Hubitat Elevation Software update 1.1.2 is now available:
NOTE: httpPOST method has changed and could effect some apps and drivers that use this method, please see this post for more information before you update to this version.
Please note, the process takes about a minute to download (depending on your Internet connection) and extract the hub update, and 1-2 minutes to perform the update after you click 'Update Hub'. We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 1.1.1:
Additions / Changes
- Added new method httpGet(String uri, Closure closure)
- Added new methods httpPostJson(String uri, String body, Closure closure), httpPostJson(String uri, Map body, Closure closure) and httpPost(Map params, Closure closure)
- Added getFirmwareVersionString() method to Hub object.
- Added global TTS Voice selection to settings page
- Re-enabled Original Echo App (for UK users)
- Streamlined the Z-Wave Info page in settings
- Color Temperature per Mode added to
- Rule Machine
- Button Controller
- Motion Lighting
- Mode Lighting
- Groups
- Added RGB, RGBW and Color Temperature bulbs
- Hubitat Dashboard:
- Added Fan Template
- New drivers and updates:
- New LUX Zigbee Thermostat driver
- New Generic Z-Wave Motion Temperature Sensor
- Added commands setNextEffect setPreviousEffect to Nanoleaf driver
- Added auto inactive preference to virtual motion sensor
- Added demo cycle preference to virtual thermostat driver
- Pushover driver now supports emergency notification with “[E] message”; must first set Retry Interval and Auto Expire in device preferences
- New Integration:
- Ecobee
Bug Fixes
- Display what devices are using a driver when attempting to delete instead of throwing a database error.
- Fixed discovery of Secondary Z-Wave controller (Aeon minimote)
- Fixed Z-Wave association set on device join, some devices were rejected the message.
- Fixed Zen thermostat missed/slow commands
- Implement Z-Wave command class clockV1
- Add timeout to http calls that do not respond, fixes issue with stopped automations.
- Generic Z-Wave Contact Sensor updates for Aeotec device reporting issues
- Fix location and hub event pruning (previously only deleted 5K records per day)
- Existing installs will get subscriptions refreshed for HSM
- Fixed Water Template extra battery bug
- Fixed relay custom colors bug
- Fixed unit values showing multiple times on update bug
- Rule Machine:
- Fixed sunrise/sunset offsets for triggers
- Fixed Private Boolean as condition test
- Throws an exception for no rule defined instead of npe
- Disallow cancel on truth change for triggered rule
- Fixed bug with At Certain Time for triggered rule
- Fixed bug with Cloud and Local Endpoints
- Button Controller
- Fixed bug for defining buttons #6 and #7
- Lutron Integration
- Fixed driver selection for shades
