Ok.. I started this from a request.. but honestly not sure now what y'all are wanting from it.. So I'm posting what I have and requesting feature requests..
The built-in driver seems to have all the features included ..
The only thing that my driver adds is Color Temperature control .. And there are so many options on this thing I wanted guidance on what y'all wanted out of it..
Sounds correct to me, in that it is trying to adjust the color. I do not think it "knows" you have RGB only, so it is setting that portion assuming the white was working.
I do not have much of anything that outputs 0-10 except my aquarium controller. I do not think I will put a Zen31 for controlling aquarium lights. But... I might be interesting if I find a 0-10v temperature, humidity, sound, or motion sensor. Not REALLY practical (better to have them on the Hubitat I think) but could be in interesting project to color the lights based on temperature, humidity, or how much activity there is (my kids would love the last 2).
It looks horrible when coming from the same strip.. That's why I have always done strip controllers as emulating RGBW Bulbs where it switched identity (colorMode) from CT to RGB depending on if you are using CT or RGB
Setting RGBW to 100% might not look great, but it's twice as bright which is why I sometimes do it...
That being said, if the ability to use RGB and W at the same time was added to this driver or someone wants to do that with the built-in driver, then they should check to make sure their LED strip supports it.
Most LED strips I've seen do, but I came across a cheap LED strip with split LEDs that mentioned in the product description that using both at full strength can cause voltage/overheating issues.
What are the voice commands for this? Can I tell something like Alexa to set each component individually? Would I need to make a scene then use a virtual switch/button to trigger that? Just wanted to get a better idea of the scope via voice control
I just got my RGBW spot lights today and hooked them up to test. Fantastic! Better than the included driver! Did you ever do the child removal mod? I switched to your driver but the child devices are still there. 1.0 though so not sure if you did it. Thanks again for more amazing work! Controlling my pool lights via Alexa in the future for. #BadAss
