensors, both the PM2.5 and the TVOC. I was wondering if they were stuck because they were not moving, but turns out they were really just saturated. I rebooted the IKEA vindisktra, and the TVOC index stayed around 100 for a lot longer than the PM2.5 which just went back up right after the reboot.
I started the seasoning process at 16:00 or so, I rebooted the vindysktra at 17:05 or so.
I started a second cycle of seasoning around 18:30.
