Curious if anyone else is seeing issues with Zwave going down on their C-7. This last time I restarted my hub it only lasted a couple days before going offline again.
On 2.3.0.124, which is when this seems to have started. Last time before this, stuff was still working, but logging for Zwave devices had stopped.
Zwave details under settings does not load. So the hub has seemingly completely lost contact with the Zwave module.
Rebooting hub does not resolve. Have to shutdown, unplug, replug.
Go to settings>>back up and restore. Click the download button and save the file to your PC. This will be a clean backup.
Go to yourhubip:8081 and click softreset. Upon reboot you will restore the backup you saved on your computer.
Once you have done that do a shutdown from the settings menu. Unplug the hubitat at the wall (never the hub) for 10 mins. Power back up. See how things are. Once you do that post a shot of your z-wave settings page
sorry, I did shut it down (in a hurry because I started the PoE port shutdown by mistake first). it did register as "hub is shut down, you can remove power" (or whatever it says)
That's because the browser has cached your credentials (Mac addr) and the hub isn't accepting them. Time out in other words that doesn't get the browser convinced.
If those nodes persist at 9.6 next thing I'd try (after waiting, which is smart/good) would be an individual repair and then wait another couple days for them to hopefully re-route. Won't happen right away, @bcopeland has counseled patience waiting for the devices to find a new/better way home after a repair.
There's always a god damned ghost... Seriously, the majority of z-wave issues I see are ghosts, zooz sensors, lack of good repeaters, or bad device. Yeah there are some z-wave revision probs but for the most part it's one of the 4.... I have a tendency to check for ghosts right off the bat I know... I should just make a macro key on my keyboard "Post a screen shot of your z-wave table"
