I should have mentioned that this shouldn't be necessary anymore given that if the Z-Wave radio crashes, the hub has a catch in place to automatically restart it now. There were some problems in the early days of the C-7 where fully restarting the Z-Wave radio was the only way out (because this crash happened). Given this change plus a few firmware updates that have happened since, these should be few and far between, if there are any at all, nowadays. (Though as long as you shut down properly, it shouldn't hurt.) But I suppose @bcopeland could comment for sure on what to advise.
But certainly, 10 minutes as mentioned in that thread should have never been necessary. It sounds like a compromise between 30 seconds for this and the 15-20+ minutes for Zigbee panic mode while not actually being either.
@bcopeland I've now experienced this same problem tonight where my zwave table is empty after doing a restore both using local back-up and cloud backup. I've tried the soft reset and restore from latest backup and then power down and wait 5 min. and still table is empty. What are the next steps to get my hub restored with zwave devices all back?
Yes I understand basic restore only does devices apps, etc. However, I thought with Cloud restore selecting this option would also restore the Z-Wave devices
We should be talking about what first steps should be taken when the Z-Wave radio collapses.
It sounds like you may have caused more problems trying to restore the cloud backup after having had recurring radio problems, which may have resulted in a corrupted Z-Wave database, from which recovery may no longer be possible.
Please send me a private message with your Hub's ID and we can further investigate to see if you can recover your devices, at this point.
I want to thank the @support_team for their fast response to my post. While it was unfortunate that I got caught with [URGENT] Z-Wave Cloud Backup Issue and had to re-add all my Z-Wave devices at least I now know why the loss occurred. More importantly this is the first opportunity I've had to use "Swap Apps Device" feature. This made the process of adding the Z-Wave devices back in much easier and faster than the old method of having to edit the DNI names Migrating a Z-Wave Network My entire HUB and automation are back-up and running without issue and everything backed-up per Release 2.3.2.127 instructions
Great to see things are up and running again, and have to agree that the new Swap feature is excellent. Also happy to see your "glass half-full" perspective on all of this - very nice!
sorry to bring up a zombie thread but I've now noticed that my C7 is dropping Z-wave (no z-wave devices report status changes) sometimes they still appear on the z-wave status page but sometimes they don't (this time they are not, but I'm not home to unplug until later this afternoon) I have noticed that shutting down and unplugging for a few min (try to do the arbitrary 5 min from @rlithgow1 as it seems to reset everything for 4-5 days than it starts again) I have checked for ghosts and don't see any, has anyone found a reason for this (z-wave mesh seems strong and automations run very fast usually until they don't) any suggestions would be great (don't want this causing an issue with the WAF as I try to get it reset before she notices (or complains about it)
Nothing in the zwave logs (it's blank). I did see there was a zwave firmware update available and upon updating it seems to be back up and working. I'm now seeing anything out of the ordinary in the hub events log either. So maybe the firmware update fixed it. The firmware now says 7.18/7.15 radio/SDK
Ahh, most of us had we realized would have recommended updating had we known. Good teal. Do a shutdown from settings and unplug power for 5 mins just to clear the radio again..
