@patrick Are there instructions somewhere to help with adding a user to the app. As I stated above they are cancelling each other out so I am obviously doing it wrong. thanks
On one of the two phones, when you log in, it shows you the Hubitat Hub devices it has found. You need to click Create New in order to associate a second Portal Account with its own Presence device on the hub.
It doesn't seem to but if you think about it it wouldn't. As nothing leaves the phone apart from in or out of the circle, therefore the only log you would see is the presence device changing from present to not present depending on if it needs to.
You can also simply move the geofence Pin temporarily to force the app to send a “not present” event and then move it back to your house to send a “present” event.
You should see her phone in your hub’s list of devices. If you view that device’s details on your hub, you will see the “presence” and “notification” events if you click on “Events”, IIRC.
You can also send a test push notification to her phone as well on that device’s details page.
As we work on fixing a few bugs (thanks to all that have helped in reporting, tracking down and reproducing many of them)... Here are a few tricks that some are using to fix certain issues getting started.
First, known issue, it is best to not name / change the label of your Mobile App Device for now. If you do, do not use anything but alpha numeric for now, otherwise your device list might not populate and duplicate devices will most likely be generated.
Second, if you aren't getting geofence events, a couple things can be done, move the pin in and out of the current location or go into settings and click send geo event.
Third, can't hurt to go into settings "select hub" and pick your hub and then your current device. Some users have reported that this fixed their issues.
Fourth, after initial install, toggling on/off wifi might be enough to create a geo event, similar to #2...
Fifth, username / email is case sensitive as is password. Make sure you have your email exactly the same as when you registered. Can check what account on hub ip/hub/register for what account(s) are linked / registered to that hub.
@patrick Have the app set up with both our phones as per the instructions. Device page for wife shows present but she has left and is way beyond the geofence I set up on her phone.
Device event page does not show anything either.
