Zwave smart switch and dimmer fingerprints
For folks that have newer zwave switches and dimmers, there are two new drivers that you may want to try.
Generic zwave smart switch and
Generic zwave smart dimmer
If these drivers work for the device in question, please post the fingerprint here so I can get your devices added, thanks.
@mike.maxwell Working on the Homeseer 100 series dimmers
  • deviceType: 17479
  • inClusters: 0x5E,0x86,0x72,0x5A,0x85,0x59,0x73,0x26,0x27,0x70,0x2C,0x2B,0x5B,0x7A
  • outClusters: 0x5B
  • deviceId: 12340
  • manufacturer: 12
@mike.maxwell Working with the HomeSeer 200 series dimmers as well! I also noticed the "Turn on Indicator" when off works with the 200's. Doesn't work with the 100's. Now we just need default indicator color option. I don't see anything for the multitap functionality, but im thinking that may only show up under a button manager?
  • deviceType: 17479
  • inClusters: 0x5E,0x86,0x85,0x59,0x55,0x72,0x5A,0x73,0x26,0x27,0x70,0x5B,0x2C,0x2B,0x9F,0x6C,0x7A
  • outClusters: 0x5B
  • deviceId: 12342
  • manufacturer: 12
The Generic smart Switch DH is working with the Homeseer 200 series switch! Also, it’s responds faster using Hubitat than it does clicking the physical switch! Indicator light also works with it.
  • deviceType: 17479
  • inClusters: 0x5E,0x25,0x27,0x85,0x59,0x55,0x86,0x72,0x5A,0x73,0x70,0x5B,0x2C,0x2B,0x9F,0x6C,0x7A
  • outClusters: 0x5B
  • deviceId: 12341
  • manufacturer: 12
Awesome, there is generic zwave central scene switch and dimmer for button capabilities, did you try that driver with those devices? I have the oem versions of those devices that i wrote those drivers for.
@mike.maxwell Thanks for the pointer. I didn’t notice the central scene dimmer driver. I just tried it and it seems to be working well! I noticed that the button controller app lists it as an available button device! Any way you could add in the leave bottom light on when off to this driver like the new generic Smart Dimmer has? Works well for the 200 series dimmers.
the zwp wd-100 that i coded against for this driver didn’t have a parameter setting for that…
Are you saying that the settings indicator light functions in the generic smart dimmer work correctly with the 200 dimmers?
Yup! It's working with the 200 dimmers, but not the 100's.
You may want to check out this DH I got from the ST forum. I was using this one for the 200’s, and it allows you to set a default color as well! I know it says 100 in the DH comments, but its the 200 series code.
 *  HomeSeer HS-WD100+
 *  Copyright 2018 HomeSeer
 *  Modified from the work by DarwinsDen device handler for the WD100 version 1.03
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 *	Author: HomeSeer
 *	Date: 12/2017
 *	Changelog:
 *	1.0	Initial Version
 *   Button Mappings:
 *   ACTION          BUTTON#    BUTTON ACTION
 *   Double-Tap Up     1        pressed
 *   Double-Tap Down   2        pressed
 *   Triple-Tap Up     3        pressed
 *   Triple-Tap Down   4        pressed
 *   Hold Up           5 	    pressed
 *   Hold Down         6 	    pressed
 *   Single-Tap Up     7        pressed
 *   Single-Tap Down   8        pressed
 *   4 taps up         9        pressed
 *   4 taps down       10       pressed
 *   5 taps up         11       pressed
 *   5 taps down       12       pressed
metadata {
	definition (name: "WD200+ Dimmer", namespace: "homeseer", author: "support@homeseer.com") {
		capability "Switch Level"
		capability "Actuator"
		capability "Indicator"
		capability "Switch"
		capability "Polling"
		capability "Refresh"
		capability "Sensor"
        capability "Button"
        capability "Configuration"
        command "tapUp2"
        command "tapDown2"
        command "tapUp3"
        command "tapDown3"
        command "tapUp4"
        command "tapDown4"
        command "tapUp5"
        command "tapDown5"
        command "holdUp"
        command "holdDown"
        command "setStatusLed"
        command "setSwitchModeNormal"
        command "setSwitchModeStatus"
        command "setDefaultColor"
        fingerprint mfr: "000C", prod: "4447", model: "3036"
	simulator {
		status "on":  "command: 2003, payload: FF"
		status "off": "command: 2003, payload: 00"
		status "09%": "command: 2003, payload: 09"
		status "10%": "command: 2003, payload: 0A"
		status "33%": "command: 2003, payload: 21"
		status "66%": "command: 2003, payload: 42"
		status "99%": "command: 2003, payload: 63"
		// reply messages
		reply "2001FF,delay 5000,2602": "command: 2603, payload: FF"
		reply "200100,delay 5000,2602": "command: 2603, payload: 00"
		reply "200119,delay 5000,2602": "command: 2603, payload: 19"
		reply "200132,delay 5000,2602": "command: 2603, payload: 32"
		reply "20014B,delay 5000,2602": "command: 2603, payload: 4B"
		reply "200163,delay 5000,2602": "command: 2603, payload: 63"
    preferences {
       input "doubleTapToFullBright", "bool", title: "Double-Tap Up sets to full brightness",  defaultValue: false,  displayDuringSetup: true, required: false
       input "singleTapToFullBright", "bool", title: "Single-Tap Up sets to full brightness",  defaultValue: false,  displayDuringSetup: true, required: false
       input "doubleTapDownToDim",    "bool", title: "Double-Tap Down sets to 25% level",      defaultValue: false,  displayDuringSetup: true, required: false
       input "reverseSwitch", "bool", title: "Reverse Switch",  defaultValue: false,  displayDuringSetup: true, required: false
       input "bottomled", "bool", title: "Bottom LED On if Load is Off",  defaultValue: false,  displayDuringSetup: true, required: false
       input ( "localcontrolramprate", "number", title: "Press Configuration button after changing preferences\n\nLocal Ramp Rate: Duration (0-90)(1=1 sec) [default: 3]", defaultValue: 3,range: "0..90", required: false)
       input ( "remotecontrolramprate", "number", title: "Remote Ramp Rate: duration (0-90)(1=1 sec) [default: 3]", defaultValue: 3, range: "0..90", required: false)
       input ( "color", "enum", title: "Default LED Color", options: ["White", "Red", "Green", "Blue", "Magenta", "Yellow", "Cyan"], description: "Select Color", required: false)
	tiles(scale: 2) {
		multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
			tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
				attributeState "on", label:'${name}', action:"switch.off", icon:"st.Home.home30", backgroundColor:"#79b821", nextState:"turningOff"
				attributeState "off", label:'${name}', action:"switch.on", icon:"st.Home.home30", backgroundColor:"#ffffff", nextState:"turningOn"
				attributeState "turningOn", label:'${name}', action:"switch.off", icon:"st.Home.home30", backgroundColor:"#79b821", nextState:"turningOff"
				attributeState "turningOff", label:'${name}', action:"switch.on", icon:"st.Home.home30", backgroundColor:"#ffffff", nextState:"turningOn"
			tileAttribute ("device.level", key: "SLIDER_CONTROL") {
				attributeState "level", action:"switch level.setLevel"
            tileAttribute("device.status", key: "SECONDARY_CONTROL") {
                attributeState("default", label:'${currentValue}', unit:"")
		standardTile("refresh", "device.switch", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
			state "default", label:'', action:"refresh.refresh", icon:"st.secondary.configure"
        valueTile("firmwareVersion", "device.firmwareVersion", width:2, height: 2, decoration: "flat", inactiveLabel: false) {
			state "default", label: '${currentValue}'
		valueTile("level", "device.level", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
			state "level", label:'${currentValue} %', unit:"%", backgroundColor:"#ffffff"
        standardTile("tapUp2", "device.button", width: 2, height: 2, decoration: "flat") {
			state "default", label: "Tap ▲▲", backgroundColor: "#ffffff", action: "tapUp2", icon: "st.Home.home30"
        standardTile("tapDown2", "device.button", width: 2, height: 2, decoration: "flat") {
			state "default", label: "Tap ▼▼", backgroundColor: "#ffffff", action: "tapDown2", icon: "st.Home.home30"
        standardTile("tapUp3", "device.button", width: 2, height: 2, decoration: "flat") {
			state "default", label: "Tap ▲▲▲", backgroundColor: "#ffffff", action: "tapUp3", icon: "st.Home.home30"
        standardTile("tapDown3", "device.button", width: 2, height: 2, decoration: "flat") {
			state "default", label: "Tap ▼▼▼", backgroundColor: "#ffffff", action: "tapDown3", icon: "st.Home.home30"
        standardTile("tapUp4", "device.button", width: 2, height: 2, decoration: "flat") {
			state "default", label: "Tap ▲▲▲▲", backgroundColor: "#ffffff", action: "tapUp4", icon: "st.Home.home30"
        standardTile("tapDown4", "device.button", width: 2, height: 2, decoration: "flat") {
			state "default", label: "Tap ▼▼▼▼", backgroundColor: "#ffffff", action: "tapDown4", icon: "st.Home.home30"
        standardTile("tapUp5", "device.button", width: 2, height: 2, decoration: "flat") {
			state "default", label: "Tap ▲▲▲▲▲", backgroundColor: "#ffffff", action: "tapUp5", icon: "st.Home.home30"
        standardTile("tapDown5", "device.button", width: 2, height: 2, decoration: "flat") {
			state "default", label: "Tap ▼▼▼▼▼", backgroundColor: "#ffffff", action: "tapDown5", icon: "st.Home.home30"
        standardTile("holdUp", "device.button", width: 2, height: 2, decoration: "flat") {
			state "default", label: "Hold ▲", backgroundColor: "#ffffff", action: "holdUp", icon: "st.Home.home30"
        standardTile("holdDown", "device.button", width: 2, height: 2, decoration: "flat") {
			state "default", label: "Hold ▼", backgroundColor: "#ffffff", action: "holdDown", icon: "st.Home.home30"
		main(["switch"])
		details(["switch","tapUp2","tapUp3","tapUp4","tapUp5","holdUp","tapDown2","tapDown3","tapDown4","tapDown5","holdDown","level","firmwareVersion", "refresh"])
	def result = null
    log.debug (description)
    if (description != "updated") {
	    def cmd = zwave.parse(description, [0x20: 1, 0x26: 1, 0x70: 1])
        if (cmd) {
		    result = zwaveEvent(cmd)
    if (!result){
        log.debug "Parse returned ${result} for command ${cmd}"
    else {
		log.debug "Parse returned ${result}"
	return result
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
 	dimmerEvents(cmd)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) {
	dimmerEvents(cmd)
def zwaveEvent(physicalgraph.zwave.commands.switchmultilevelv1.SwitchMultilevelReport cmd) {
    dimmerEvents(cmd)
def zwaveEvent(physicalgraph.zwave.commands.switchmultilevelv1.SwitchMultilevelSet cmd) {
	dimmerEvents(cmd)
private dimmerEvents(physicalgraph.zwave.Command cmd) {
	def value = (cmd.value ? "on" : "off")
	def result = [createEvent(name: "switch", value: value)]
    state.lastLevel = cmd.value
	if (cmd.value && cmd.value <= 100) {
		result << createEvent(name: "level", value: cmd.value, unit: "%")
	return result
def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
	log.debug "ConfigurationReport $cmd"
	def value = "when off"
	if (cmd.configurationValue[0] == 1) {value = "when on"}
	if (cmd.configurationValue[0] == 2) {value = "never"}
	createEvent([name: "indicatorStatus", value: value])
def zwaveEvent(physicalgraph.zwave.commands.hailv1.Hail cmd) {
	createEvent([name: "hail", value: "hail", descriptionText: "Switch button was pressed", displayed: false])
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
	log.debug "manufacturerId:   ${cmd.manufacturerId}"
	log.debug "manufacturerName: ${cmd.manufacturerName}"
    state.manufacturer=cmd.manufacturerName
	log.debug "productId:        ${cmd.productId}"
	log.debug "productTypeId:    ${cmd.productTypeId}"
	def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
	updateDataValue("MSR", msr)
    setFirmwareVersion()
    createEvent([descriptionText: "$device.displayName MSR: $msr", isStateChange: false])
def zwaveEvent(physicalgraph.zwave.commands.versionv1.VersionReport cmd) {
    //updateDataValue("applicationVersion", "${cmd.applicationVersion}")
    log.debug ("received Version Report")
    log.debug "applicationVersion:      ${cmd.applicationVersion}"
    log.debug "applicationSubVersion:   ${cmd.applicationSubVersion}"
    state.firmwareVersion=cmd.applicationVersion+'.'+cmd.applicationSubVersion
    log.debug "zWaveLibraryType:        ${cmd.zWaveLibraryType}"
    log.debug "zWaveProtocolVersion:    ${cmd.zWaveProtocolVersion}"
    log.debug "zWaveProtocolSubVersion: ${cmd.zWaveProtocolSubVersion}"
    createEvent([descriptionText: "Firmware V"+state.firmwareVersion, isStateChange: false])
def zwaveEvent(physicalgraph.zwave.commands.firmwareupdatemdv2.FirmwareMdReport cmd) {
    log.debug ("received Firmware Report")
    log.debug "checksum:       ${cmd.checksum}"
    log.debug "firmwareId:     ${cmd.firmwareId}"
def zwaveEvent(physicalgraph.zwave.commands.switchmultilevelv1.SwitchMultilevelStopLevelChange cmd) {
	[createEvent(name:"switch", value:"on"), response(zwave.switchMultilevelV1.switchMultilevelGet().format())]
def zwaveEvent(physicalgraph.zwave.Command cmd) {
	// Handles all Z-Wave commands we aren't interested in
def on() {
	sendEvent(tapUp1Response("digital"))
	delayBetween([
			zwave.basicV1.basicSet(value: 0xFF).format(),
	],5000)
def off() {
	sendEvent(tapDown1Response("digital"))
	delayBetween([
			zwave.basicV1.basicSet(value: 0x00).format(),
	],5000)
def setLevel (value) {
	log.debug "setLevel >> value: $value"
	def valueaux = value as Integer
	def level = Math.max(Math.min(valueaux, 99), 0)
	if (level > 0) {
		sendEvent(name: "switch", value: "on")
	} else {
		sendEvent(name: "switch", value: "off")
	sendEvent(name: "level", value: level, unit: "%")
    def result = []
    result += response(zwave.basicV1.basicSet(value: level))
    result += response("delay 5000")
    result += response(zwave.switchMultilevelV1.switchMultilevelGet())
 *  Set dimmer to status mode, then set the color of the individual LED
 *  led = 1-7
 *  color = 0=0ff
 *          1=red
 *          2=green
 *          3=blue
 *          4=magenta
 *          5=yellow
 *          6=cyan
 *          7=white
def setStatusLed (led,color,blink) {
    def cmds= []
    if(state.statusled1==null) {
    	state.statusled1=0
        state.statusled2=0
        state.statusled3=0
        state.statusled4=0
        state.statusled5=0
        state.statusled6=0
        state.statusled7=0
        state.blinkval=0
    /* set led # and color */
    switch(led) {
    	case 1:
        	state.statusled1=color
            break
        case 2:
        	state.statusled2=color
            break
    	case 3:
        	state.statusled3=color
            break
        case 4:
        	state.statusled4=color
            break
        case 5:
        	state.statusled5=color
            break
        case 6:
        	state.statusled6=color
            break
        case 7:
        	state.statusled7=color
            break
    if(state.statusled1==0 && state.statusled2==0 && state.statusled3==0 && state.statusled4==0 && state.statusled5==0 && state.statusled6==0 && state.statusled7==0)
    	// no LEDS are set, put back to NORMAL mode
        cmds << zwave.configurationV2.configurationSet(configurationValue: [0], parameterNumber: 13, size: 1).format()
    else
    	// at least one LED is set, put to status mode
        cmds << zwave.configurationV2.configurationSet(configurationValue: [1], parameterNumber: 13, size: 1).format()
        // set the LED to color
        cmds << zwave.configurationV2.configurationSet(configurationValue: [color], parameterNumber: led+20, size: 1).format()
        // check if LED should be blinking
        def blinkval = state.blinkval
        if(blink)
            switch(led) {
            	case 1:
                	blinkval = blinkval | 0x1
                    break
                case 2:
                	blinkval = blinkval | 0x2
                    break
                case 3:
                	blinkval = blinkval | 0x4
                    break
                case 4:
                	blinkval = blinkval | 0x8
                    break
                case 5:
                	blinkval = blinkval | 0x10
                    break
                case 6:
                	blinkval = blinkval | 0x20
                    break
                case 7:
                	blinkval = blinkval | 0x40
                    break
        	cmds << zwave.configurationV2.configurationSet(configurationValue: [blinkval], parameterNumber: 31, size: 1).format()
            // set blink speed, also enables blink, 1=100ms blink frequency
            cmds << zwave.configurationV2.configurationSet(configurationValue: [5], parameterNumber: 30, size: 1).format()
            state.blinkval = blinkval
        else
        	switch(led) {
            	case 1:
                	blinkval = blinkval & 0xFE
                    break
                case 2:
                	blinkval = blinkval | 0xFD
                    break
                case 3:
                	blinkval = blinkval | 0xFB
                    break
                case 4:
                	blinkval = blinkval | 0xF7
                    break
                case 5:
                	blinkval = blinkval | 0xEF
                    break
                case 6:
                	blinkval = blinkval | 0xDF
                    break
                case 7:
                	blinkval = blinkval | 0xBF
                    break
 	delayBetween(cmds, 500)
 * Set Dimmer to Normal dimming mode (exit status mode)
def setSwitchModeNormal() {
	def cmds= []
 * Set Dimmer to Status mode (exit normal mode)
def setSwitchModeStatus() {
	def cmds= []
 * Set the color of the LEDS for normal dimming mode, shows the current dim level
def setDefaultColor(color) {
	def cmds= []
    cmds << zwave.configurationV2.configurationSet(configurationValue: [color], parameterNumber: 14, size: 1).format()
def poll() {
def refresh() {
	log.debug "refresh() called"
    configure()
def zwaveEvent(physicalgraph.zwave.commands.centralscenev1.CentralSceneNotification cmd) {
    log.debug("sceneNumber: ${cmd.sceneNumber} keyAttributes: ${cmd.keyAttributes}")
    def result = []
    switch (cmd.sceneNumber) {
      case 1:
          // Up
          switch (cmd.keyAttributes) {
              case 0:
                   // Press Once
                  result += createEvent(tapUp1Response("physical"))
                  result += createEvent([name: "switch", value: "on", type: "physical"])
                  if (singleTapToFullBright)
                     result += setLevel(99)
                  break
              case 1:
                  result=createEvent([name: "switch", value: "on", type: "physical"])
                  break
              case 2:
                  // Hold
                  result += createEvent(holdUpResponse("physical"))
                  break
              case 3:
                  // 2 Times
                  result +=createEvent(tapUp2Response("physical"))
                  if (doubleTapToFullBright)
                  break
              case 4:
                  // 3 times
                  result=createEvent(tapUp3Response("physical"))
                  break
              case 5:
                  // 4 times
                  result=createEvent(tapUp4Response("physical"))
                  break
              case 6:
                  // 5 times
                  result=createEvent(tapUp5Response("physical"))
                  break
              default:
                  log.debug ("unexpected up press keyAttribute: $cmd.keyAttributes")
          break
      case 2:
          // Down
              case 0:
                  // Press Once
                  result += createEvent(tapDown1Response("physical"))
                  result += createEvent([name: "switch", value: "off", type: "physical"])
                  break
              case 1:
                  result=createEvent([name: "switch", value: "off", type: "physical"])
                  break
              case 2:
                  // Hold
                  result += createEvent(holdDownResponse("physical"))
                  break
              case 3:
                  // 2 Times
                  result+=createEvent(tapDown2Response("physical"))
                  if (doubleTapDownToDim)
                     result += setLevel(25)
                  break
              case 4:
                  // 3 Times
                  result=createEvent(tapDown3Response("physical"))
                  break
              case 5:
                  // 4 Times
                  result=createEvent(tapDown4Response("physical"))
                  break
              case 6:
                  // 5 Times
                  result=createEvent(tapDown5Response("physical"))
                  break
              default:
                  log.debug ("unexpected down press keyAttribute: $cmd.keyAttributes")
           break
      default:
           // unexpected case
           log.debug ("unexpected scene: $cmd.sceneNumber")
   return result
def tapUp1Response(String buttonType) {
    sendEvent(name: "status" , value: "Tap ▲")
	[name: "button", value: "pushed", data: [buttonNumber: "7"], descriptionText: "$device.displayName Tap-Up-1 (button 7) pressed",
       isStateChange: true, type: "$buttonType"]
def tapDown1Response(String buttonType) {
    sendEvent(name: "status" , value: "Tap ▼")
	[name: "button", value: "pushed", data: [buttonNumber: "8"], descriptionText: "$device.displayName Tap-Down-1 (button 8) pressed",
def tapUp2Response(String buttonType) {
    sendEvent(name: "status" , value: "Tap ▲▲")
	[name: "button", value: "pushed", data: [buttonNumber: "1"], descriptionText: "$device.displayName Tap-Up-2 (button 1) pressed",
def tapDown2Response(String buttonType) {
    sendEvent(name: "status" , value: "Tap ▼▼")
	[name: "button", value: "pushed", data: [buttonNumber: "2"], descriptionText: "$device.displayName Tap-Down-2 (button 2) pressed",
def tapUp3Response(String buttonType) {
    sendEvent(name: "status" , value: "Tap ▲▲▲")
	[name: "button", value: "pushed", data: [buttonNumber: "3"], descriptionText: "$device.displayName Tap-Up-3 (button 3) pressed",
def tapUp4Response(String buttonType) {
    sendEvent(name: "status" , value: "Tap ▲▲▲▲")
	[name: "button", value: "pushed", data: [buttonNumber: "9"], descriptionText: "$device.displayName Tap-Up-4 (button 9) pressed",
def tapUp5Response(String buttonType) {
    sendEvent(name: "status" , value: "Tap ▲▲▲▲▲")
	[name: "button", value: "pushed", data: [buttonNumber: "11"], descriptionText: "$device.displayName Tap-Up-5 (button 11) pressed",
def tapDown3Response(String buttonType) {
    sendEvent(name: "status" , value: "Tap ▼▼▼")
	[name: "button", value: "pushed", data: [buttonNumber: "4"], descriptionText: "$device.displayName Tap-Down-3 (button 4) pressed",
def tapDown4Response(String buttonType) {
    sendEvent(name: "status" , value: "Tap ▼▼▼▼")
	[name: "button", value: "pushed", data: [buttonNumber: "10"], descriptionText: "$device.displayName Tap-Down-3 (button 10) pressed",
def tapDown5Response(String buttonType) {
    sendEvent(name: "status" , value: "Tap ▼▼▼▼▼")
	[name: "button", value: "pushed", data: [buttonNumber: "12"], descriptionText: "$device.displayName Tap-Down-3 (button 12) pressed",
def holdUpResponse(String buttonType) {
    sendEvent(name: "status" , value: "Hold ▲")
	[name: "button", value: "pushed", data: [buttonNumber: "5"], descriptionText: "$device.displayName Hold-Up (button 5) pressed",
def holdDownResponse(String buttonType) {
    sendEvent(name: "status" , value: "Hold ▼")
	[name: "button", value: "pushed", data: [buttonNumber: "6"], descriptionText: "$device.displayName Hold-Down (button 6) pressed",
def tapUp2() {
	sendEvent(tapUp2Response("digital"))
def tapDown2() {
	sendEvent(tapDown2Response("digital"))
def tapUp3() {
	sendEvent(tapUp3Response("digital"))
def tapDown3() {
	sendEvent(tapDown3Response("digital"))
def tapUp4() {
	sendEvent(tapUp4Response("digital"))
def tapDown4() {
	sendEvent(tapDown4Response("digital"))
def tapUp5() {
	sendEvent(tapUp5Response("digital"))
def tapDown5() {
	sendEvent(tapDown5Response("digital"))
def holdUp() {
	sendEvent(holdUpResponse("digital"))
def holdDown() {
	sendEvent(holdDownResponse("digital"))
def setFirmwareVersion() {
   def versionInfo = ''
   if (state.manufacturer)
      versionInfo=state.manufacturer+' '
   if (state.firmwareVersion)
      versionInfo=versionInfo+"Firmware V"+state.firmwareVersion
   else
     versionInfo=versionInfo+"Firmware unknown"
   sendEvent(name: "firmwareVersion",  value: versionInfo, isStateChange: true, displayed: false)
def configure() {
   log.debug ("configure() called")
   sendEvent(name: "numberOfButtons", value: 12, displayed: false)
   def commands = []
   commands << setDimRatePrefs()
   commands << zwave.switchMultilevelV1.switchMultilevelGet().format()
   commands << zwave.manufacturerSpecificV1.manufacturerSpecificGet().format()
   commands << zwave.versionV1.versionGet().format()
   delayBetween(commands,500)
def setDimRatePrefs()
   log.debug ("set prefs")
   def cmds = []
	if (color)
        switch (color) {
        	case "White":
            	cmds << zwave.configurationV2.configurationSet(configurationValue: [0], parameterNumber: 14, size: 1).format()
                break
      		case "Red":
            	cmds << zwave.configurationV2.configurationSet(configurationValue: [1], parameterNumber: 14, size: 1).format()
                break
            case "Green":
            	cmds << zwave.configurationV2.configurationSet(configurationValue: [2], parameterNumber: 14, size: 1).format()
                break
            case "Blue":
            	cmds << zwave.configurationV2.configurationSet(configurationValue: [3], parameterNumber: 14, size: 1).format()
                break
            case "Magenta":
            	cmds << zwave.configurationV2.configurationSet(configurationValue: [4], parameterNumber: 14, size: 1).format()
                break
            case "Yellow":
            	cmds << zwave.configurationV2.configurationSet(configurationValue: [5], parameterNumber: 14, size: 1).format()
                break
            case "Cyan":
            	cmds << zwave.configurationV2.configurationSet(configurationValue: [6], parameterNumber: 14, size: 1).format()
                break
   if(localcontrolramprate != null) {
   		//log.debug localcontrolramprate
   		def localcontrolramprate = Math.max(Math.min(localcontrolramprate, 90), 0)
   		cmds << zwave.configurationV2.configurationSet(configurationValue: [localcontrolramprate], parameterNumber: 12, size: 1).format()
   if(remotecontrolramprate != null) {
   		log.debug remotecontrolramprate
   		def remotecontrolramprate = Math.max(Math.min(remotecontrolramprate, 90), 0)
   		cmds << zwave.configurationV2.configurationSet(configurationValue: [remotecontrolramprate], parameterNumber: 11, size: 1).format()
   if (reverseSwitch)
       cmds << zwave.configurationV2.configurationSet(configurationValue: [1], parameterNumber: 4, size: 1).format()
   else
      cmds << zwave.configurationV2.configurationSet(configurationValue: [0], parameterNumber: 4, size: 1).format()
   if (bottomled)
       cmds << zwave.configurationV2.configurationSet(configurationValue: [0], parameterNumber: 3, size: 1).format()
   else
      cmds << zwave.configurationV2.configurationSet(configurationValue: [1], parameterNumber: 3, size: 1).format()
   //Enable the following configuration gets to verify configuration in the logs
   //cmds << zwave.configurationV1.configurationGet(parameterNumber: 7).format()
   //cmds << zwave.configurationV1.configurationGet(parameterNumber: 8).format()
   //cmds << zwave.configurationV1.configurationGet(parameterNumber: 9).format()
   //cmds << zwave.configurationV1.configurationGet(parameterNumber: 10).format()
   return cmds
def updated()
 def cmds= []
 cmds << setDimRatePrefs
Yes, I’m aware of that feature!
I challenge anyone over the age of 10 to successfully pull off anything over a doubletap on a regular basis…
Haha, My kitchen switch was set to doubletap up = turn on fireplace. doubletap down = off fireplace, Trippletap up Going to bed routine!
It is pretty crazy and seemingly unrealistic that the 200’s support up to 6 taps!
Smart Switch DH working with GE 14291 switch:
  • deviceType: 18770
  • inClusters: 0x5E,0x56,0x86,0x72,0x5A,0x85,0x59,0x73,0x25,0x27,0x70,0x2C,0x2B,0x7A
  • deviceId: 12342
  • manufacturer: 99
Edit: Hmm…the Indicator light setting doesn’t seem to do anything. I had this issue before with the other switch DH, but for some reason, it didn’t work one time, but then did another time. Maybe that will also be the case with this Smart DH.
Aeotec Smart Switch Gen 5
  • zwaveSecurePairingComplete: true
  • inClusters: 0x5E,0x25,0x32,0x27,0x2C,0x2B,0x70,0x85,0x59,0x56,0x72,0x86,0x7A,0x73,0x98
  • outClusters: 0x5A,0x82
  • deviceId: 75
  • manufacturer: 134
There's no way a secure pair can happen with this driver...
There’s no way a secure pair can happen with this driver…
Bad switch then?, re-pair?
I'm sure the switch is fine, but the driver is not secure enabled, and I can't force a user to not use secure pairing. I'm surprised this is working actually, given that it was paired securely to the hub.
Since I don’t care about secure pairing, and I don’t see how to turn that offf, any suggestions?
you will have to exclude it, then pair it again with a single tap.
Tried that a number of times, as well as a factory reset of the switch in between, no go… will have to look at it later after reading the documentation from Aeotec.
